Question about Whirlpool GC5SHEXNS Side by Side Refrigerator
Excessive moisture on ref compartment
What is the best solution to eliminate or minimize the moisture on the refrigerator compartment that causes water drifting on aside by side refrigerator here in the Philippines.
  • arvin61375 Feb 28, 2009
    i already check the door gaskets, freezer and ref compartment. Gaskets are intact. The problem is, when the the ref compartment is empty or less food loaded, there is no presence of moisture, but if the load of ref compartment is full, moisture is start to build up and drift on the divider shelves. Is there's any solution that i should do to prevent the excessive moisture on the ref compartment.
  • arvin61375 Mar 05, 2009
    Thanks for helping. But on my experience, the defrostng time/operation will be activated base on the whole 8 hours operation of the compressor not on the 8 hours operation per day. So, my estimate, defrosting will be activated from 2 to 3 days operation of the unit.
  • Whirlpool Master
  • 4,640 Answers
Make sure the door seals are in good condition. If the doors do not close and seal properly it will cause moisture to be brought inside the refrigerator and condensate will form. The refrigerator should not be level like you would want. It should have the front leaning back a little to the back wall to keep the doors from opening when you close them. Let me know if this help you, Thanks, Sea Breeze
Posted on Feb 28, 2009
  • John Tripp
    John Tripp Feb 28, 2009
    Your refrigerator should defrost every 8 hours, settings for freezer and food compartment should be set on 5 for both. If the defrost does not work 3 times a day moisture will build up. temp. settings vary for many reasons hot outside temps. and warm food. so adjust until you get proper temperatures. Let me Know, Sea Breeze
Whirlpool fridge gets frost build up in freezer
This means you have a defrost problem or a bad door gasket.
Apr 24, 2016 | Whirlpool Refrigerators
We changed our damaged freezer gasket but the top section is still icing up though it does hold the set temperature
Are you sure that the gasket is sealing perfectly all around - a properly installed gasket will minimize air and moisture getting into compartment and minimize icing up.
Jul 19, 2015 | Refrigerators
Refirgdator humidity doors freezing to the bottom of the compartment
You probably have a door not shutting all the way around or the door gasket is damaged or pulled out of guides. Excess icing is normally caused by moisture being drawn into the refrigerator through a small crack.
Hope this helps
Feb 15, 2015 | Refrigerators
What a mess. The instruction manual (really lacking in detail) does not have part numbers or model description. Excess moisture dripping in refirgeration portion of unit (top freezer; bottom...
Yes it could, you will have to check your defrost water drain, if its plugged defrost water won't go to condensate pan under unit, instead will make its way down to refrigerator section
Jun 29, 2011 | Maytag Refrigerators
Side by side refrigerator/freezer. Refrigerator warm but freezer is cold and Ice maker works well.
evaporator iced up so air cant circulate to fidge compartment... either defrost heater blown.... or air circulation fan caput... maybe seal around freezer door not very good so excess moisture getting inside...
Feb 06, 2011 | Maytag Refrigerators
Refrigerator door left open for 11 days, now when closed it makes a loud vibrating noise, what could be the cause?
Because the door was open a large amount of moisture would have been introduced to the evaporator. This moisture would condensate and freeze behind the back walls and cause ice build up on the fan motors and in the dampers. The best way to bring this back to normal is to turn the frig off for 24 hours with the doors open and food out of it. This will unthaw the ice. If you do not eliminate all the hidden frost and ice the frig will not operate to it's full potential.
Jun 19, 2010 | Kenmore 73503 Stainless Steel Bottom...
Front center panel where doors meet to close are very warm/hot to the touch. Is this normal for this refrigerator?
yes they have heaters in them to help reduce moisture on the ref you can ussually turn them off by turning the energy saver feature on but this may cause moisture to build up on the exterior part and the inside of th ref
Sep 06, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hotpoint refrigerator freezer(top) mod ctx18bacerww not cooling/freezing correctly. removed inside back panel in freezer compartment,found coils partially covered in frost, fan not blowing.. flicked fan...
Hi, fan may have stuck, but you could have a defrost problem, check defrost heater, thermodisc(defrost thermostat) and defrost timer. or excessive moisture, if your days are hot, or if you put hot foods in ref. could result in excessive ice build up. you can manually defrost it, by unpluging ref. for couple of hrs, until all ice melted. then restart. you make get excessive water on floor. be prepared.
Aug 02, 2009 | Refrigerators
Moisture on refrigerator compartment
not really. It allowes the air inside the box to equalize with the outer air pressure and keep a vacume from forming inside the box and keep the door from opening.
Feb 28, 2009 | Whirlpool GC5SHEXNS Side by Side...
Whirlpool GC5SHEXNS Side by Side Refrigerator Logo
264 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
