Question about Dell Dimension 4300 PC Desktop
Pci bus controller
Unhooked the white pci card tried to install froze up at debugger and then an error code showed up says file setupdd.sys could not be loaded error code is 4
  • steveswny
    steveswny May 11, 2010
    http://www.hardwareanalysis.com/content/...
    here you will find what u need steve,
  • John Miller Jr May 11, 2010
    Willing to bet the card youre trying to install is the problem. Either the card is defective, or you have a clone driver problem. A clone driver problem is where two or more devices are so much alike with each other that the incorrect driver for the device installs. (Example: modem model ABC1200 and ABC1300--both modems have their own drivers, but because theyre both similar in design, the driver for ABC1300 will try to install on the ABC1200 and vice versa). Are you installing this under Windows XP? Post back and let us know...
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 94 Answers
Setupdd.sys can be found on your windows xp cd.
Posted on Mar 03, 2009
Hi, my laptop tells me that I have a problem in setupdd.sys PAGE_FAULT_IN_NONPAGED_AREA How can I fix that?? /Jan
Well, you should probably replace the file from a backup or handy good installation; the error itself is explained in the Intel processor manual if you like, but overall it means that some file corruption or another soft error happened where your software was supposed to stay perfect. It is also possible that some memory timing is off, and you just need to dust and reseat your memory and graphics cards, or dial back any custom timing.
May 23, 2011 | Microsoft Windows XP Professional for PC
'm installin win xp on my pentium3 with 10gb harddisk n 256 mb ram... it shows setupdd.sys could not be loaded error code 7 durin installation.. i tried change d xp cd 3 times.. still hav same problem
change the cd-rom unit,i know it sounds crazy but try it before you waste anymore blank discs,im a tech and that is one solution that works ,good luck
Feb 27, 2011 | Computers & Internet
When starting the laptop acer 5100 it tyries to start and it shows the following Bus 06, device 02 ,function 00 error resource conflict pci in slot 03 bus 06 device 04 function...
If it just started doing this all of a sudden, then it is a good bet that *********** board is fried. If you just installed some memory or a communications card or new drive, then take it out and see if it still does it. If not, check the installation instructions to make sure it was put in right.
Sep 08, 2010 | Acer Aspire 5100 Notebook
What can I do other then the reboot CDs for a corrupt system file
Its means " setupdd.sys" is not present on your system. May be corrupted by virus or by mistake its deleted. Batter you repair your OS.
Thanks.
Feb 02, 2010 | Acer Aspire 5670 Notebook
Help on reformating pc!!!
Use different CD installer or burn your present WindowsXP to another disc. Your files might have been corrupted due to poor disk surface of your Windows Installer.
Jan 21, 2010 | Acer Aspire T310 PC Desktop
Pci card drivers
you would need to get all the drivers for your laptop from the IBM website and install all of them. If you cant find them or need further help please post back and let me know.
Apr 10, 2009 | IBM ThinkPad T60 Notebook
PROBLEM
here are some link for the error codes hope this helps.
ERROR CODE 7( NTKRNLMP.EXE) .http://support.microsoft.com/kb/812580
ERROR CODE 4 ( SETUPDD.SYS) .http://support.microsoft.com/kb/330181
Sep 18, 2008 | Toshiba Computers & Internet
Help with a toshiba TECRA 8100
Yes, it should run WinXP. The minimum system requirements to run both Windows XP Home and Professional are 233Mhz, 64Mb RAM and 1.5GB hard drive space. I have a Toshiba Tecra 8000 that still runs XP, a little slow, but has run smoothly for 5 years.
The setupdd.sys error is most likely a due to a defective hardware like RAM. Try installing only one ram if you have two to see if either one is defective; it should work for most users.
Sep 09, 2008 | Toshiba Tecra 8100 Pentium III, 850 MHz...
No HDD Found on initial XP Install
Did you insert the sata driver disks when prompted in the first stages of installation? I think it's mentioned as scsi drivers.
Mar 04, 2007 | Mach Speed (S755) Motherboard
Error code 10 Device cannot restart
Generally a code 10 refers to a dead component unfortunately.Although the card will be recognised.
Aug 29, 2006 | U.S. Robotics MAXg USR5417 802.11g/b...
Dell Dimension 4300 PC Desktop Logo
112 people viewed this question
Alun Cox
