My Kenmore 80 series washer just started making a loud Aihaiha electrical or motor type noise. This happened during a heavy load cycle. Noise was very loud. When I click to regular, delicate or hand wash. The noise lessens some. Washer will not agitate or go into a spin. Drained water by putting in spin cycle and holding down spin tab with a straw. Terrible noise continued all during process of draining the water.
  • Anonymous Apr 25, 2009
    kenmore top load washer model 4685290 tub empties after last rinse but does not spin even though motor is running. Black rubber dust from where motor attaches to transmission.
    President:
  • 373 Answers
The following are the reasons for the drum not spinning :-
* Test the lid switch
* Test the timer control
* Test the centrifugal switch
* Test the water level switch
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
In the case of loud noises in the machine, the drum bearings might have been damaged and might need a replacement. Also do check the leveling of the machine. Good luck.
Posted on Feb 28, 2009
SOURCE:
My Kenmore 80 Series washer won't agitate or spin. Makes noise.
sounds very much like the bushes have worn out on the motor,they are easy to replace take down model number to your nearest electrical shop and they will supply them for about £10.00
Jun 07, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore makes whining noise as it tries to spin
The drive coupling has probably broken. Usually happens when you overload the machine. Easy fix. READ MORE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 21, 2009 | Kenmore 24902 Top Load Washer
I have a Kenmore series 80 washer that is making a loud clunking
check the motor coupler between the gearcase and motor for wear. If it is cracked or broken it will need to be replaced
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series 110 washer making loud noise during final spin
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series loud whirring/howling noise during spin cycle
Sounds like you have a broken motor coupler. They are inexpensive. Can be a little tough to replace but I can walk you through it. You can purchase a coupler here.
http://www.shop.washermd.com/product.sc?categoryId=1&productId=1
Dave
Dec 18, 2008 | GE WBSR3140DW Top Load Washer
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washer makes loud knocking noise during spin cycle
Most washer tubs are suspended by heavy rubber O-rings. These do fail with age so that the tub is not being held centered anymore. I suspect one of them has failed or come off during a severely unbalanced load.
Kenmore 80 series makes noise in sping cycle
Its the transmission. Try to find a used appliance store in your town. Most save used parts and you should be able to pick up a used tranny for around 100 bucks.
Nov 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore front load washer
My Kenmore front-load washer starts to make the huge noise. The noise happens during the wash cycle, but is mild. During the spin cycle, the noise becomes really loud. It looks like the drum is getting loose and hitting other part of the machine.
I checked the drum, and I can sway the drum easily with my hand. So it looks some supporting structure is broken. I don't know if it is easy to open the washer to check what has been broken.
May 20, 2008 | Kenmore 44072 Front Load Washer
Kenmore series 80 washer only works right on hevy duty load
CHECK SEE IF MOTOR IS SEIZED BY TIPPING MACHINE FORWARD AND SEE IF YOU CAN TURN THE MOTOR BY HAND. IF MOTOR TURNS FREELY , YOU HAVE A START CAPACITOR PROBLEM.
FXIT
Nov 20, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
513 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
