Question about Apple PowerBook G4 Mac Notebook
Apple laptop won't turn on
I have a powerbook g4 and when I try to turn it on, I hear it work for a min, then the apple goes away and turns into a 'do not enter' sign and it stops making noise. How can I turn my laptop back on?
  • wolf918 Apr 20, 2009
    it act like my hard drive had it.
  • 40 Answers
Try to boot from the CD the computer shipped with.
Insert CD and restart the computer holding the "c" key
Your computer should boot.
If so run disk utility from the cd and repair the disk as well as permissions.
If this is successful your computer "should" be repaired. If it still has problems booting, Use your CD to perform a Archive and install which should keep all your personal settings and installed software intact.
Posted on Mar 01, 2009
Reset button on a powerbook g4
The Powerbook G4 power button functions like a reset button if you hold the power button in for a few seconds until the computer powers down.
  1. Hold the power button in for a few seconds (until you see the screen turn off/go black and hear the fans & hard drive stop spinning).
  2. Press the power button again to turn your computer on.
  3. If you have more trouble, you may need to boot in Safe Mode or "perform a Safe Boot":
    Press and hold down the "Shift" key immediately after you hear the start-up tone. Release the "Shift" key when the gray Apple icon appears on the screen.
May 02, 2014 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
When I power up my PowerBook G4, I hear the startup chime but the screen stays black, nothing happens!! Is my screen turned off or something?
It seems likely that the PMU (Power Management Unit) has failed and needs to be reset. There are comprehensive instructions on how to do this at the apple support site. Apple Support: PMU reset
Jan 27, 2011 | Apple PowerBook G4 Mac Notebook
My apple ibook g4 won.t turn on
cheak:
The power from AC
The power from Battery
Have you recently pulled apart your powerbook?
Dec 19, 2010 | Apple iBook G4 Mac Notebook
My apple powerbook display is just showing blank. I had turned the powerbook G4 and when I went to restart it the display would not show anything. I can hear the startup sound but nothing on the screen....
Just remove ur CMOS battery and harddisk connection from motherboard. And then try to restart it will give u a msg no boot device or OS found.. Now reboot and add the CMOS battery and harddisk on motherboard...
Apr 24, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Powerbook G4 12" no video
Try this courtesy of your manufacturer
  1. If the computer is on, turn it off.
  2. Reset the power manager by simultaneously pressing and then releasing Shift-Control-Option-Power on the keyboard. Do not press the fn (Function) key while using this combination of keystrokes.
  3. Wait 5 seconds.
  4. Press the Power button to restart the computer.
If that doesnt work lemme know
Feb 03, 2010 | Apple PowerBook G4 Mac Notebook
Canoot get Mac to boot up all the way
there is a hardware fault or full hdd ...
thi guys will help Micromen - London
Aug 30, 2009 | Apple Powerbook G4 17" 1.67 GHz SuperDrive...
My powerbook G4 will not startup... All that appears on the screen when I try to turn on my computer is a tiny folder with a question mark on it. The mouse pad is nonresponsive.
Computer cannot find operating system files. Start up from Install Disk or Utility disk and re-install system. Hold down C key while starting from disk.
Aug 11, 2009 | Apple PowerBook G4 Mac Notebook
PowerBook G4 won't eject cd by any means found on apple support
If you can hear that it's trying, it might be getting pinched while trying to eject, especially if something pressed down on the case at that spot. Try gently widening the opening with a flat head screwdriver while you are ejecting the CD. just put the driver in and twist a bit to widen the slot. Also, check to make sure that the fuzzy stuff that brushes off the disk when you insert it - and keeps out dust - hasn't been damaged. If it is partially missing, the missing part may be inside, keeping the CD from ejecting.
Apr 16, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Powerbook g4 will not turn on
pull the battery out, put it back in, plug the mac in, and hold down the power key till u hear the chimb
Feb 16, 2009 | Apple PowerBook G4 Mac Notebook
PowerBook g4 15" Screen Won't Display Anything!
your lcd probably just went out or the connecting cable just came loose(its in behind the lcd under the apple logo that lights up when you turn it on) if you open and close it frequently it will cause this
May 26, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Apple PowerBook G4 Mac Notebook Logo
877 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
