Question about SanDisk Open Box 1GB Cruzer Mini High-Speed USB 2.0 portable flash drive (SDCZ21024A10OB) Hard Drive
Water Damage to USB Flash Drive
HELP!
MY USB GOT WET!
My usb had been in water for what I think was less than 5min before I noticed that my key chain that had my usb on it was in water. When I noticed this I instantly pulled my usb out of the water and dried it straight away.
It was a good 20-30min before I got home to my computer and checked to see if it still worked. (Unfortunately at the time I didn't know that you are not suppose to connect a wet usb until it is fully dry) :(
When I did connect it, it was flashing for a few seconds then stopped. I pulled it out again and tried two more times (it flashed every time I did pull it out and connect it again). I gave up on my third attempt.
So now I want to know if I had defiinitely damaged my USB even more by connecting it after 30min of getting wet and unknowingly connecting it before allowing it to dry for a good 24hs?
It has only been less than 24hrs since it got wet. I have checked to see if the moisture I could see before inside the plastic casing has evaporated which it has. However I dont want to risk connecting it again untill another day or two.
My Question is:
How long must I allow for my USB to dry before I connect it again and at this stage have I ruined all chances of useing it again to retrieve Extremly Important Data??
If the USB is damaged, will a specialist be able to retrieve any data from it if the chip is removed from it's casing??
I would very much appreciate a quick response as this is very very important to me.
regards,
Mary
  • mgdirecto876 Mar 01, 2009
    Does it matter which type of paint thinner I use?
    What will this paint thinner do to my USB?
     I've looked inside my USB stick I cant see any traces of moisture any where inside. It's now 2days since my USB got wet. Will it be safe to try and see if it works first before I pull it apart and soak it in the thinner?
    Thank you.
    Mary.
  • mgdirecto876 Mar 03, 2009
    I did go to a computer store and asked if they could do anything for me, all they did was connect it to see if it did still worked and when it didn't register on their computer they offered to crack it open to see inside and attempt solving my problem. I didnt really trust that idea so I figured I'd ask fixya first.
    So regardless of the fact that I have connected my usb to my computer before allowing it to dry 24hrs, it will still be fine after I apply this procedure?
    Is the chance of this procedure working very high or very low?
Just keep the flash drive in the open dor about half an hour(do not expose to scorching heat and light of the son). The humid conditions dries up the moisture content. Take the flash drive when it is a little bit hot and connect to the PC. It functions even better than before.
Posted on Apr 09, 2010
    Problem Solver:
  • 11 Answers
The problem is very bad. In my openion there is only one solution with this problem. all you need to do is to remove its plastic casing and then put your USB into thinner ( A liquid that can be found at paint stores). Then let it get dry for 5 to 6 hours. And you are done. now connect it to your pc and get your data. Don't forget to rate the solution. Thanks!
Posted on Feb 28, 2009
  • pak_pyar Mar 02, 2009
    Dear Mary. The thinner that I use for such problems is labled Carbon Tetra Cleaner. and it is very effective for the water damage problems. This thinner will Remove the water effects out of your USB. and you'll be enjoying the use of USB just like a new one. Thanks for consulting before applying the procedure.
  • pak_pyar Mar 03, 2009
    Hi Mary. I think that they are also going to apply the same procedure of recovery to your flash drive. Its better to get it tried by them because in my opinion an expert can do it far better than a layman can. Hopefully you'll have good results.
  • 3 Answers
My Usb got into the washing machine for about an hour... i immediately damp it in a towel and dry it off in front of a fan but i dont know how long will it take for it to be able to remove/dry excess water inside and if ever it does, will it still work and am i going to recover all of my datas in the flash drive.. please help me! thanls.
Posted on Apr 15, 2011
  • Ali Naqvi Feb 11, 2013
    Like I said above.
I accidentally dropped my flashdrive into a shake like drink. I immediately got it out and rinsed it off. I then proceeded to 'thump' it on a towel to expel excess moisture. I am not sure if I got all of the shake out of it, but don't know if I should subject it to more water. What should I do? This drive contains a great deal of irreplaceable data.
Posted on Aug 19, 2010
    Put it a few inches away from a vent for about 45 minutes. then it works pretty good.
4 Suggested Answers
kgjsm397
  • 105 Answers
SOURCE: no communication
Is it displaying in device manager or it is not at all detecting. In that you may try with it some other system and same problem persist, there is possiblilty for damage. send it for warranty calim. Pen drive easily does not die. Check it in other system.
Any application or data is talking each other with computer and usb drive, then it gives warning try to close all application or any virus infection is there.
Posted on Apr 17, 2008
HITESH
  • 20 Answers
SOURCE: Cruzer micro 2.0GB
Some times it happens that Windows explore do not recognise the USB flash drives. There may be some causes: 1. Ckheck your flash drive & ensure that it was not burnt or have any physical damage. 2. Start the computer without flash drive and connect the flash drive to it. Noe ensure that your computer is not hanged.If your computer hanged than the flash drive is damaged. 3. if your computer is not hanged and not dectecting the drive,(fore windows) go to My computer, right click, properties, divice manager. In the device list see USB serial bus controllers. click + next to it to see the sub devices. 4. Now see that the computer has a listing for the flash drive. The listing may be as "Usb mass storage device", "Drive company name: etc. 5. If there is listing no listing for flash drive just disconnect it and see the device manager listing. some changes will occur or mouse pointer will show busy. Again reconnect the flash drive the same thing happens. 6. if your flash drive worked as in step 5 that means the the drive is ok and the compueter is ok. There is prblem with driver of flash drive that is currently installed. Please upgrade the driver from your flash drive manufacturer or it is ready to use device just unuinstall it from the device manager listing. Restart the computer. after restart connect the flash drive it will detect the drive. 7. if there is still a problem go to start run & type regedit and press enter to run registry editor. In Hkey_local_machine>software>Cruzer micro and delete it. restart the computer. 8. You wrote that if you connect it to USB port computer does not start. If above step 1 to 7 does not work means there is strong possibality of reading problem means the flash drive has errors on it and file system is damaged. This same thing happens with Cd drive with a cd having corroupt file system. i will prefer to take the flah drive to an local hardware expert or manufacturere.
Posted on Jul 24, 2007
Nandakishore
  • 304 Answers
SOURCE: very important pictures stored on my flash drive
If it was only casing then no problem happily you can plug into usb. If it is recognising the drive then your data is safe.
Thanks & Regrads
Nandu
Posted on Mar 10, 2009
My PNY 16 GB not being detected by computer
if you are referring to a usb drive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with post a reply
hope it helps
Jun 26, 2012 | PNY Attach? 16GB USB 2.0 Flash Drive
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have a JF V33 Transcend USB and I tryed JFSW and JFSW2 to try to reformat the USB but, they both cant read the USB I need help ASAP plzzz
There are two possible
1. Damage to partition table
2. Damage to firmware
To fix the Transcend flash drive, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, repair damaged partition table and damaged firmware.
JetFlash Online Recovery, you can download here Transcend Customer Support
How to use JetFlash Online Recovery, and analyze damage to flash drive, can you read in my blog. To find my blog, how:
Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". Analysis and how to use the JetFlash Online Recovery can you read in my blog.
Hopefully this information helps
Oct 05, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My pen drive is not working ofter fall in water
Most jump drives are not water proof. I would suspect that the the bored inside the jump drive is wet and or corroded.
You could try taking it apart and drying it but you are probably out of luck.
Thanks
Dustin
Jan 17, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My flash drive kingston 8 gb is write protected. how can i open my flash drive?
Hi.
Try these steps.
Carefully switch the write protect tab to Write enabled when inserting the flash in the usb "PC".
try using it. This happens mostly when you are inserting the usb, the tab is pushed to Protected mode without noticing.
If that doesnt work, i suggest you buy a new flash from different brand and less GB.
Good Luck
Nov 15, 2010 | Computers & Internet
Remove the write protection from the volume
this the great solution... try low level format..
1. plug ur usb flash
2. run Formatter v2.9.0.9.exe
3. follow the instruction and wait for the format (might take 5min for 4GB)
4. after complete, may the small volume (about 2MB...here the solution
5. plug your usb flash on other computer and format like regular (make sure u untick quick format) and click on "restore device defaults" then click format
6. now your usb flash drive was like a new one
>>>>DOWNLOAD FORMATTER CLICK HERE <<<<
Jul 13, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Remove write protection from transcent pen drive
Jun 24, 2010 | Electronics - Others
Sir, I have TDK 4 GB Pendrive. I was formated some
Dec 14, 2009 | Vacuums
How can I open my sandisk cruzer? It got wet and I'm trying to dry it. And whats the best way to retrieve all my files, it has all my assignments (I have not back up my recent files). Thank you. AK
this is a tough one, if it just got wet you can use isopropyl alcohol and a q-tip and dab the circuits with it, alcohol soaks up water faster than any towel and evaporates when it dries. good luck!!
Nov 03, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Computers & Internet Logo
5,433 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
