Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
TV not responding to remotes
Sony Trinitron model number KV-32FS10.
Recently our television has not been responding well to remotes. Rather, it has not been responding to remotes, period. I initially thought it was the batteries in one of the remotes and proceeded to change them, and when this did nothing to fix the problem I decided to try reprogramming our Comcast universal remote in an attempt to fix the problem.
However, all attempts have fixed nothing. I looked up numerous Sony codes, and went so far as to do the ''search yourself'' method, all to no avail. Something that I've noticed has caused similar issues in the past was if something was on top of the television (anything electronic) messing with the receiver device that responds to remotes. I'm not sure what to call it as I don't know televisions well. Usually moving whatever was blocking the signal was the solution.
This time there is nothing blocking it! As far as I can tell, the remotes were all working a week ago, so I'm at a loss as to what changed between that time and now to cause this.
So please, if anyone has experienced this personally or understands what is causing it, I'd very much appreciate your wisdom.
  • erinja Mar 01, 2009
    We have a remote for the TV but also a universal remote. I know for a fact neither of them has been dropped and we have no digital cameras in the area to test whatever it is you mentioned. My whole point of addressing the TV codes was to mention that the universal remote is also not working. I'm almost 100% certain it isn't the remotes that are the problem, but rather the television itself. The universal remote works just fine with the cable box and whatever else it's programmed to control.
    Thanks for your input, however.
  • robson_lee Mar 17, 2009
    my tv just does not respond when using the remote or by the buttons on the tv then the screen goes blank but has sound
    Problem Solver:
  • 18 Answers
I ASSUME IT'S JUST THE REMOTE YOU'RE SPEAKING OF- FIRST, IF YOU HAVE A DIGITAL CAMERA, OR CAMERA PHONE, AIM IT AT THE INFRA-RED LED'S ON THE FRONT OF THE REMOTE, AND PRESS BUTTONS [LIKE POWER OR CHANNEL] - THE CCD'S USED IN DIGITAL CAMERAS ARE VERY SENSITIVE TO IR, AND YOU SHOULD SEE A WHITE LIGHT [IMAGE] OF THE LED'S, EITHER STEADY, MOMENTARALLY, OR PULSING. IF THE REMOTE HAS BEEN DROPPED, THERE IS A CCHANCE THE CRYSTAL CONTROLLING THE FREQUENCY HAS BEEN DAMAGED. TRY A UNIVERSAL REMOTE, ALTHOUGH OFTEN YOU MAY LOOSE SOME FUNCTIONS, OR THE BUTTONS REACT DIFFERENTLY THAN LABELED. SELDOMLY, BUT IT DOES HAPPEN, THE IR RECEIVER SECTION OF THE SET ITSELF CAN FAIL. THE IR RECEIVER [LOOKS LIKE A DARK LED] CAN FAIL, AND THEY'RE COMMERCIALLY AVAILABLE AT RADIO SHACK
Posted on Feb 28, 2009
  • david small
    david small Mar 04, 2009
    ok, with the detail you have just provided, it does sound like it could be the tv itself. [i assume you have tried a code search- the feature where you scroll through by pressing usually the power button on the universal until the set responds], with no sucess. also, make certain the lens on the st [usually a red piece of plastic] is clean and unobstructed. one inexpensive and commercially available [even atradio shack] is an infra-red receiver 'led' - i use the quotes because i don't recall if they actually label it as an led, but it looks just like a dark led. beyond that, if the set is new enough to warrant the time and effort, you might want to obtain service notes on the set, and one other thing- google your model, and even specify your problem, and don't be surprised if you find that it is not an uncommon problem, and there will be a list of the most common failed components. anyway, in my experience, the circuit for the remote function has relatively few components, if you have a voltmeter, check across the electrolytic capacitors in the ac range, and the reading should be zero. the only other thing i can think of would be one of the processor chips, and that would most likely be an involved repair, and parts availability is not very likely. good luck
WHAT IS THE MODEL NUMBER OF THE REMOTE FOR SONY TRINITRON 29 WEGA KV-SW29M50
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 09, 2014 | Sony FD Trinitron WEGA KV-SW29M50 29" TV
I have a SONY TRINITRON TV Model no. KV-XR29M80. Unfortunately, the Remote Control supplied with the original TV set is not working. How can I obtain a replacement Remote Control for the set ? I live in...
Hello
The original remote control of your TV is available at Ebay. It is priced $8.99. Just order them with the exact model number of your TV and order for a remote control of the set. They will get it at your doorstep. OK.
May 29, 2011 | Sony FD Trinitron WEGA KV-21CL10 21" TV
My remotecontrole for the sony trinitron KV-32FX60B is stolen how of where can i buy it
Hello
You can just buy it from any Sony authorised service centers, or they will give you information about its availability. You just go to the nearest Sony service center for further information. Give them your TV sets model number, ot the remote model number. They can find the right one and give it to you. OK.
Dec 15, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron kv-32fs10 component color problem
check the av in puts of your tv, this sounds that your av jack has a loose joint on the connection under.
May 24, 2010 | Sony KV-32FS10 32" TV
My tv has sound but no picture. The screen is greenish in color.
SONY TRINITRON TV 32 INCH MOD# KV-32FS10 SER# 9006800 PICTURE INTERMITTENTLY BLANKS OUT AND COME RIGHT BACK NEVER LOOSE SOUND.
Feb 07, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a sony 32'' I think. model # KV-32FS10, serial #8047927, made Jan 2000. During a move, the tv was dropped and now when you press the power, your hear the click, the red click light flashes...
It sounds like that in the drop you may have cracked the main PCB. The PCB's usually crack around the heaviest part of the PCB. Probably around the flyback transformer.
Oct 15, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
About Sony Trinitron KV-28LS36B
there are two possible defects in your circuit.
However, if the led blinks for about 10 times your tuner is defective 90%.
You will need a scope to check or you will need to take it in for service.
Oct 13, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony television will not respond to remote.
battery in remote.
Many times I will 'reseat' the batteries in a remote & then it will work for a while again.
Jul 27, 2008 | Sony FD Trinitron WEGA KV-20FV300 20" TV
SONY TRINITRON MODELO KV-21XME
If its a digital television and has a remoten sensor just buy a universal remote and configure it to your TV.
If it responds then you can search and store the channels you missing.
Thanks
May 07, 2008 | Televison & Video
Setting tv to channel 3
When the led blinks twice it is telling you that the remote accepts the code, but that does not mean the tv accepts the code. If the tv does not power on after programming the new code then you must try the next code in the sequence, until you find one that powers on or off the tv.
Aug 25, 2007 | Radio Shack (15-2147) Remote Control
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
279 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
