Question about Texas Instruments TI-83 Plus Calculator
TI-84 problems when I go to add two numbers wether I subtract or multiply...etc.. I hit the enter sign to find my answers. well usually if you want the problem to keep going you can just add more numbers toget another answer when I do this it doesnt work it just skips a line and shows a one  somebody help me PLEASE  LET ME KNOW IF YOU CAN FIX IT THANKS
Ok, if your trying to do something like this: 2+2=4 then make it continue adding by 2's (6,8,10...)
What you do is after you type 2+2 and press enter, you need to press the "+" and u should see it show this "ans+" then type 2. Then this should continue adding by 2's. Hope this helped.
Posted on Mar 02, 2009
How to solve franctions
Multiplying Fractions:
  1. Make sure you're working with two fractions.
  2. Multiply numerator x numerator, then multiply denominator x denominator.
Dividing Fractions:
  2. Flip the second fraction upside down.
  3. Change the division sign into a multiplication sign.
  4. Multiply top x top and bottom x bottom.
Converting Mixed Numbers into Improper Fractions:
  1. Convert mixed numbers into improper fractions.
  2. Take the whole (non-fraction) number and multiply it by the denominator.
  3. Add that answer to the numerator.
  4. Put that amount over the original denominator and you will have an improper fraction.
Method for Adding and Subtracting Fractions:
  1. Find the lowest common denominator (bottom number). For both adding and subtracting fractions, you'll start with the same process.
  2. Multiply fractions to match the lowest common denominator.
  3. Add or subtract the two numerators (top number) but NOT the denominators.
Mar 07, 2017 | Homework
I have a TI-84 and when i put a negative number it appears Ans before how can change that?
Use the (-) key to the right of the decimal point key when entering a negative number. The - key to the right of the 6 key is for subtracting something from something else. In order to subtract from something, if you don't specify anything then the calculator uses the previous answer as designated by "Ans." The same thing happens with the + key for example, because it adds something to something else.
Feb 01, 2014 | Texas Instruments TI-84 Plus Silver...
Answer always appearing
Minus and change-sign are two completely different things. Minus is used to subtract one number from another. When you press minus when the input line is empty, your telling the calculator to subtract. The only way it can subtract the number you're about to put in is to subtract it from something else, and that something else is the previous answer, hence the "Ans."
If you want to input a negative number, use the change-sign key. If you want to subtract one number from another number, use the minus key.
Try pressing the plus key when the input line is empty. You'll get Ans+ in this case as well, The same with multiply and divide, among others, and for the same reason.
Sep 23, 2013 | Texas Instruments TI-84 Plus Calculator
Can not reset calculator. Keep getting + sign when press enter
If the TI-84 does not function even though you are sure that the
batteries are fresh, you can try manually resetting it by following steps:
1. Remove all of the AAA batteries from the graphing handheld
2. Press and hold the ON key for ten seconds
3. Replace the batteries
4. Turn on the unit
When you reset your graphing handheld, the contrast sometimes
changes. If the screen is faded or blank, adjust the contrast by
pressing 2nd and releasing up-arrow or down-arrow keys.
Feb 24, 2013 | Texas Instruments TI-84 Plus Calculator
What is the formula to find the percent between two numbers. example: nuts cost .233 last year and this year nuts increased to .332 what is the percentage increase.
Divide .332 by .233, multiply by 100, then subtract 100.
Alternatively, since the increase in price was .099, divide .099 by .233 then multiply by 100.
Aug 10, 2011 | Texas Instruments TI-84 Plus Calculator
How do input subscripts into a program with a TI-84 Plus? Like Y(sub 1)=y
Use the square brackets ("[" and "]"). They're the shifted functions of the multiply and subtract keys. For Y(sub 1) enter it as "Y[1]".
May 15, 2011 | Texas Instruments TI-84 Plus Calculator
How do i multiply radicals on my ti-84 plus silver edition? jgammell@woh.rr.com thanks
To input radical numbers, you need to press the 2nd key and then the x^2 which has the square root symbol in blue above it. Input the numbers of the first radical. Hit the ) button. Then press the multiplication button. Hit the radical button again. Input the numbers of the second radical. Press the ) button again and press enter.
Feb 10, 2011 | Texas Instruments TI-84 Plus Silver...
How do i put brackets in a problem
Use the parenthesis above the 8 and 9 keys. Don't use the curly braces on those shifted keys (those are for lists) nor the square brackets on the multiply and subract keys (those are for arrays).
Sep 16, 2010 | Texas Instruments TI-84 Plus Calculator
How do i make subtraction, additions and divisions using excell
Put the figure which you have to multiply in cell A1, Put the figure in cell A2 by which you have to multiply by, type =A1*A2 in cell A3. You will get the right answer.
You may substract, multiply or add by this method by appropriate mark in cell A3 in between A1 and A2.
npbhoge@rediff.com
Jul 29, 2008 | Microsoft Excel for PC
HELP WITH SIMPLE ADDING, SUBRACTING AND MULTIPLYING
I love that old, little calculator, the TI-1795+ (not the new one, SV).
Does anyone know where to get any more of these. I'd buy a few,
but they are probably out of production. I've had my three for years
and years and years. They still work fine.
Jul 27, 2008 | Texas Instruments TI-1795 SV Calculator
Texas Instruments TI-83 Plus Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
