Question about Canon XL1E Mini DV Digital Camcorder
Red flashing indicator in viewfinder of my Canon XL1E
Hi, I have a flashing red warning light in the viewfinder, there is a horizontal line intersected by an angled vertical line in the center of the viewfinder. I don't what it is or what it means. The camera functions seem to work, the tape loads and unloads . . any ideas appreciated.
Hi . .  I downloaded the manual . . found I needed to replace the 3 volt lithium battery located on the underside of the hand grip for the zoom. Changed the battery . . . No red flashing icon in the viewfinder.
Cheers
Steve
Posted on Feb 28, 2009
When I try to take a pic, the camera beeps and a red light flashes.
Hi. Based on your brief description of the problem I would think that the camera is failing to focus and the flashing red light in the viewfinder is the auto-focus indicator, make sure that the red auto-focus indicator is positioned in the centre of the viewfinder initially until you have experience of using it (to do this consult your camera manual) focus on a subject that has some contrast ie a red brick wall, grass or pebbles on a beach.
Apr 15, 2014 | Canon EOS 1100D / Rebel T3 Digital Camera
Why are green horizontal lines are appearing, too much yellow colour and green light blinking red?
These horizontal lines are vertical flyback lines and would indicate
one or more of the tubes cathode drive circuits are defective.
As the picture is predominantly yellow this would indicate excessive drive to red and green guns. Check the red and green video output stages especialy any clamping diodes.regards from Vintie
Sep 19, 2013 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Power indicator /red/ and warning led/red/ are lighting after ea 15 sec. a lamp never start and fans goes in OFF mode. I checked power supply lines S5V,S-5V,S16V on the Main Board . I checked unit lamp...
If power indicator light red and warning indicator red flashing than according to user manual :-
The projector has been cooled down enough and the temperature returns to normal. When turning ON the projector the WARNING indicator stops flashing. CHECK AND CLEAN THE AIR FILTER.
Experience:- 1. if the temperature is very low than temperature sensor maybe misbehave.
2. If anyone fan not working
so please you check fans.
(If lamp or lamp ballast unit faulty than after a time period the lamp indicator light ON not a warning indicator. I experience many times if any fan in projector are broken or jamed the temperature light if present otherwise warning light ON or flashing)
Jan 20, 2011 | Sanyo PLV-Z4 Multimedia Projectors
A red icon flashing on the screen.
It's the warning to replace the back up batter which is housed behind the main battery.
May 28, 2009 | Canon MV830 Mini DV Digital Camcorder
Red crossed horizontal icon flashes on screen
It's the warning to replace the backup battery which is housed behind the main battery.
Flashing Red Light....
The flashing "boat" in the middle of the viewfinder just means the button battery is dead. Camera will still work. It's the little pull-out light grey plastic thing that's next to the heel of your right hand when you're using the camera normally. You need a CR2025 cell.
Jan 27, 2009 | Canon XL1S Mini DV Digital Camcorder
1991 CANON CANOVISION E100 / E110 Red light flashing after 2 minutes, not condensation, battery well charged. No picture appears in viewfinder when red light is OK & not flashing. HELP!!!
ive gt to use it recently and it woot the canovision E100,hardly been used i went to use it and it wouldnt come on , there is a red light
Aug 19, 2008 | Canon Cameras
The image is getting blurred
Hi
The camera may have moved when the picture was taken. Try steadily squeezing the button intead of a quick press.
2.Try using a tripod, this could fix the blurred images.
3. faster shutter speed will be needed if you need to hold the camera, and cannot use a tripod.
4. Main reason for the lines could be that the subject is to bright.
A vertical bar of light(red, purple) appears on the LCD monitor/ in the viewfinder This is a normal occurrence in devices containing CCDs (Digital Cameras) and does not mean a malfunction. (This red bar of light will not be recorded when shooting still photos, but it will be recorded when shooting
movies.)
Solution to the last point would be to try and switch of the flash if it is in use. Turn the ISO setting (50, 100, 200) to a lower one as well.
Hope that helps.
May 26, 2008 | Canon PowerShot Pro1 Digital Camera
Screen Line
I don't think that this is a defect. I own an A60 and there is an horizontal line running through my viewfinder. I use my LCD screen more often then my viewfinder, so I've never seen the blur. However I'm pretty sure that your camera is fine.
Aug 31, 2005 | Canon PowerShot A60 Digital Camera
Canon XL1E Mini DV Digital Camcorder Logo
382 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Sheryl Bahr
Sheryl Bahr
Chris Phillips
Level 1 Expert
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
