Question about Sony Playstation 3 (PS3) Console
Solid red light, flashes green when i turn it on then it dies.
Ok after i turn on my pse from the switch in the back i get a solid red light, this is normal but when i push the power button it flashes green then it turns off completely . AFter i have to turn off the switch in the back then back on just to get the solid red light again i turn it on again same thing happens.
  • 2,653 Answers
Pretty much the only thing worth trying is starting the PS3 without the hard drive.
If it doesn't work it's more than likely a GPU problem that only Sony can fix.
Either way check out my guide here for tips and details.
Please feel free to email me any other questions and please don't forget to rate!
Posted on Feb 28, 2009
Cricut mini flashing red light
1-Open Cricut Craft Room with circuit on and flashing green/red
2-Hold power & feed button together until both are solid green
3-You'll be prompted to update firmware
4-Press & hold two buttons again (keep holding)
5-initiate firmware update
6-Let sequence go until 99% may hear a sequence of beeping, don't be alarmed
7-Release buttons
8-You'll be prompted to restart your machine
9-Unplug all plugs from Cricut
10-Wait 30 seconds
11-Plug in both cords
12-Power on Cricut
13-Light should be solid green
14-Press OK on Craftroom prompt on computer
Jan 03, 2014 | Provo Craft Cricut Disney Font Cartridge
Runco flat panel tv displays solid green then blinking red light. What doe this mean?
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link
Nov 14, 2013 | Runco Televison & Video
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
When comp pluged in just a green flashing light
If you are sure that the 110 volt power is coming into the computer then the most likely problem is that th epower supply died. Obtain a new one of the same or larger wattagge as the one you are replacing . It does nto have to come from the manufacture of the computer.
Nov 26, 2008 | Compaq Presario SR1000T (568657) PC...
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Will not flash red/green
This means Battery is low to charge the capacitor.
I suggest you test this with unused new Duracell.
Oct 06, 2008 | Vivitar 285HV Flash
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Beep 3 times turns green yellow then blinks red then turns to a solid red wont turn on wont give me game
3 Solid Red lights usually means that a cable is unplugged. Check all cables (unplug and plug back in) may need to replace power cable if issue is still ocurring. If it is 3 Flashing red lights, this is known as the Red Rings of Death, i.e. your XBOX is dead and needs to be completely replaced.
Jun 16, 2008 | Video Game Consoles & Games
Powering on
OK ... after a lot of trial and error, I got mine to work. I think it may be a really low charge or something. I had to press the power button until it was completely dark ... no flashing faint green or any colors. Then when I plugged it in, I got a solid red and left it for awhile. Then when I pressed the power button I got yellow, red and green ... the computer recognized it and then got a solid yellow.
Before when I had it plugged in, I'd get a lot of red random flashing ... and it just didn't seem to charge at all ... even after a full day.
I think the issue was that it was in this "flashing state (red when connected, very faint green when disconnected)" It wasn't easy to get it to turn off completely. Most of the presses of the power button didn't change the state at all. But if I got it just right, I could see the faint green light go off. That's when I plugged it in and got a solid red light, and eventually a good charge.
Hope this works for some others.
May 23, 2008 | LeapFrog FLY Fusion Pentop Computer
Sony Playstation 3 (PS3) Console Logo
111 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
