Question about Samsung SCX-4100 All-In-One Laser Printer
The gears on my samsung scx-4100 laser printer are turning but the gears turning the roller in the cartridge will not turn. Are these gears supposed to turn freely when the cartridge is out of the machine or is there a contact or release that is supposed to free the roller to turn when inserted? The gears just grind when I insert the cartridge.
  • maximous01 Mar 14, 2009
    I have the same problem, I've and a removed the Fuser Assembly and noted there is some worn on a plastic case by the gear side, actually the gear itselft was grinding it, some how the turning force was pushing the fuser sleeve to right side disengaging the fuser gear with drive gear and wearing the drive gear teeth (Fuser gear seems to be harder). But can't locate the drive gear for replacement. Any ideas?
I have the same problem, I've and a removed the Fuser Assembly and noted there is some worn on a plastic case by the gear side, actually the gear itselft was grinding it, some how the turning force was pushing the fuser sleeve to right side disengaging the fuser gear from the drive gear causing to weare out the drive gear teeth (it seems the the fuser gear is harder). Neet to change the drive gear.
Posted on Mar 14, 2009
    Sergeant:
  • 199 Answers
I think your cartridge is jam, check or replace another cartridge in the printer
Posted on Feb 28, 2009
Samsung Printer SCX-4100 LSU Error
Laser Scanner Unit or LSU is what writes to the surface of the drum. The glass above the cartridge in the machine may be dirty. The mirror motor in the LSU could be bad or needs to be cleaned to spin better. The Laser diode may be faulty.
This is not a user-serviceable issue. You will need to contact Samsung for service. You can do it online via Samsung website or contact the vendor to see who will they appoint to service the printer to, especially if it is still under warranty.
Jan 27, 2011 | Samsung SCX-4100 All-In-One Laser Printer
I have Samsung scx 4100 Printer. I want to know how to maintain it and charge its cartridge. I want to know about its construction.
Excellent (all in one) printer.
We have 4 in our Texas/Louisiana branches on the network! I can connect to and maintain all of them from my desk.
Samsung's website has a lot of really good information that I'm sure you will appereciate:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=SCX-4100#
Oct 11, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Samsung SCX-4100 Jam 1 or no Cart
Put cartridge inside correctly and press lower inside again.
if not solved
there are loose catridge connection, check or replace cartridge (the connection at right side in the cartridge)
Feb 26, 2009 | Samsung SCX-4100 All-In-One Laser Printer
My SCX-4100 prints a blotchy stripe down the middle of each page
check the lsu out mirror (top of the cartridge in the machine.) if it is clean go for a cartridge or pray god to shoe the way.
Jan 14, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Printing problem
quality - cartridge,charge roller,
4-5 papers - pickup presure pad, clean / replace.
long time to charge - fixing unit.- thermister.
Oct 22, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Samsung scx 4100 cleaning the roller
one way to clean those rollers is to take the printer apart. this would provide you with enough room to fix it and clean it.
however, if the suggestion of taking it apart does not sound good, you can still actually have that cleaned while it is turned on. as what you mentioned, you are asking how would it turn while cleaning it. i suggest that you try using the qtip and tune the printer to turned on. so that you can actually see what your doing with the roller.
Jun 03, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Roller Means Paper picker or you are talking about drum unit or fuser let me know.
Mar 25, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Printer prints lightly after changing a cartridge
i guess you have problem with the poor quality ink.
faced same problem.
i re-filled with best ink in the market and the problem was gone..
i hope that helps
Mar 21, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Samsung SCX-4100 All-In-One Laser Printer Logo
190 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
