Question about Kodak ESP 5 Printer
Kodak esp 5 won't scan to computer
I can make a copy of a document with the scanner but can not scan documents into the computer. Whenever I try the LCD display just says scanning but does nothing. I have printed plenty of pages and pictures from the computer.
Thanks.....
  • 10 more comments
  • Anonymous Mar 04, 2009
    My esp 5 wont scan to the computer either and ive only had it two weeks!
  • Anonymous Mar 06, 2009
    I can print, copy but not scan. I've tried removing the drivers and re-installing but that doesn't seem to help...is everyone else running XP or Vista?
  • ammibrooks Mar 10, 2009
    My 5300 Kodak printer doesn't seem to scan to my computer. Do i need a memory card to do that?
  • Anonymous Mar 20, 2009
    I have the same problem. I push the scan button and then start as prompted and nothing happens.
  • utleyschick Apr 08, 2009
    This printer is a peice of ****.
    DONT BUY ONE!
    WILL NOT SCAN! and it's extremely loud.
    When it decides to print, it print 1/2 of a page.
    Not worth the $$!
  • Anonymous May 13, 2009
    Also not working here. Frustrating. D:
  • Anonymous May 17, 2009
    Please help if someone has the answer. I rather like this printer and would hate to deal with this for any longer.
  • Mike Feb 13, 2012
    Same here..."Scan Failed". I simply went to "Windows Scan and Fax" program and my 3250 worked like a champ. Forget trying to use the Kodak Control Panel for anything but copying doc's or photos.
  • Mike Aug 13, 2012
    From the OP; techisbest's response was my solution too. Just couldn't print from the printer, did it through Kodak AiO with no trouble.
  • gabbysgirl19
    gabbysgirl19 Nov 26, 2012
    When I try to scan it will go through the process, but when it is done and the picture tries to pop up the window will close on my computer what is wrong. Please help
  • Anonymous Mar 19, 2014
    Need to scan A4 document on a Kodak ESP 7
  • Anonymous Mar 28, 2014
    My Kodak ESP2170 is having a scanning problem. It was scanning fine then the pages started getting darker and the pages are turning out black. How do I fix this?
Here is the solution I found on the Kodak ESP 5 Support Center web page. Hope it helps or else maybe just visit the web page and browse it to see if you can find the solution to your specific problem.
Question : How do I scan from my all-in-one printer using MICROSOFT WINDOWS Imaging Acquisition (WIA) Drivers on a computer running WINDOWS VISTA Operating System? Answer : For computers running WINDOWS VISTA Operating System:
  1. Click Start > Programs/All Programs, and select Windows Photo Gallery.
  2. Click Scan at the bottom of the Windows Photo Gallery window, then click New Scan at the top of the window.
  3. Select KODAK ???? AiO (where ???? is the model number) from the Select Device window, then click OK.
  4. Click Preview and make whatever adjustments needed to achieve the desired scan.
  5. When you have made the desired adjustments, click Scan.
    During scanning, the progress is displayed.
    When the scan is complete, the file is displayed in the Windows Fax and Scan window, along with a preview of the file.
  6. Click Save as... to save the file, or click the Print icon to print the file from the Windows Fax and Scan application.
Posted on Jun 08, 2009
  • Art Main
    Art Main Dec 30, 2014
    While this answer is a possible work-around solution, it does not answer the OP's question. I can scan just fine using the Kodak software (or your solution to use Windows Photo Gallery instead), but what I can't fo (and what the OP asked about) is to scan using the LCD control panel on the printer itself. Print and copying work just fine, but choosing Scan just hangs at "Scanning..." until you shut the printer off. I wish I had the solution to that part.
I had this problem; printer would copy okay but not scan, just start and then stop.
The way I got it working (apart from upgrading all software and drivers) was to connect printer to a USB2 port (I connected directly to the PC rather than a hub). I did have it attached to a USB1 hub and this just didn't seem to work for scanning. Something to try!
Posted on May 30, 2010
  • tjacobs944 Sep 29, 2010
    I spent forty five minutes online with Kodak tech support, made about five changes to the computer default settings, then spent a half hour down loading and reinstalling drivers and software. Still wouldn't scan to the computer.
    Changed the USB connection from the hub to the computer and it works perfectly.
    Thanks dkharvey312
  • Craig McCloughlin Jan 31, 2012
    Excellent! Simple but effective. Well done! Thank you very much.
I had the same problem and found this page (obviously). When none of the suggestions worked for me, I decided to go into the printer and devices screen, right click on my Kodak printer, then go to troubleshoot. The computer fixed the issue for me and it started scanning again. I have win 7 and it's a ESP C310 AIO. :)
Posted on Feb 01, 2012
I had the same problem using the printer's buttons. I used the Kodak AiO Home Center software that came with the printer without any problems.
Hard to believe Kodak let the printer get out the door like that.
Posted on Aug 02, 2009
  • AskAnna Jun 28, 2011
    I think it may have to do with a conflict in computer add-ons. It sometimes takes up to 5 mins before it finishes processing the scanning and the Save As PDF window then pops up. Temporarily disabling some add-ons may help. Sometimes it also seems to help to restart the printer. It's important that you are connected on the same wireless/internet connection as the printer is set up to. I have 2 routers set up at my home and I always have to remember to switch to the same connection that the printer is set up to to print or scan.
  • 4 Answers
I had the same problem after windows 8.1 update, try reducing the scan resolution, it worked for me.
Posted on Oct 27, 2013
I have a Kodak ESP5210. Its an all-in-one with the printer, copier, and scanner. I can't get my scanner to work. I put a picture on it and hit "Start" and all it did was keep saying scanning. It...
Make sure any other scanners are disconnected from your computer. I had a problem with the scanner in the Kodak ESP 7 AIO printer. Kodak advised me to disconnect my other scanner. After I disconnected my Canon scanner, I was able to use the Kodak ESP 7 scanner.
MWR
Feb 28, 2011 | Kodak ESP 5 Printer
I just bought A Kodak esp 3250 series AIO printer. I can print from computer, copy and all that but whenever I try to scan to computer or even preview scan I get a error saying :An error occurred while...
Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
2. Type %windir%, then click OK.
3. Double-click twain_32.
4. Right-click Kodak, then select Delete.
5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
6. Double-click aioscannr.msi, then follow the instructions to remove it.
7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
8. Open Home Center Software:
a. Select Scan Documents and Pictures.
b. Scan a document.
Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
I hope this helps.
Jan 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a Kodak AIO 5 printer and Windows 7. I
This is easily accomplished using Kodak AIO Home Center v5.3:
Scanning documents from Home Center
1 On the main screen, click Scan Documents and Pictures.
2 Place your original document face down on the scanner glass.
3 Select Document.
4 Select the type of document you are scanning.
5 Select a Resolution for your scan from the drop-down list.
6 Select Perfect Page Technology to automatically correct imperfections in the scan.
7 Select Next.
8 On the Edit screen, edit each image as needed.
9 Click Next.
10 Select Save to File, then select Save As (pdf or rtf), Then Save.
11 Select Done to return to the main menu.
Jul 21, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
When scanning a document why do I get a green line running vertially through the document?
Possible hardware problem with the scanner.
Do the ff:
  • copy of a picture or document
  • scan of the same picture or document
If the line is still existing call the kodak technical support; Your printer is in need of repair
the number is 1800 421 6699
Aug 20, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
When i press scan the display shows 'scanning' nothing happens - the printer works and is connected... kodak esp 5
connect ur printer with ur computer thru a usb cable and then try to scan a document from computer using home center software. u will be able to scan the document or picture.
Jul 28, 2009 | Kodak ESP 5 Printer
My kodak scanner won't scan but will print pictures
connect ur printer to ur computer and then try to scan any document or plug in any memory card and then press scan .it will ask u to save the file after scanning, save it on computer. ur issue will be resolved
Jul 20, 2009 | Kodak ESP 5 Printer
Scanner will not work have just purchased the printer and have now got the print working but cannot get scanner working ?
scanning anything will ask for a place to save the document install kodak home center from cd or from net- www.kodak.com/go/downloads connect ur printer and computer with usb 2.0 open home center on computer
and try to scan a document by placing on scanner glass on the printer will be able to scan if not, call kodak 1800 419 1909 for further directions
Jul 08, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Vertical black line when copy with Koda ESP 3
Some dust particle or something might have been stuck on the scanner. Try cleaning the scanning glass
May 19, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
My kodak esp3 will not scan it prints and copies.
I had the same problem and I got it to work. I have Windows Vista and Microsoft Office 2007 on my computer. Here's what I did...
Go to "Start" then "Control Panel".
-Click on "Programs and Features".
-Scroll down to Microsoft Office Home and Student 2007 - click on that and then click on the "Change" link above.
-A box will pop up, click on "Add or Remove Features" and then click "Continue".
-Click on the "+" next to "Office Tools"
-Click on the "+" next to "Microsoft Office Document Imaging"
-Click on the down arrow next to "Scanning, OCR and Indexing..."
-Then, click on "Run from my Computer"
-Next click on "Continue" at the bottom of the dialogue box and your configuration process should begin
Once completed go to the start menu and type in "Scan" into the search box. Go to "Microsoft Office Document Scanning" Once there, plug your scanner into you computer, chose what color you want your scan to be in, and click on the picture of the scanner to the right. To make my scans clear, I had to click on "Scanner..." and chose KODAK ESP AiO as my scanner even though I have a KODAK ESP-3 printer/scanner.
I hope these instructions weren't too confusing and I hope this helps some of you out! My scanner was causing me a lot of frustration for a while!
May 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
KODAK ESP-3 AiO Will Not Scan On Vista 64 Bit Ulitmate
Feb 16, 2009 | Office Equipment & Supplies
Kodak ESP 5 Printer Logo
13,933 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Sajid Najmi
Sajid Najmi
Level 1 Expert
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
