Question about Intel Computers & Internet
Problem with pc
Pls help me.... m using intel 845 motherboard, 512 ram with p4 processor . my system runs for a while and then automatically slows down and then once again starts (clearly identified as my processor fan slows down)..... not completly shut down and then restart,,,,,,,,no display in my monitor....i changed the ram (sd)..till m getting that problem...even smps is working fine....i want to know whether the problem is in motherboard or in ram slot...........or in processor
  • 129 Answers
You probably need to check the cooling fan setup ( some motherboards give the control on the task manager or a sperate software to control it) This seems to be a problem of overheating which might have started after the installation of new ram.
Posted on Feb 28, 2009
Mother board update
Well that can depend on a number of factors like how much you are willing to pay.
Logon to newegg.com or zipzoomfly.com and search through their motherboards for ones that match your processor. pick one that has the features you want. Im partial to Asus boards so id find one of those that would match that processor. They list which processors will work with them so it really is pretty easy. zipzoom is my personal fav.
Mar 09, 2010 | Intel Desktop Board D845BGL Motherboard
Swaping hdd 845 motherboard to 915 motherboard
its always safe to have data backed up
u can swap the HDD
but bootup with the Win2K CD in the Drive and after the files are loaded at the first screen select install then after it detects the OS select R (Repair) and this will reinstall the operating system files and then you can use the system as before though u may have to install the device drivers and motherboard drivers
for any other clarifications u can place a comment in the same question or u can mail me at mail2pvs@gmail.com
Jul 30, 2009 | Intel Pentium 4, 3.0 GHz 530...
Intel 845 gvsr memory problems
Sounds like the RAM is not compatible. Try another 1 GB chip from same manufacturer & see if that helps.
Dec 20, 2008 | Computers & Internet
Vista compatiable
intel doesnt list any vista drivers for that motherboard on there site so you might run into problems with the intergraded devices such as the ethernet,audio,chipset, & any intergraded video
You might be able to use the xp drivers but if theres problems it wouldnt be supported by intel
Nov 26, 2008 | Intel D101GGC Motherboard
Ram support
Any 845 intel board should support 512 ram.may be the one u have brought is defective.plz be specific and more detailed quires when u post next time.
May 10, 2008 | Intel Motherboard
Compatilblity with 845G mother board
try update the system bios because there were motherboards that had compatibility problems, this board is not a new one so it should work with your processor
Feb 07, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Ram support for intel 845 motherboard
Ok. So you've defined the Intel 845 chipset on your motherboard.
But is it the 845 or 845G chipset?
Click HERE for the specifications of the Intel 845 chipset.
Click HERE for the specifications of the Intel 845G chipset.
Peepnklown is only HALF right.
The Intel 845 chipset does NOT support PC133 memory.
The Intel 845G chipset DOES support both DDR and PC133 memory.
The difference?
The 845 has a single memory controller for DDR memory.
The 845G has two memory controllers. One for DDR and one for PC133.
Although you're going to need DDR memory as it is FASTER and less expensive than the older PC133 memory. (Believe it or not.)
I do NOT recommend using Corsair's ValuSelect memory on this chipset. I have two boards with the 845G chipset and that type of memory does not allow the board to boot.
These boards typically come with DDR266 (PC2100) modules installed.
I would go ahead and buy DDR333 (PC2700) memory for it. The board you have may not utilize the full speed of that memory, but will use tighter memory timings if the RAM is clocked down by the board. This will result in better efficiency of memory use by the processor.
Think of it as giving the motherboard "breathing room".
I could recommend PNY memory for the most basic compatability. (Not that they manufacture their own RAM modules...) Or perhaps Nanya, Infineon or Microtek.
Look for memory compatability lists for your particular motherboard module online. You could also use PNY's memory configurator on their website.
Click HERE for PNY's memory configurator.
Good luck.
Cyryl
Nov 10, 2007 | Intel Motherboard
Computers & Internet Logo
93 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
