Question about Whistler Power Inverter
How long will 12 v battery last using power inverter
I want to instal audio and video equipment in rv how fast will battery last before recharge can I install extra batteries.
  • Ibe Chukwudi
    Ibe Chukwudi May 11, 2010
    it depends on the power of the equipment you want to install let me know the power and the power of your inverter then i can help you
  • Gregg Rene May 11, 2010
    To answer we need to know 4 things:
    1. What model exactly is the whistler inverter? (so we can determine the efficiency)
    2. What is the amp-hour rating of the battery?
    3. What wattage rating is the inverter?
    4. What is the total wattage of the appliances you want to run?
    We have to know all four to estimate the current draw and the length of time for the battery to fall below the inverter shutdown point.
    And safety warning: remember - cigarette lighter plugs won't handle more the 130 watts of power, if you need more than a couple light bulbs lit you need to wire the inverter directly to the battery(s) (using a switch and fuse of course).
  • 615 Answers
Yes you can install 2 batteries for your systems and charged by your rv motor or exteranal charger.
Posted on Sep 08, 2009
  • 1 more comment
  • Norman Al-Anbar Sep 08, 2009
    if you going to use it while driving the car will keep the battery charged if you use it parked it will depend on how manhy watt is your tv or radio etc. usually small stuff use little so it may last few hours.
    you neeed to find out how many watt it use and how big is your battery I have forkleft battery old one I usually charge it every week and I use it for my house, tv, freezer, etc. Normal batteries usually last few hours if you have small sytem.
    yes you can use 2 of them to last about 18 hours...
    if one only without recheging it may last few hours...need to mnow how many amp your battery and how much use your system to be exact
Can these be battery operated? If so can this be done.
Yes, you go through a converter.Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DC AC Power Inverters 12 Volt DC to AC Inverter
12 Volt DC To 110 Volt AC Power Inverter for Auto RV and Boat compatible...
Mar 12, 2016 | Mediasonic HomeWorX HW-150PVR ATSC Digital...
Dometic brisk 2 AC can it be operated on a 24 volt inverter.
If your inverter puts out enough power, sure. It may drain your batteries pretty fast, though. Check the power rating of your AC and compare it to the power output of the inverter. Add a safe margin for everything else you want to run at the same time.
Oct 29, 2015 | Dometic Rooftop RV Air Conditioner
I have a 24' travelaire 1989 rv. is there a switch to go from electrical hook up to battery operated lights in the camper
there is a power inverter,somewhere near the front of the trailer, RV Basics 12 Volt DC Systems
http://www.winnebagoind.com/resources/manuals/pdfs/Winnebago_Catalog.pdf
Atwood Mobile Products: 574-264-2131
Carefree of Colorado: 800-621-2617
Carriage Carpets (Shaw Flooring): 877-706-3054
CCI Controls: 800-521-5228
Coleman: 316-832-4357
Denso: call Fleetwood 800-322-8216
Dometic: 800-544-4881
Fantastic Vent: 800-521-0298
Generac: 888-GENERAC
Intellitec: 800-251-2408
Kidde Safety Products: 800-880-6788
Kwikee Products: 800-736-9961
Magic Chef 800-688-1120
Magnadyne: 800-638-3600
Norcold 800-543-1219
Onan: 800-888-6626
Power Gear: 800-334-471
Riverpark: 800-442-7717
Suburban: 423-775-2131
Suburban Dynatrail Furnace Manuals
Thetford: 800-521-3032
Velvac: 800-783-8871
Winegard: 800-288-8094
Xantrex (invertor/chargers and control panels )
http://www.rverscorner.com/wiring/index.html
Manuals 1989 older RVing The Midwest Connection
May 14, 2015 | Camper Vehicle Parts & Accessories
Dc lo keeps blinking on the fridge and lights go low in rv, power converter middle light is blinking green
The battery is not being charged OR is no longer accepting a charge.
The inverter does not charge the battery. An inverter consists of components that first convert the battery's low (12) volt "direct current" (DC) power used to power automotive devices to a higher (120) volt "alternating current" (AC) power that is required by nearly all household appliances to operate properly.
The charging of the battery occurs when either the RV's engine is running and spins the alternator, etc. OR when connected to another charging device - whether it is permanent or portable.
With the RV engine running, there should be about 13.5 - 15 volts, DC on the battery posts or terminals. This voltage is coming fromt he RV alternator and since it is greater than the 12 volt battery, "charges" the battery. If you use a portable charger - that is part of a generator, or plugs into a power port at a camp site, etc. this will charge the battery.
When none of these things is happening, the battery voltage will slowly drop. Once it is at ~10 volts, it is "dead" and will need to be recharged.
The battery will no longer accept a charge if a "cell" inside it has "opened" or "shorted", or if the battery is at the end of its useful life. The battery state can be checked quickly by any mechanic.
I hope this helps & good luck!
Nov 19, 2013 | Electrical Supplies
I have a Craftsman mulcher model 315.370270. The green recharge light goes on but the battery charge level stays in the red. Do I need a new battery and if so where do I buy it?
I guess you've solved this by now, sounds like you need new batteries if the mower lacks power after trying to recharge. There are two sealed lead acid 12-volt batteries connected together on this mower to provide the 24 volts of power. These are the same batteries that are commonly used on rechargeable power wheelchairs and scooters. So you could find them at a Durable Medical Equipment company. The last two times I bought them, I got them from a DME company where I used to work. I also looked into buying them over the internet. Just make sure the replacement batteries are the same size and specs. You could burn out your on-board charger by continuing to charge batteries that are shot. I did this a few years ago with my 315.370270. Since then I have been charging the batteries with my portable Craftsman charger. The 12-volt batteries last about 3-5 years. I have had my mulcher since 1995 and have replaced the batteries about four times. This is the best mower I've ever owned. I'm going to retire it this year, if you're interested in it for spare parts.
Aug 27, 2011 | Craftsman Garden
Does this camera operate on regular AA bateries. Put 2 brand new ones in and it will not power up. The manual says Kodak does not "support" Alkaline batteries....
Probably this old chat may help you to resolve your problem.
From site:
http://www.digitalcamera-hq.com/products/kodak-easyshare-c663
Kodak EasyShare C663 Specifications
  • 6 megapixels
  • 3x optical zoom / 5x digital zoom
  • autofocus
  • auto exposure
  • JPEG file format
  • ISO 100-400
  • 2 AA batteries
  • movie mode w/sound
  • 2.5" LCD screen
  • Part Number:C663
  • Release Date:Jan 12, 2006
chrissy66 (12/10/2007)reply to this comment (by James DeRuvo - 12/12/2007)Sounds to me like your lens may have come out of alignment. Was it dropped recently? Since your camera is still under warranty, the best thing you can do is have Kodak should fix it. If your camera is out of warranty, or if Kodak refuses to repair it for free, the one thing you can try is to try resetting the camera.
Kodak is also of the opinion that lens errors also occur when you use batteries not recommended by Kodak.
I recently chatted with a kodak specialist about this issue and he recommends changing your batteries to NiMh rechargeable batteries. These are the batteries that the camera is designed to use and using other types - like alkalines, can often cause the lens error to occur. If that doesn't work, then the camera indeed does need repair.
Rechargeable Ni-MH Batteries (AA Size): These Ni-MH AA batteries last up to twice as long as alkaline batteries when used in your Digital Camera - and you can recharge them up to 1000 times in our rapid charger.
Oxy-Alkaline Digital Camera Battery (AA Size).
CRV3 Lithium Batteries: A non-rechargeable battery designed specifically for today's feature-rich cameras. This battery is the obvious choice for speed performance, and long life. It delivers faster flash recycle times and lasts up to 10% longer than our previous design!
Ni-MH Rechargeable Battery Pack: Provides exceptional capacity with its 2.5 hour fast charge cycle time; can be recharged up to 1000 times in the EasyShare Camera Dock or EasyShare Rapid Charger,
Jan 06, 2011 | Kodak EasyShare C663 Digital Camera
I have a 1000 Watt Inverter, along with a regular car battery when the electricity goes out; Question: Can I use the 1000 Watt inverter and connect a 100 amp, deep cycle battery? I use regular house...
Yes, just be sure connections are heavy enough wire, and obviously the inverter uses 12 vdc input. Hook jumper wires positive to positive, negative to negative, on all 12 volt batteries. Deep cycle batteries will work better than car batteries. Just remember, when re-charging them, that they last longer when charged slowly, so don't use a high amp setting on charger and to monitor them closely, and do it in a well ventilated area, away from any ignition sources.
Apr 14, 2010 | Schumacher 1000 Watt Inverter with 2 GA....
Inverter is draining house batterys on rv
it is possible that you batteries are bad, if you have used it for over a year you will need to replace it with new ones
Feb 16, 2010 | Xantrex Technology Heart Freedom 20 12...
Roof top rv air conditioner installation
Waeco manufacture a rooftop A/C with a matching inverter.you will need to ensure that you have enough battery power when staionary but your al;ternator will provide power when mobile you could also use a small generator through a battery charger to keep your batteriesd charged up but this is not neccessary unless you are stopped for a long period of time.these units are fairly easy to install and come with fitting instructions for the A/C and wiring kits for the inverter..hope this helps
Jan 11, 2009 | Dometic Rooftop RV Air Conditioner
Power Supply How To
Because inverters operate from a DC (Direct Current) power source, usually a battery bank (one or more batteries), the battery source will have to be recharged at some point. (Remember that a battery discharged more than 50% is probably close to being dead.) Most cars and trucks recharge their batteries from an onboard alternator. Depending on the inverter load and runtime required, most power use applications will be covered by the charged battery, augmented by the operating alternator supplying a continuous charge to the battery. If the load is large (air conditioner, large draw power tools, large microwave, food freezer, ice cream machine, etc.), the user should verify that the installed vehicle alternator is of large enough capacity to operate the vehicle's power requirement as well as to fulfill the capacity of the inverter load. If it’s not, a motor throttle installation may be required to carry a small load, a larger alternator may be required, or a larger alternator, battery isolator and additional onboard battery bank may be required in order to meet the power requirement of the large load. Remember: it takes 12 DC Amps (at 12 VDC) to run 1 AC Amp (at 120 VAC single-phase) of power because there are voltage and efficiency factors to take into consideration.
Aug 27, 2008 | Xantrex Technology Xantrex Freedom Xmic...
Whistler Power Inverter Logo
1,892 people viewed this question
Top Whistler Electronics - Others Experts
Brian Sullivan
Brian Sullivan
Are you a Whistler Electronics - Other Expert? Answer questions, earn points and help others
