Question about ASUS M2N-MX Motherboard
Problem in Ethernet port and usb
I've a problem with this board that motherboard cannot support usb as well as lan ethernet port using linux 4 please send some immediate reply for this thank you
  • 61 Answers
If you have an open Us2 port There is a PCI usb Expansion Cards you can plug in and it will work just fine But you might have to install driver for it. Here some websites will be helpfull to purchase or you can buy it from stables and Bestbuy. you can search in on ebay as Pci USB card they would be cheaper on ebay.
http://www.calibex.com/serv/calibex2/buyer/OutPDir.jsp?nxtg=bfc0a240520-43A764D6EAB0E45E&search=pci+card+for+usb&ysmwa=Z3MKRYnUU3a3WQ36sanwOvWFLeF70SVdnHAINxyN2EAVgPVhYFNSvJv8pAArf61E
http://www.memorysuppliers.com/bususb205por.html
Posted on Feb 28, 2009
Computer ethernet port
Try different cable, modem, router, but seriously if its the actual lan connector on the motherboard that is bad, buy a new motherboard.
Check the warranty on the PC.
You can always but a lan card, see what you have for PCI slots on your motherboard and buy a card from Newegg.
It is not worth fixing an onboard lan.(ethernet) one that's built onto the board.
Look at these.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&N=100006688&isNodeId=1&Description=ethernet+cards&x=0&y=0
Mar 04, 2013 | Compaq Computers & Internet
FROM WHERE CAN I DOWNLOAD WINDOWS XP SP2 LAN DRIVER FOR HP PROLIANT ML110 G6
Hi ppswalia
Since this is a Server, rather than an ordinary Desktop computer, it is not designed to work with normal Windows XP Operating Systems. It is designed to work specifically with Windows, Unix and Linux Server Applications. See here:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3577715&lang=en&cc=us&taskId=135&prodTypeId=15351&prodSeriesId=3577708
There are 2 things you can try.
You can try installing the LAN/Ethernet Drivers for the various Windows Server versions from the above official HP Downloads and Drivers Support Website and see if one of them just happens to coincidentally be compatible with XP SP2.
Assuming there are no further compatibility issues between other Server Motherboard Devices and Win XP SP2 Drivers, you could open the Server case and either bypass any on-board LAN/Ethernet/NIC Port or remove any separate LAN/Ethernet/Network Card installed and install, instead, a pre-confirmed Win XP compatible LAN/Ethernet/NIC Card and then install the drivers for the new card.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 18, 2011 | HP ProLiant ML110 Server
My dell xps 410 will not go online thru either of the ethernet ports on the computer. im using my phone with usb tether and it goes online fine. it says it need the ethernet controller driver but...
Hello, look at this link, you should have installed the bottom driver, but take care! if you've got a LAN card as well, you might have got the MOBO one disabled in bios, so best to take out the LAN card, find out what it is and look for a driver for it, meanwhile, with it removed, install the LAN driver for the MOBO LAN port, (bottom driver on this link ) and see if it appears in your 'Network Connections' (Check in bios to see if it's been disabled, though)
Regards, nicam49
The link: http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_PNT_9200_XPS_410&os=WW1&osl=en&catid=&impid=
Aug 22, 2011 | Dell XPS 410 PC Desktop
My compaq G60 laptop dont have ethernet lan driver how i can solve this.
buy a adaptor callled "USB LAN adaptor" ....connect to ur USB port and then connect the LAN cable to that adaptor...ur USB port turns to a LAN portb67261b.jpg
Feb 02, 2010 | HP Compaq Presario F500 F700 and G6000...
Need a driver..
Here you have specs for that motherboard:
Part/Feature Support/Specification Motherboard Description
  • Manufacturer's name - N1996
  • HP/Compaq name - Argon
Motherboard Supplier MSI System BIOS Supplier MSI/Award Form Factor uATX Processor Brand Intel Maximum approved processor 2.53 GHz Intel Pentium 4 Processor Socket Type mPGA478 Processor Family Intel P4 or Celeron Processor Front Side Bus Frequency 400/533MHz Chipset Name 845E Chipset "North Bridge"
revision/stepping 845E
A1 Chipset "South Bridge"
revision/stepping ICH4
A1 Super I/O
revision/stepping Winbond
W83627HF-AW Flash BIOS Device 4MB Flash EEPROM Memory Type 2.5v. DDR Memory Speed PC2100/PC1600 Memory Sockets 2 DIMM Maximum Memory 1GB Graphics Supplier Intel Graphics Configuration Up Graphics Connector (AGP) AGP 4x TV-Out Device No Audio AC'97 Down AC'97 CODEC Device Realtek ALC202A Audio Jacks (legend below)
M Microphone M,LI,LO,SO
LI Line In
LO Line out
SO Speaker Ethernet 10/100 LAN Supplier Realtek RTL8101L Ethernet Configuration PCI Down IDE UDMA Modes ATA-66/100 Expansion Slots (AGP/PCI/Exten) 3 PCI USB Ports 6 USB Front/Back Options 2F+4B Serial, Parallel, Floppy, PS2 Kbd and Mouse 1S,1P,1F,PS2 K+M Serial Port Front Chassis Option No Available Mfg Options -U,L,A,S
A Audio down on motherboard C External L2 cache on motherboard E 1394 on motherboard G Graphics down (on motherboard or in chipset) L LAN on motherboard (Ethernet) P - PCMCIA slot S S3 power management support T TV-out on motherboard U Graphics card (up, not on motherboard) W Microsoft®) Windows XP hardware compliant
Nov 19, 2009 | Computers & Internet
Can you tell me what the difference is between the modem part for ethernet/usb adsl modems, 060-E240-061 AND 060-E242-A01. I would appreciate and info or direction to a specific web site for this info....
when your pc conect with ethernet port also say that LAN port and oter port is USB port
which one conect with ethernet/LAN port is
called ethernet Modem and which conect with
USB port called usb Modem.
Jul 06, 2009 | Computers & Internet
To u my friend
nothing much buddy ...
here are some details below find the right one and take it
Model No: TM 2403NWXCi
Platform: Intel Celeron-M Processor 370 (1.5 GHz, 1MB L2 Cache, 400 MHz FSB)/ Intel 910GML Chipset.
RAM: 256 MB DDR2 400 RAM
HDD: 40 GB
Optical Drive: DVD-Rom/CD-RW Combo Drive
Display: 14.1" Wide Screen XGA TFT w/1280 x 800 resolution
Graphics: Intel GMA900
Other Features: Ethernet / Integrated 802.11b/g Wireless LAN/ 56K Fax-Modem/ 3 USB Ports
Weight: 2.38 KG
Battery: 6-Cell Lithium Ion Battery
O.S.: Linux
Warranty: 1-Year Global Warranty
Price: Rs. 27,999*
Model No: TM 2424NWXCi
Platform: Intel Celeron-M Processor 380 (1.6 GHz, 1MB L2 Cache, 400 MHz FSB)/ Intel 910GML Chipset.
HDD: 40 GB
Weight: 2.35 KG
O.S. : Linux
Price: Rs. 28,499*
Model No: Aspire 5002NWLMi
Platform: AMD Turion 64 ML-30 (1.6GHz)
RAM: 256 MB DDR333 RAM
HDD: 60 GB
Optical Drive: DVD-Dual Double Layer drive
Display: 15.4" WXGA Acer CrystalBrite TFT Screen w/1280 x 800 resolution
Graphics: N.A.
Other Features: 10/100 Ethernet, 56K Modem, Integrated 802.11 b/g WLAN with Acer SignalUp, Integrated Bluetooth
Weight: 2.9 KG
Battery: 8-Cell Lithium Ion Battery
O.S. : Linux
Price: Rs. 37,999*
Model No: Aspire 5004NWLMi
Platform: AMD Turion 64 ML-34 (1.8GHz)
HDD: 60 GB
Graphics: N.A.
Weight: 2.9 KG
O.S. : Linux
Price: Rs. 38,499*
Model No: Aspire 5502ZNWXCi
Platform: Intel Centrino Mobile Technology based Processor Pentium M 735A (1.7 GHz / 2MB L2 Cache / 400MHz FSB) / Intel 915GM Express chipset.
HDD: 60 GB
Optical Drive: DVD+CDRW Combo Drive
Display: 14.1" WXGA CrystalBrite TFT with 1280 x 800 resolution.
Graphics: N.A.
Other Features: 56 Kbps modem / LAN / Intel PRO 2200 -802.11b/g Wireless LAN Integrated/ 2 USB Ports.
Weight: 2.38 KG
Battery: 6-cell Battery
O.S. : Linux
Price: Rs. 40,499*
Model No: AS 1641NWLMi
Platform: Intel Centrino Mobile Technology based Processor PM 725A (1.6 GHz / 2MB L2 Cache) / Intel 915GM Express chipset
RAM: 256 MB DDR2 533 RAM
HDD: 60 GB
Optical Drive: 8X DVD-Dual Double Layer Drive
Display: 15.4" WXGA CrystalBrite TFT with 1280 x 800 resolution
Graphics: N.A.
Other Features: 56 Kbps modem / LAN / Intel PRO 2200 -802.11b/g Wireless LAN Integrated/ 3 USB Ports
Weight: 2.38 KG
Battery: 4-cell Battery
O.S. : Linux
Warranty 1-Year Global Warranty
Price: Rs. 42,499*
Apr 14, 2008 | Computers & Internet
MV43V motherboard by shuttle
Here are your MB specs:
MV43V/N - Supports Socket 478 Intel Pentium 4, Celeron with 400/.533 MHz FSB
- VIA P4M266A + VT8235 Chipsets
- DDR 200/266 SDRAM, 2 x 184 – pin DIMM, Up to 2 GB
- 2 x ATA 133
- 4 X AGP device, 2 PCI slots, 1 CNR slot
- Onboard AC97 audio two channels
- Onboard S3 Pro-Savage 3D Graphics
- Onboard VIA VT6103 10/100 Fast Ethernet (MV43VN only)
- 6x USB 2.0
- Micro ATX Form Factor
The your motherboard has an ethernet adapter all you need to do is download the drivers for the ethernet adapter and install them. here is the link : http://members.driverguide.com/driver/detail.php?driverid=206328 do a free subscription first. cheers
T
YE
Feb 16, 2008 | Shuttle MV43N Motherboard
ASUS M2N-MX Motherboard Logo
71 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
