Question about Samsung LN-T5781F TV
SOUND OK BUT NO PICTURE.
I HAVE A SAMSUNG TANTUS 43" PROJECTION T.V silver colour 3 guns ,chassis no PCL545R, mechanic suggest s to change PCB part THYRISTOR no 2SD 921 .
EXPERT OPINION REQUIRED.
THANX.
    President:
  • Samsung Master
  • 1,779 Answers
The 2sd921 is not a thyristor, but a High Speed Switching Transistor. It's used in the HV circuit of older televisions. If is is for the HV, make sure that he re-solders the horz driver transformer while he's at it, also check the hv safety caps. Just a word of caution, the CRT's in that model have a history of arcing, that could be why your 2sd took a dive. If that's the case don't have it repaired, besides I doubt if you'll be able to get them.
Posted on Feb 28, 2009
    Problem Solver:
  • 18 Answers
THAT MAKES SENSE, CHECK FOR HIGH VOLTAGE- YOU CAN SIMPLY HOLD A NY SMALL NEON BULB[LIKE THOSE USED IN PILOT AMPS] NEAR THE ANODE LEAD OR FLYBACK TRANSFORMER IF IT'S ACCESSABLE, AND IT SHOULD GLOW. THE NEXT STEP IS TO CHECK THE FILAMENT CIRCUIT FOR THE PROJECTION TUBES- OFTEN IN MODERN SETS, THE FILAMENT [HEATER]VOLTAGE IS OBTAINED WITH A COUPLE WINDINGS AROUND THHE FLYBACK. IF YOU HAVE HIGH VOLTAGEE, AND NO FILAMENT, A 'HACK' THAT WORKS IS TO USE A SMALL POWER TRANSFORMER [MOST FILAMENTS [HEATERS] ARE 6.3 VOLTS, BUT DOUBLE CHECK THAT- IF YOU HAPPEN TO HAVE ONE OF THE LESS COMMON LOW VOLTAGE HEATERS, AND YOU OVER-VOLTAGE IT, YOU'VE JUST DESTROYED A VERY EXPENSIVE TUBE.THE 2SD921 IS IN AL LIKEYHOOD THE HORIZONTAL OUTPUT, WHICH DRIVES THE HIGH VOLTAGE CIRCUIT. IF YOU HAVE A SCOPE, CHECK FOR APPROX 15KHZ SIGNAL AT THE EMMITTER OR BASE- BUT BE CAREFUL ABOUT THE GROUND LEAD- USE A 3 PRONG ADAPTER, AND DEFEAT THE EARTH GROUND OF THE SCOPE, OR YOU COULD DAMAGE THE TV'S POWER SUPPLY
Samsung Tantus projection TV 40 inches. the problem is that when it has worked for 5 minutes the text and picture is having a trace line that looks like a convergence problem in conventional CRT tv. any...
U have the early warning problems of the convergence problems.Do the manual or auto convergence adjustment until,u can't do it anymore.Replaced all the parts,that make the convergence board to work.
Jun 22, 2010 | Apex Digital GB4308 43" Rear Projection...
My TV was snapping or arcing then no picture at
Sorry to hear this. What has happened is that CRT coolant has leaked from one or more CRT's down onto the Main bd and or the Power Supply bds and shorted them. You must replaced ALL three CRT's and the shorted Main bd and or the Power Supply boards. Then a Full Convergence Alignment must be done by a very good and experienced tech. Not cheap.
Apr 04, 2010 | Samsung PCL545R 54" Rear Projection...
Samsung Tantus (SP-43J8PF) Has Green Tinge - Easy fix?
You may try to get into the service menu and adjust screens/drives level(procedure below). But first turn the color off completely and adjust you brightness to mid-range, what you`ll want to do is a grey raster or bring it as black and white as you can while adjusting the red/green /blue guns or tubes. Also get a piece of paper and pen because you`ll want to record the original values of the items you may change. You want to go into the adjustment menu. Hope this will help Good luck
In quick sequence on the remote press:
MUTE - 1 - 8 - 2 - POWER buttons.
The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
Select the function and use the VOL+ button to enter.
Save settings and exit by pushing MUTE twice then POWER .
Nov 19, 2009 | Samsung PLH403W 40" Rear Projection...
Samsung Tantus problem
your main power supply is gone out
Aug 30, 2008 | Samsung PCH521R 52" Rear Projection...
Our Samsung Tantus Rear Projection TV, the colour is a problem, on the right hand side there is a red shadow next to the picture so it almost seems as if the picture is doubled. I have a double picture...
Sounds like a convergence issue with your RGB colour channels - probably need to get it serviced and have the convergence tuned.
Unlikely you can do this yourself.
Papa
Jun 20, 2008 | Televison & Video
Green bow tie, convergence not helping
Yes, your geometry correction has failed and you will need to seek qualified tech for help. You need what are called STKs and you should be able to get the job done inhome for under 300.00
Craig www.classtorations.com
Jun 08, 2008 | Samsung PCL545R 54" Rear Projection...
Samsung 52" tantus pch521r convergence panel
I found a this SITE that carries that convergence assembly for your TV.
Good Luck.
Mar 10, 2008 | Samsung PCH521R 52" Rear Projection...
No picture
Without diagnosis I would bet on a tuner.. with PIP you have two tuners.  However, check all your cables, with any electronic equipment, we always first start with the simple things and work upward toward more complex possibilities.
Mar 08, 2008 | Samsung PCL545R 54" Rear Projection...
LG PLASMA TV WITH COLOURED LINES OVER SCREEN
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Dec 22, 2007 | LG 42PX5D 42 in. Plasma HDTV
Samsung LN-T5781F TV Logo
146 people viewed this question
Henry  Thomas
Henry Thomas
