Question about Microsoft Windows XP Professional
How to convert a jpeg image into bits(binary data)
I am doing my project in java. i have a need to convert images into its binary code
  • Peter Steiert
    Peter Steiert May 11, 2010
    Do your own homework. This is the kind of thing notes, listening, and textbooks are for.
  • 271 Answers
Hi Sir,
Check this link.maybe it is what you are looking for.
http://www.vbcity.com/forums/topic.asp?tid=156188
Thanks
Posted on Feb 28, 2009
....not to mention "Google", all kinds of info and free software for this!
Changing Jpeg into PDF
Here is an Image to PDF Converter which converts JPG, GIF, TIF to PDF.
http://www.dvd-ppt-slideshow.com/aff/convert-jpg-gif-tif-to-pdf-image-to-pdf-converter/
Image to PDF is a simple, lightning-fast desktop utility program that lets you convert photos, drawings, scans and faxes into Acrobat PDF documents.
Aug 29, 2011 | PANDIGITAL PANSCN05 Film Scanner (35 mm)
How to get no. Of pixels from given image through java
try this code
import java.awt.image.PixelGrabber;
import java.awt.Toolkit;
import java.awt.Image;
class getpixel2
public static void main(String args[]) throws Exception
Image image = Toolkit.getDefaultToolkit().getImage("D:\\one.jpg");
if(image==null)
System.out.println("NO FIle");
PixelGrabber grabber = new PixelGrabber(image, 0, 0, -1, -1, false);
if (grabber.grabPixels())
int width = grabber.getWidth();
int height = grabber.getHeight();
if (isGreyscaleImage(grabber))
byte[] data = (byte[]) grabber.getPixels();
else
int[] data = (int[]) grabber.getPixels();
for(int i=0;i<data.length;i++)
int r = (data[i] >> 16) & 0xff;
int g = (data[i] >> 8) & 0xff;
int b = (data[i] >> 0) & 0xff;
System.out.println("(R,G,B)=("r","g","b")");
public static final boolean isGreyscaleImage(PixelGrabber pg)
return pg.getPixels() instanceof byte[];
} import java.awt.image.PixelGrabber;
class getpixel2
if(image==null)
else
May 15, 2010 | Computers & Internet
DFT technique in image steganography
Just do a search in your favorite search engine for 'steganography dft' and you should get several thousand results that cover the theory, the math involved, etc. Bing returned 3,380 valid results.
Jul 26, 2009 | Computers & Internet
Can anybody tell me how to convert jpg image to its binary form??
may be this link will help you in making a project
http://www.codeproject.com/info/search.aspx?artkw=image+to+binary
Apr 22, 2009 | Microsoft Windows XP Professional
Java code for adding octal, hexadecimal subtracting binary,
Hello desireejane,
One method is to do the following
  1. Convert the octal, hexadecimal or binary to decimal.
  2. Add or Subtract the decimal normally
  3. Convert the result back to octal, hexadecimal or binary.
  • Convert the octal to decimal:
public static long octalToDecimal(String octal) throws NumberFormatException {
// Initialize result to 0
long res = 0;
// Do not continue on an empty string
if (octal.isEmpty()) {
throw new NumberFormatException("Empty string is not an octal number");
// Consider each digit in the string
for (int i = 0; i < octal.length(); i++) {
// Get the nth char from the right (first = 0)
char n = octal.charAt(octal.length() - (i+1));
int f = (int) n - 48;
// Check if it's a valid bit
if (f < 0 || f > 7) {
// And if not, die horribly
throw new NumberFormatException("Not an octal number");
} else {
// Only add the value if it's a 1
res
+= f*Math.round(Math.pow(2.0, (3*i)));
return res;
Mar 24, 2009 | Sun Java Programming Language (cdj-275)
Access of image file through c/c++ programme.
The best way to do this is to use Visual C++ or .NET's C# and use an image object to hold the binary image data as you address/manipulate it. If you are doing this as a web-based application, then ASP.NET using C# is the way to go, again using an image object.
There are many helpful developer site for the beginner through expert that can walk you through the use of an image object. There are also many variants of the image object and you'll have to decide which one best suits your needs. Start with the generic one to get your base code loading and addressing the image and go from there.
Here's a good starting point.
Hope this helps.
Dec 25, 2008 | Computers & Internet
Solution for converting image(jpeg,.bmp) to string
hi prem,
i really cant answer your question but im hopeful that maybe this link will help you in your troubles.
thanks for using fixya
Mar 30, 2008 | Computers & Internet
Face recognition in java
http://www.ifp.uiuc.edu/~krejcark/Demo/DemoParams.dat
Mar 21, 2008 | Computers & Internet
Java programming
There are 2000 jpeg libraries in Java out there, easily searchable on search engines, sourceforge, maybe versiontracker, and secondly, you're asking for (what should be application-specific -output-; why would you hobble input) crop/resize without hinting at your algorithm? First, get a real programmer....
Java project for college applications? Gee, how about one to take a personality inventory (the INTJ type; only padded out) including areas of interest and make people little public/private spot codes (2D barcodes, like the ones in Japanese magazines) to indicate their type. The camera in a cellphone with J2ME can read the codes, maybe.... The cool part is that they're coupled with either P3P in wikis or java applets that help communicate with that person if you're an type that would otherwise take bothersome human care and preface to communicate.
There are all kinds of little systems you can build to thwart the draggy bits of Alzheimers' etc. with various little expert systems, that come up when you read a science journal (Nature, Science, Dr. Dobb's Journal, JAMA, JVNA....
You could invent something other than big-headed anime characters to add a personal visual reference to GUIs; emobots were cool, but maybe you can have a **** Cheney's Hands IM environment if it doesn't already exist (see also: Galludet University (for deaf students) stuff.)
Mar 20, 2008 | Computers & Internet
*ist RAW converter problem
Ignoring the JPEG artifacts, which isn't about the extra grain in both the TIFF and JPEG images produced by the convertor, is it possible that different sharpness settings were used for the output images that for the on screen review? High values of sharpening without using an appropriate noise threshold value will have the effect of increasing noise/grain.
Sep 08, 2005 | Pentax *ist D Digital Camera
Microsoft Windows XP Professional Logo
314 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
