Question about Minolta CF2001 Copier
Service code c37 appeared on my toshiba photocopier
Service code c37 appeared on my toshiba 550 photocopier
  • Minolta Master
  • 643 Answers
C37 indicates Abnormal transfer belt cam motor.
U need to perform below checking:
(1) Check if the connector of the transfer belt cam motor is not disconnected.
(2) Check if the transfer belt contact/release switch is working properly.
(3) Replace the transfer belt cam motor.
(4) Replace the LGC board.
Posted on Feb 28, 2009
HOw to remove C 550 error in Toshiba Photocopier?
Hi Jawad, I hope you came right if not you can maybe ask the guys over at Thoshibatech?
Toshiba Copiers South Africa 1 Toshiba Printers For Sale
Jan 24, 2018 | Toshiba Office Equipment & Supplies
Error c37 toshiba
Hi Ahmed - I'm not much of a copier tech any more, but I'm pretty good at looking things up.. :)
According to the link I found for you, it indicates a problem with the transfer belt cam motor. One contributor on another site wrote, "I don't have service manual. However you may try this; Press and hold 0 and 3 while turning on the power. Enter code 114. This will make the Transfer belt motor run. Press Clear/Stop to end the test." The page with error codes was found here: http://officeimagingsystems.com/id175.html - your machine is about 2/3 down the page. Another contributor recommended that you, " Examine the transfer Belt to check and clean it,contacts,wires etc.
Use a multimeter to check if belt motor is working or not.
If it works,it means you can have problems with wires,conntacts and LGC board." Other people pointed out it could be failure of the cam motor itself. I hope one of these bits of information leads you to a solution.
Finally, if you don't have a service manual for it, I found one you can download for free at http://www.feedroller.com/Store/Service%20Manual/SERVICE_MANUAL.PDF Best wishes -
Mark
Jun 15, 2014 | Toshiba E-studio 550 Copier W/net Print
Call service
Hi:
If you hold down the clr and 8 keys together a alpha numeric code will appear in the upper right corner of the display. I would need this to diagnose further.
Andrew
Nov 13, 2013 | Toshiba E-Studio 3511 Color Copier
Hello, I turn on my Toshiba E-Studio 166 Photocopy Machine and it shows an Error Code C 41, please how can I fix this problem?
Poor contact of the fuser drawer connector may cause the following
error codes: C41~C46, C4A, CD5, E01, E03. To correct this issue, a
spacer (see SPL p25 item 1 attached) has been added between the
fuser connector and the frame; also the springs (see SPL p24 item 8
attached) have been changed to provide more tension.
This change has been applied since January 2003 production:
e-Studio 550 TA314824
e-Studio 650 WA312627
e-Studio 810 XA311627
Model P-I Before Change After Change
e-ST550 25-1 --- 6LA14365000
e-ST650 SPACER-DRW-CNCT
e-ST810 24-8 6LA08946000 6LA14468000
SPC067-070-140 SPC068-080-160
Jan 26, 2011 | Toshiba e-Studio163 Copier
Toshiba e-studio 45call for service 254292
Press "clear/stop" and "8". While holding this combination of keys down, an error code will be displayed....what code are you getting?
Sep 15, 2009 | Toshiba e-Studio 45 Black and White Copier
I have 2 problems with my toshiba 550. service code CD3 and SPC
The CD3 error is related to the recycled toner unit. the recycled toner is backed up/clogged.
Toshiba made a parts change to the design of the recycle toner unit by replacing a bushing with a roller bearing and a seal. depending on how old your copier is it may or may not have this modification. The copier firmware/software also needs to be updated to the most current version and along with that there are a few internal settings that need to be adjusted.
If you are unable to do any of the above then try this - (it will get rid of the problem short term) clean/vacuum out the toner recycle unit.
If you open the front cover of the copier you will a white plastic pipe sitting at about a 45 degree angle (below the toner cartridge) - this is the pipe that leads to the recycle unit on the right. The whole unit needs to be removed and taken apart and cleaned, inside and out, including the pipe.
The SPC code is related to this issue and should also go away.
Hope this helps.
Mar 31, 2009 | Toshiba E-STUDIO 550 Copier
My toshiba e-studio 550: service recommended for SPC appeared
Check the control status of the surface potential sensor (05-242).
<When “4” is displayed: sensor error>
The sensor detection value is abnormal or the sensor output value is not changed even though
the main charger bias value is changed.
Is the connector of the surface potential sensor connected properly?
Is the main charger grid/wire attached poorly?
Is the main charger attached poorly?
Are leaks and such occurring?
Mar 05, 2009 | Toshiba E-STUDIO 550 Copier
Toshiba estudio35 trouble code
Try 08-600 sub code of 2. This is a reanitilazation of the HDD it may help you out. If it errors and does't tell you to reboot then your hdd is shot. after this code you will lose all fax presets and templates stored on machine. also just try a reboot.
Apr 20, 2008 | Toshiba e-Studio 350 Copier
291 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
