Question about Dell OptiPlex GX260 PC Desktop
Is it possible to have a bad network card.if so would it do any good to try to reboot after uninstalling network card, then putting network card back in to see if computer would recognize. I have the yellow ? marks on the ethernet-driver device ect. can this only be a driver problem or could it be a card problem????
    Sniper:
  • 66 Answers
Hi
Is it your wireless desktop card or your lan card ?
An yellow exclamation mark means the drivers are not installed .
Sometimes drivers that you install from the cd are corupted or not working .
Try uninstalling and reinstalling the device.
You can also download drivers dirrectly from the dell website if it is an lan card .
http://support.ap.dell.com/support/downloads/drivers
If it the wireless desktop card take the card out
Then download the drivers for the wireless card and reinstall that
Plug the card back and and follow the steps to configure the hardware
And as far as my knowledge goes it is a driver problem .
Posted on Feb 28, 2009
  • 82 Answers
Try to uninstall and re install driver first ..if the yellow symbol remains..then it might be the card problem...
At startup windows narator give error 0xc000007b
If you have installed a network card, uninstall any software you installed for it, then shut down your PC. Uninstall the network device you are having trouble with and boot your computer into safe mode (Power up the computer and IMMEDIATELY begin to tap the F8 key SLOWLY about ONCE PER SECOND until you see a menu, then STOP. Use arrow keys to select safe mode then press enter) to see if it will start correctly. If windows starts in safe mode, the reboot. If windows starts normally, there may be a problem with the driver software (download new drivers) or the card itself is bad, and windows chokes on it. You may wish to try and install it again, but that is your call. I would try a different adapter.
Sep 16, 2013 | Acer Computers & Internet
My dell Optiplex GX-620 But my lan indicator was always green flashing but now Its red all the time. please give me th sol
Red would be no signal.
1. Check network cable (try a different cable).
2. What is connected at the other end? Hub? Switch? Modem? Does the other equipment also have lights?
3. Check the settings in the operating system / driver. Select "Auto" for link type and speed. Use manufacturers defaults if possible.
4. Uninstall the network card driver, reboot, re-install the network card driver
Jan 13, 2011 | Dell OptiPlex GX260 PC Desktop
I have not used my laptop for a while and when i came to use it my wireless connection wont work i have a netgear virgin system installed.
Check in the device manager if your computer is seeing the wireless card driver.
Right click my computer, properties, hardware, device manager,network adapters.
Is the wireless card listed?
If it is right click uninstall and reboot on reboot the wireless card should be seen as new hardware follow the wizard and let it install the driver.
If the computer is seeing the card but it has a yellow mark next to it the driver is not loaded you need to get the appropriate driver for that type of card from it's support site or once again try the uninstall reboot.
That’s the wireless card.
Is the net-gear showing an internet connection.
Put a cat 5 cable from your laptop to the net-gear and try to connect via cable if that works it's got to be the wireless card driver or the wireless settings in the net-gear however if they worked previously there is no reason to suspect the router settings.
Hope this helps
Sep 12, 2010 | Computers & Internet
In order to configure TCP/IP,you must install and enable a network adapter card, Windows 7, Vostro Dell A840
Not much to go on with your question. Windows 7 does not see your network adapter(s). Did you just upgrade? If so, you might need to go back to Dell website and download the Win7 drivers for you laptop. On that laptop you should see 3 network interfaces for WiFi, Ethernet, and the modem, and possibly a 4th for bluetooth. Dell is pretty good with downloads - just type in your service code at their support site, and they will only show you what you might need for your computer.
Jun 09, 2010 | Dell Computers & Internet
Connect my mediacom cable to a laptop I just
Hi there.
If the other computer is connecting fine then the problem lies with your laptop, possible bad drivers.
This method will hard reset the wireless drivers back to default settings.
What i want you to do is right click "computer" select "manage" and then "device manager", a list will populate, then click on the + sign next to "network adapters" and right click on the wireless adapter and "uninstall" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again.
keep me informed please as a download of the drivers may be required.
Good luck
Jun 29, 2009 | Dell Inspiron E1705 Notebook
Cant get wireless card to work!
Mic,
Couple of ideas for you to try, sorry if you've all ready given them a go
have you tryed installing the software first then plugging the usb adapter in?
Have you tryed a different USB port?
Regards
Nick
Dec 01, 2008 | Computers & Internet
House hit by lightning - Ethernet not connecting to router
Most likley the network card is bad. Check if you get any lights on the network card. If there are no lights get a PCI network card for the system. If you get the link lights it could be just corruption on the system. Try uninstalling and reinstalling the drivers.
Aug 02, 2008 | Dell Dimension 4600 PC Desktop
Network adpter malfunction
try this
Uninstall any drivers for card shut down remove card restart then shut down reinsert card reboot on reboot it should come up with message new ??? found and go into finding drivers follow instructions to install them from where the driver folder is
when installed reboot normally this will fix problem
Jul 27, 2008 | ASUS Computers & Internet
104-Unsupported wireless network device detected. system halted. remove device and restart
The problem is caused by a card that is either not built for the machine or is corrupt. This is not a driver issue as this message comes up in the POST (Power On Self Test) this is before any driver is loaded. The reason that this happens when a network card is replaced is because HP/Compaq laptops have a whitelist of allowed cards built into the bios. If the cards vendor and device id don't match one on the list they don't allow you to run it. This is simply so you have to line the pockets of HP spare parts for somthing 10 times more than what it is worth. The only solution is to flash your bios with a modified one to remove the white list. This is a very risky operation and could brick your machine. If your getting this error and have not changed your card the likely reason is corrupt card or the bios has somhow become corrupt. Good luck on this issue.
Jul 15, 2008 | HP Pavilion dv1000 Notebook
Nvidia GeForce FX 5500 / 256MB gets rebooting
Try to boot in safe mode, uninstall then reinstall the driver for your card, then try to change the resolution gradually.
May 21, 2008 | Nvidia GeForce FX 5500 Video Card Graphic...
Dell OptiPlex GX260 PC Desktop Logo
155 people viewed this question
Alun Cox
