Como habilitar mute
queria tmb
You may also use the following shortcut:
Dial ''1'' to exit programming mode and store the option as Enabled
(Mute Button, Record Out, Record Warning Tones), or
1-Line (Display) or the Per Plug setting (Headset Volume).
Dial ''2'' to exit programming mode and store the option as either
Disabled (Mute Button, Record Out, Record Warning Tones, or
Headset Volume) or 2-Line (Display).
Dial ''3'' to set the Headset Volume to the Per Call setting. (This
option is ONLY available for the Headset Volume setting.)
1-While on-hook (the headset must be unplugged), press 'SELECT'
+ The Light next To 'SELECT' Goes on.
2-PRESS 'MUTE'
+ THE CALLMASTER is in option Programming mode.
3Dial The 2-Digit Code, "68" ("MU").
+ The current Setting (Enabled or Disabled) is Shown on The display.
4-Dial * To chande the Setting.
5 when the setting you prefer is shown on the display, press # to save it an exit Programming mode.
DISPLAYING THE OPTIONS -------
To display the option settings:
1 While on-hook (the headset must be unplugged), press 'SELECT'
Select .
d The light next to
'Select' goes on.
2 Press
''Mute'' .
d The CALLMASTER is in option programming mode.
3 Dial the 2-digit code, ''00.''
d The display shows the option settings (three options are available
on the CALLMASTER III; four options are available on the
CALLMASTER II).
d The display will return to normal after approximately five seconds.
NOTE: Use the same procedure for international settings. However, you
must dial ''11'' instead of ''00.'' The top line of the display shows the
international settings, and the bottom line will either be blank or report a
problem with the (EEPROM) memory used to store the options an
Voc? tamb?m pode usar o atalho seguinte:
Dial '' 1 '' para sair do modo de programa??o e armazenar a op??o como Ativado
(Bot?o de mudo, Record Out, Record Aviso Tones), ou
1-Line (Display) ou a defini??o Per Plug (Headset Volume).
Dial '' 2 '' para sair do modo de programa??o e armazenar a op??o como quer
Disabled (Bot?o Mute, Record Out, Tons de aviso Record, ou
Volume fone de ouvido) ou 2-Line (Display).
Dial '' 3 '' para definir o volume do auricular para a defini??o por chamada. (Este
op??o s? est? dispon?vel para a configura??o de volume do auricular.)
1-o monofone no gancho (o fone de ouvido deve ser desligado), prima ' SELECIONE '
+ A luz ao lado ' SELECIONE ' continua.
2-PRESS ' MUTE '
+ O CALLMASTER est? no modo de programa??o op??o.
3-discar o c?digo de dois d?gitos, "68" ("MU").
+ A configura??o atual (ativado ou desativado) ? mostrado no display.
4-Dial * Para Chande o Ambiente.
5 quando a configura??o de sua prefer?ncia ? exibido no visor, pressione # para salv?-lo de um modo de sair da programa??o.
Apresentar as op??es -------
Para exibir as configura??es de op??o:
1 Enquanto estiver no gancho (o fone de ouvido deve ser desligado), prima ' SELECIONE '
Selecione.
d A luz ao lado
' Select ' continua.
2 Pressione
'' '' Mute.
d O CALLMASTER est? no modo de programa??o op??o.
3 Disque o c?digo de dois d?gitos, ''00.' '
d O visor mostra as defini??es de op??es (tr?s op??es est?o dispon?veis
na CALLMASTER III; quatro op??es est?o dispon?veis na
CALLMASTER II).
d O display voltar? ao normal ap?s cerca de cinco segundos.
NOTA: Use o mesmo procedimento para as configura??es internacionais. No entanto, voc?
deve discar '' 11 '' em vez de ''00.' 'A linha superior do display mostra a
configura??es internacionais e a linha de fundo ou ser? em branco ou relatar um
problema com a mem?ria (EEPROM) utilizado para armazenar uma das op??es
Oct 29, 2013 |
Avaya 6408D+ 8 Button Display Telephone
same happened to me and I cant un ignore him and I really want to
Same thing and my friend can't give me my mill now... i gave it him from another acount now i can't get it... sucks.
