Question about Amana ALW480DA Top Load Washer
Does not agitate with large load
With a small load it agitates on medium larger loads don't agitate well or wash well when i got it from someone it only spun didnt agitate then i heard a bang and it started agitating but now only with small loads and if to big of load it leaks can u solve
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
Have same problem but mine take large and small loads and leaks
you need part #ap4253876 made by whirlpool
Posted on Mar 03, 2009
Have a GE washer that has small, medium, large, and super load size. It's a top loader. When machine starts wash cycle, it bangs on the cotton and permanent press setting?
Probably out of balance, if in the spin cycle. If not, a "bang" corresponding with agitator reverse, you may have a transmission problem. Override open lid off switch with a pencil or used toothbrush in the small hole upper left location just under lid when closed so you can see the agitator action. If so run it till it breaks. Then replace. Otherwise, call your friendly appliance repairman and ask for a repair estimate first. If it is an ageing machine consider repair cost versis a lightly used one or new.
Oct 30, 2014 | GE G.e. Gtwn4950lws He Top Load Washer
Washer won't agitate
I would start by checking the belt on the motor could be slipping when u put full load in washer. also check that pulleys are not loose.
Apr 19, 2014 | Miele W1903A Front Load Washer
Washer wont agitate or spin
Depending on the brand of washing machine, the agitator may be a single piece unit or a two piece dual action agitator. If the single piece agitator or the lower portion of a dual agitator does not oscillate back and forth during the wash cycle, or if the agitator can be turned on the transmission shaft, then the spline may be damaged and the agitator may need to be replaced. Most agitators are held in place with a bolt that threads into the top of the transmission shaft and is located below the softener dispenser or top cover. Some models use a small set screw in the barrel of the agitator just above the base to secure the agitator to the shaft, while some will use a rubber o-ring to provide a tight fit. When the retaining device is removed you should be able to lift the agitator from the shaft.
Aug 03, 2017 | KitchenAid Washing Machines
My Sear Kenmore washing macbine will barely agitate when using the full size load. It barely moves, but on small or medium loads it works fine. What seems to be my problem?\r\nModel #110.26292692 SN#...
Take and turn the agitator by hand. It should only turn one way. If the agitator will turn freely either way, then you will need to replace the "agitator dogs" that go in the top of the agitator. Take a look at this video.
Jul 21, 2011 | Kenmore 16812 Washer
Maytag top loader won't agitate. will fill and spin
Try this:
When the washer should be agitating, try turning your load size switch back and forth a few times. If you are on a medium load, going to a larger load should cause it to begin filling again, going to a smaller size should start the motor for agitate. If this works, your pressure / water level sense switch is okay, but the switch for load size is faulted / or is on its way out. If you went from a medium load, to a higher load, then your pressure switch is faulted as well.
Sep 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
90 series--------the agitator makes a grinding sound on small loads, and doesn't work at all on large loads
If you mean the top half of the agitator doesn't move, then the 4 "dogs" need replaced.
Feb 13, 2010 | Kenmore Washing Machines
Maytag Performa Model# PAV 2300 AWW agitator & larger wash load
pull the agit out and look at the side just below the slots there is a small hole there and the lock screw is probably missing . / to pull agit you turn the screw out and to lock it down you turn it in till it stops . if no lock screw the out comes the agit ... could be very bad in spin if it came out . i have heard of this .. so lock it down .. **** hope this helps .
Dec 07, 2009 | Dryers
Washer wont agitate with med - large loads
Without knowing the age of your machine, your agitator "dogs" may be wearing or worn out. It should be fairly easy to check them out. You will need to figure out how to remove the agitator Usually the agitator will have a fabric softener dispenser or a cap on the top. Pull the dispenser/cap off the top of the agitator and you may see a screw holding the agitator in place. Once you lift the agitator out, the "dogs" should be visible. Most appliance stores should carry the dogs for your particular washing machine. I've added a couple of photos so you have an idea what to look for.
Black powder under the motor??? The motor uses carbon "brushes" to electrically make the motor move. Without going into motor theory, I would tell you that the black powder, in a small amount, is normal. The brushes can be replaced, and again, can be found at most major appliance dealers
Jan 11, 2008 | Amana ALW880WH Top Load Washer
Amana ALW480DA Top Load Washer Logo
256 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
