Question about Sony PlayStation 2 (PS2) Console
Dual shock does not work or led display on controller
I have an old ps2 console,and for some reason all my controllers do not vibrate or light up...they do work other than that..but it seems something from my console is causing my controllers not to shock or light up.....any thoughts??? ps, my controllers do work fine on other consoles,they just stopped working on mine....
  • buckwheat060 Apr 07, 2009
    ps2 all of the sudden will only recognize one controller. for some games that one controller is stuck in only one direction. I have tried several different controllers that all work, just not 2 at a time. Help?
If it is wireless put your ps2 infront of remote
Buy a new ps2 or remote
Posted on Feb 28, 2009
My mad catz dual force ps2 controller wont work
you will need a dual shock 2 ps2 controller. The mad catz controller is probably a dual shock 1 controller. Some games require the dual shock 2. It should say on the back of the game if the dual shock 2 is required. If it says something along the lines of "pressure sensitivity" or "pressure sensitive" on the back of the game case (where it says "1 player" or "2 player") ... then you will need a dual shock 2 controller. If this is not the case and it only says "analog controller" and "vibration" then you won't need the dual shock 2 controller. If the controller doesn't work for any games or even on the console main screen, then it must be the controller that is broken. Try turning the system on without a game in it and see if the controller works. Hope this helped :-)
Oct 16, 2012 | Mad Catz PS2 Dual Force Controller
I noticed that every time I buy new PS2 Dual Shock 2 it only last for 3 months because I play to much almost everyday then when I try to open the black wire of the dual shock the colored wires some...
Hi, This is happen because : 1. You may bought a non original controller. 2. You may always engage the vibration function. Sony dual stick controller ( analog stick) has fine cables inside controller. The imitation ones even smaller. While you use the vibration function for long time, it make some cables apart.
Suggestion :- Use only original dual stick controller ( analog stick). Don't engage vibration function for long time - I believe you can reconnect the wires inside controller ( so just fix it yourself) and play..
Dec 01, 2010 | Sony PS2 Dual Shock 2 Controller...
How to make a ps2 controll vibrate
if it's a dual shock controller, press the analog button.
that should do it.
press it again to turn it off.
hope this helps :D
Aug 18, 2010 | Sony PlayStation 2 (PS2) Console
Need wireless controller with vibration mode
they don't have it. the dual shock 2 has it. but thats a ps2 controller. the dual shock 3 is a six axis controller, sony opted for six axis instead of vibration. if your lucky you may be able to find a setup to use a dual shock 2 setup to use with an wireless adapter for the ps3. good luck with that one though.
Dec 17, 2009 | Sony Playstation 3 (PS3) Console
My PS2 controller does the same.
its vibrating because it is probably grounded.. check for stuck buttons...try opening it and check the rubber underneath the keys
Sep 06, 2009 | Sony PS2 Dual Shock 2 Controller...
Ps2 dual shock black controllers are not recognized?
1.) i think u r controller pin is bend are broken
2.) or controller wire is cut
its better 2 buy a new controller
peace out >>>>>
Jul 26, 2009 | Sony PS2 Dual Shock 2 Controller...
The vibration on the left side isnt working
Your controller ******** have got fused you are need to replace with new...
Jun 23, 2009 | Sony PS2 Dual Shock 2 Controller...
How to check terminals on a dualshock2 ps2 controller
does it stop working?or stopped vibrating?if the vibration stopped then wire connecting to the rotating motor is detached this is the common problem with dual shock because of constant vibration.Solution is to open the controller and connect the loose wire,dust is also a big factor if buttons are already not responding so try also to remove accumulated dust on the button touch board.
Jan 24, 2009 | Sony PS2 Dual Shock 2 Controller...
Sony PlayStation 2 (PS2) Console Logo
130 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
