Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Tv flickers I am looking at purchasing a used set from a friend but have been advised that the screen flickers. She thinks it is a bulb/lamp that needs changing. Does this sound right and if so, is it easy to change, how much do they cost and where can I purchase one?
  • 6,784 Answers
This is no bulb issue. its the tuner. this will cost 79.00 for the part. it is repairable. This is the beginnings of tuner issues. the flickering is the starting point.
Posted on Feb 28, 2009
Mitsubishi tv flickering
the problem you are having is the colour wheel. it spins to correct the colour on the screen when it fails you get wrong colours and flicker... the motor on it fails after time. and will need replacing.
Mar 05, 2014 | Televison & Video
Flickering
although the digital board could be a suspect, i would lean more to the dmd board. the board will hve to be repaired by a proper tv technician or it will lead to more critical state.
feel free 4 further assistance n keep sending more question n comments or doubts that arise in ur mind regarding this to me.rate the solution as fixya if it helps u understand n solve ur problem
Jun 18, 2008 | Samsung HLN617W 61" Rear Projection HDTV
The bulb is flickering. I have replaced it but the new one also flickers
replace the ballast I can send you one cheaper than you could purchase it I have 100s of them in storage always a ballast if they flicker
Apr 10, 2013 | Verilux Modern Deluxe Natural Spectrum...
I had to replace my lamp bulb in my mitsubishi wd-60638 tv and now i have a picture again but it is fickering and greenish tint to the screen
If you tried a cheap bulb then that might be the problem as some of the bulb carrage may not be complete4lyto spec. I had one that was close but there was a gap between bulb and where it fits. I went with a bulb dealer that had I believe a 1 year warrante and I have had no problems. I had a 73838 tv set.
Jul 26, 2017 | Mitsubishi WD-60638 DLP TV
Flickering shadows bottom 3/4 of the screen flatscreen vizio tv
Hello
To replace the CCFL lamps, you have to disassemble the LCD module. It is a very skilled work, as CCFL lamms are very brittle. and should be handled carefully. It will be best to get this set repaired by any expereinced service technician.
Mar 05, 2012 | Vizio VO47L 47 in. LCD TV
Just replaced my optoma hd65 lamp with an original optoma lamp and the picture color is great but there is flashing/flickering of the colors on the screen periodically, sometimes more often. I reset the...
Try putting the bulb into normal (rather than eco) setting.
Check the bulb is seated correctly.
If this does not help you may have to contact your bulb supplier to see if they can swap bulb for you.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Optoma HD65 DLP Projector
Tv went grayscreen, flickering. turned off, then
When you had gray screen and flickering you had only one problem - color wheel. After "putting everything together" you have totally different problem, caused by multiple possibilities like: forgotten connectors, cut/jammed cables/wires, lamp not being inserted properly, lamp door not being set properly, disconnected color wheel, etc. Try to open rear cover and redo what you have done. Remove optical block, check everything visually and slowly put everything back. If still no luck - then only skilled TV repairman may (or may not) help.
Mar 10, 2010 | Samsung Televison & Video
DLP TV starts to loose picture after 1 - 1/2 hours of use
This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. see which inputs have the problem to narrow it down. if only some inputs, suspect analog board. if everything flickers(all inputs and menu), suspect the dmd or engine. you can see the lamp shine out the back. if the lamp is flickering, suspect lamp or ballast.
Nov 22, 2008 | Samsung HLN5065W 50" Rear Projection...
Hitacha 50V720's Lamp Bulb
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy. Some models are real bulb hogs though. Look them up on the net (include the word complaint or repair) before you buy, or you might be sorry. Many class action lawsuits out there - even against some of the name brand makers.
Dec 10, 2007 | Hitachi 50V720 Television
Mitsubishi wd 57731 wont power up
There is a lamp cover on the back that only requires a few screws to remove. the lamp is behine there, you will need a standard screwdriver to remove the lamp and inspect it. If indeed the lamp is bad you will see it shattered and/or burned at the tip. The timer light flashing for 30 seconds is normal as the TV is going thorugh a boot up process. One word of advise, don't touch the glass part of the lamp pnly the case.
Nov 26, 2007 | Mitsubishi WD-57731 57" Projection HDTV
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
Henry  Thomas
Henry Thomas
