Question about Goodman GMS90703BXA Heater
Limit Switch I have a Goodman GMT Furnance. It was blinking for times which indicated an open limit switch. I replaced the limit switch and the aux limit switch. I was able to get the unit to blow warm air on one cycle. The circuit board shows no errors. The unit will start, the ignitor comes on the furnance fires, looks like the blower starts but after a few minutes the unit shuts back off. If it does run there is no hot air blowing into the rooms.
  • 1 more comment
  • k_matson54 Mar 01, 2009
    I cleaned the filter. I believe the reason for why the unit shuts off is because the lower motor (GE 5KCP39FGV0645AS) is bad. The fan does not spin causing the limit switch to trip. I took the lower motor assembly apart and found a piece where the end of the shaft fits into the back casing had discenigrated. I should know by Monday if I am correct after buying a new motor.
  • k_matson54 Mar 08, 2009
    You are correct when you say the limit switch shut down the system due to overheating. The problem was not the filters but the lower vent motor. Once I replaced the motor the unit has been functioning fine and with the original limit switch.
  • Paul Carew May 11, 2010
    have you cleaned the air filter
    Novelist:
  • 189 Answers
It is rare that a limit switch goes bad. It is a safety control. If it is shutting off your furnace there is a problem that it is protecting you from.
If the limit switch is shutting the unit down your furnace is overheating. Check the filters. Check for any obstruction in the blower assembly. Check to see if you can raise the blower speed. Make sure all registers are open in the house. Your evaporator coil could be obstructed if you do not take good care of your filters.
Posted on Mar 08, 2009
I turn the thermastat to heat on my goodman gms90904cxa and the inducer fan does not come on and after a couple of seconds the lights blink 3 times
Hello, a 3 blink pattern indicates a open limit switch. Most of the time a dirty filter, dirty blower wheel, weak blower motor, can cause the limit switch to open.
Oct 02, 2011 | Goodman Heating & Cooling
1993 goodman status light 4 times blinking
Witch blower is running, the inducer or the systems blower?
System blower could mean the the high limit is opening and shutting down the systems gas train, I would check this out first.
The other problem could be with the pressure switch for the gas train, it is supplied from the inducer motor, check to see if it is operating fully.
HSI boards do go from time to time, this sounds more like a system control problem.
Jan 24, 2008 | Goodman GMS90703BXA Heater
Furnace problems
On - OK
1 Blink - Ignition failure. Check Gas flow, gas pressure, gas valve, flame sensor.
2 Blinks - Closed pressure switch. Check pressure switch (stuck in closed position).
3 Blinks - Pressure switch - failre to close. Check venter, pressure switch, vent blockage.
4 Blinks - Open limit switch. Main limit or aux limit are open. (My comment - Means overheating in chamber. Often result of blocked intake air. Bad filter. In my case, plastic wrap had been sucked into the intake. )
6 Blinks - False flame sensed. Check sticking gas valve.
Rapid continuous blinking - Incorrect twinning, incorrect primary polarity. Reverse transformer secondary leads, reverse primary wires.
Closed pressure switch can be from dirty combustion vents, bad chamber pressure - like missing screws, maladjusted gas pressure, failing pressure switch, loose hoses, moisture in the hoses or fan blades The switch need to be closed to ge the unit to work
Jan 23, 2008 | Goodman GMS90703BXA Heater
Goodman # GMS81155CNA light blinks 4 times - furnance won't light and blower runs all the time - it's cold - please help
The 4 blinks means that the high limit switch or the regular limit switch are tripped... try to find the high limit switch... it is usually near the blower...there will be a red reset button in the center of it... push it in and the unit should work again...
if the regular limit switch is kicked you may have to replace it for the unit to work again...
This often happens after a power failure if the unit was running at the time of the failure. If you did not have a power failure, then find out why the limit switch kick out...
Here is a tip that will help you try to figure out why yourfurnace is not working.
BasicFurnace or Heating System Troubleshooting
heatman101
Apr 23, 2011 | Goodman GDS81155CNA Open Flame Mid-Size...
Goodman dependable 92,7years old. Furnace works sometimes. Checked out by qualified technican. no problem found. Constant checks shows troubleshooting light blinks three (3) times. Help please. 3...
This indicates a open limit switch on the furnace, the heat exchanger is getting to hot therefore the limit switch is opening and not allowing the furnace to work properly. Did the techinician check the limit switch on the unit?
Dec 30, 2010 | Goodman GMS90703BXA Heater
4 blinks, main limit switch open or aux limit switch open. How do I fix this?
There is a limit switch above the burner with 2 wires going to it. Take a jump wire and jump out the switch to test it, It is 110 volts so be careful. If it fires, that switch is bad and will need to be replaced. There may be up to two more switches on the same circuit. These switches may be reset-able if there is a small dark red button between the two terminals. Why did the unit overheat in the first place. Is your air filter clean? Is the room air blower working? Are all return air grills free of obstructions?
Jan 24, 2010 | Goodman Heating & Cooling
RED BLINKING (6TIMES) ON FURNACE
THE ROLL OUT SWITCH IS LOCATED IN THE BURNER COMPARTMENT MOST CAN BE RESET
Jul 20, 2009 | Goodman GMS90703BXA Heater
Goodman GMP125-5 limit switch open
There may be as many as 6 limit switches on the furnace. The first thing to do is turn off the power to the furnace. Look around the burner box. You will see possibly 3 small maybe brown plastic swithes with two wires to each and a button between the wires. Press the button on each one. If it clicks that's the one tripped. There may also be the same kind of switch(s) in the blower compartment. There's a self resetting limit on the middle of the furnace it also has two wires but looks like a black or dark brown plate about 2 1/2 X 3 1/2 inches. You have to check that one with an ohm meter. If any of these switches are tripped there is a reason. Check your filter and overall air flow. with low airflow the furnace may overheat. The switches around the burner box are roll out switches. Watch to see if flames are coming out of the burner area. especially when the blower comes on. DO NOT bypass any of these switches. Call a certified tech. to check it out.
Mar 02, 2009 | Goodman CLJ30AR32 Air Conditioner
I have a Goodman furnace GMPN080-4 REV B. I had the blower motor take a dive, so I replaced it with another equivalent 115 VAC 60 Hz 1/2 HP motor. I replaced the 10.0 MFD +10% -5% capacitor with a 7.5 MFD...
limit switch is on the heat exchanger black plastic about 1and1/2 in. by 2 in. with 2 wires going to it , it has 2 screws holding it in take it out and check it with an ohm meter and you should not have a reading if it is good
Feb 01, 2009 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
429 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
