Question about HP Photosmart C5180 All-In-One InkJet Printer
Left corner of paper wrinkles when printing
Used to jam paper, but now just wrinkling the left corners of the each printed document. Really annoying! Does anyone know why?
I know several reasons, and they are all related to an obstruction of some sort..whether it be a small piece of paper along the paper path, to something slightly bent, or broken...impossible to say for sure
Posted on Feb 28, 2009
    New Friend:
I was having this problem and couldn't figure out what was going on. I noticed the piece on the back of the printer that you remove to clear a paper jam was not longer sitting flush against the printer. I held it tight and printed a document, it printed fine. So I tapped the top edge tight against the printer. No more problems.
Posted on Feb 03, 2014
  • Tammy Dunn Feb 03, 2014
    I noticed the piece you remove to clear a paper jam on the back of my printer no longer sat completely flush against the printer. I taped the top edge to hold it flush again and have had no more problems.
Wrinkled Paper
Check paper path,especially near fuser.If all ok fuser is faulty.
Jul 10, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Wrinkled Left front corner
Sounds like you have a burr on the paper guide fins. Look for a small nick in the plastic guides fins which can simply be filed smooth with a small file.
May 26, 2009 | Brother HL 5250DN Laser Printer
PRINTER CRUNCHES AND WRINKLES PAPER WHEN TRYING TO PRINT
ok, in this case you need do:
1) check the roller before the fuser and after it some roller old not enough firction and pressure balance
2) check the fuser press roller it could not has good tough to fuser surface, it should be no gap at all and good pressure balance on the fuser surface
3) check the fuser cleaner which maybe too dirty, or change new one if you have the parts.
4) fuser unit maybe too old if printing pagers over its life cycle
hope this help you and please ask me any time.
May 16, 2009 | HP LaserJet 3030 All-In-One Printer
HP 1300 makes noise and wrinkles paper
open the back door. see if there are small Pisces of plastic the color will brown or gray. if there is then the fuser sleeve has worn out. very common problem. part is a bout $40.00.
Dec 18, 2008 | HP LaserJet 1300 Printer
Paper Wrinkle when Printing
Its time you need to change the Tension roller of the printer.
Dec 16, 2008 | Office Equipment & Supplies
Paper jamed or wrinkled
Dear
this is the problem of hot roller replace it paper jam problem will be resolved.
Nov 25, 2008 | Samsung ML2251N Laser Printer
Paper stuck in printer
Dear Sir,
During Printing paper stuck in printer. I oberved on left corner of the printer their is wrinkles and print is also very bad.
Jun 20, 2008 | HP Office Equipment & Supplies
OKI C5250 Printer
My informed guess without seeing print sample is that your oki needs fuser unit replaced. Look at orange rollers should br smooth no wrinkles.
Dec 20, 2007 | OKI C5200n Laser Printer
Phaser 7700GX Color Printer prints wrinkled pages!
when this occurs the problem is most of the time with the transport roller, fuser / fixing assembly roller.question is the image still toner only and not fused to the paper.
In these areas there is offen a jammed and not removed piece of paper dislodged in the paper path or jammed in the fuser or the transfer rollers teflon coating has perished inspect the areas carefully and remove any found if the unit still is faulty (fanning of paper the fuser would be the first to be replaced are past there usable life) if so then Post a reply
Sep 10, 2007 | Xerox Phaser 7700 Laser Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
141 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
