Question about Panasonic KX-TG5632 Phone
How to connect additional unit to base unit special code ?
Lost one phone so i bought same model on line and lost instructions how to make connection
  • william orts Mar 07, 2009
    i like to add another hand set to my base ill be number 3 how do i do this
    Novelist:
  • 106 Answers
Hello. Here is how you do register your handset below, and a link to the manual its on page 46. The procedure depends on how many handsets you have. If you only had one handset follow the directions below. If you have more than one handset follow the second set.
On the handset push menu, then dial 0 0
On the base, push and hold down the locator/intercom button until the charge light flashes
Press OK on the handset, and it should automatically register in a few seconds.
On the base, press select until you see the intercom number you wish to register it to. Stop there and push the Call button until the charge light flashes
Push OK on the handset, and it should register
Hope this helps
http://service.us.panasonic.com/OPERMANPDF/KXTG5631.PDF
Posted on Feb 28, 2009
Want to add another phone to the base nedd to make it number 3 how do i do it.
Posted on Mar 07, 2009
Gigaset instructions
Base unit isn't connected to a live phone line.
Sep 03, 2014 | Lands Phones
Connecting to base
read the user manual as the handsets have to be registered by the base unit to be connected
the main base is the operational unit
the other bases are just cradles to hold the phone while it is being charged
May 03, 2017 | GE / Rca Visys 25424re1 4- Line Corded...
I lost 2 phones to the dct748 system. I bought 2 more and cannot connect them to the base....how do I tell the base to drop the phones I lost and add the two new ones.
Follow the "System Reset" instructions on page 25 of the manual at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DCT748-2om.pdf
Aug 13, 2011 | Uniden DCT748-4 Phone
Can I connect a CL82409 handset to a CL82409 base system
Yes, and no.
When you buy the new corded base station (CL84109) with 1 handset, that base unit by default is "paired" with only the 1 cordless handset that came with it.
While you can plug both base stations into the landline wall plugs (RJ-11), and when the line rings, both base unit phones will ring and will each operate as independent corded phones would.
But, in this scenario, the cordless phones communicate only through the base unit they are Paired with. The cordless phone paired with the CL84109 corded base unit will not be able to transfer or Intercom between the cordless phones paired with the CL82409 base unit.
However, if you want to transfer the cordless phones that originally came with the CL82409 base unit to work directly with the CL84109 corded base unit, you can likely "Pair" them to work directly with the CL84109 corded base unit for a total of 5 cordless phones to be paired to the CL84109 base unit.
Consult the User Guide that came with the CL84109 base unit for instructions on how to Pair additional cordless phoned to this base unit.
The CL84109 can be expanded and paired with up to 12 cordless phones. So, this should be do-able.
Keeping in mind that the CL82409 will no longer have any phones paired to it and will thus be useless from that point on. (unless you pair more expansion cordless phones to it again)
Mar 13, 2011 | AT&T CL82409 Cordless Phone
It said base no power
Remove then replace the batteries from the hand set. You should now get dial tojo.
Oct 25, 2010 | Panasonic KX-TGA101S Cordless Handset
Have just bought a second hand BT mango telephone with 2 extra handsets.There doesn't appear to be anywhere to connect the phone wire to handsets 2 and 3. Only a socket for the power supply. Is this right?
There isnt a socket to connect the additional handsets because it is not needed. The handsets all use a single line by connecting to the base unit. You need to make sure the additional handsets are registered to the base unit.
For how to do this and anything else look in the manual which can be downloaded for free at http://phone.manualsonline.com/manuals/mfg/british_communications_bt/bt_mango_1_2.html
Aug 14, 2009 | Uniden Cordless Phone
Phone says OUT OF RANGE while on the base and won't work.
The handset has lost the link with the base. This link codes the handset to the base with a unique security code so others with the same phone cannot use your phone line.
If you changed the battery, try disconnecting the base telephone line and ac adapter for a while (1/2 hour or so if possible).
Remove the battery from the handset as well.
After 1/2 hour, install the battery in the handset, connect the telephone line and ac adapter to the base. Place the handset in the charging base and the link should be established. If not, the phone is defective.
joequevedo@charter.net
May 07, 2009 | GE 27992GE5 Cordless Phone
Adding a new handset
You need to register the new handset with the base.
In Global settings De-register the new handset then place it on the main base unit connected. It should then register.
Jun 30, 2008 | Uniden TRU8885 Cordless Phone
Main handset won't work; additional handsets do.
Check that you have the larger power adaptor connected to the base unit.
May 16, 2007 | Doro 530 Twin Cordless Phone
Panasonic KX-TG5632 Phone Logo
381 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
