Question about Kenmore Elite HE4 Electric Dryer
Kenmore HE4 Dryer leaves clothes wet
We have a Kenmore He4 model 110.8586 dryer that usually dries clothes great on a moderate setting. Tonight my wife has had to run a 3rd cycle on a load that is not unusually heavy at all. Vent tube is clear and flowing well. Lint screen is cleaned every load, and I have tried opening the cover just inside the door to get lint out of the cabinet, but I have not really gone after the guts.
Is the moisture sensor possibly clogged with lint? Do the sensor boards go bad on these units? Are they relatively easy to replace. I assemble my own PCs as a reference point.
  • 2 more comments
  • marc796 Feb 28, 2009
    As, I mentioned, the vent is clear and flowing fine. It was cleaned professionally within the last 8 months. Temperature in dryer is OK, clothes are just not drying. I suspect
    1, moisture sensors (though they look clean enogh, need to check wiring
    2. thermistor
    3. main board.
    I also got the dryer into diagnostic mode this morning and checked the moisture sensors with my finger per a tech manual I found online. I got error code 9, which leads to the diagnosis above.
    I'm working the troubleshooting. Thermistor test seems OK. the dryer does not shut down early if I run it empty on heavy duty. Have not checked the wiring to the moisture sensors, but they dont appear that dirty. Suspect the central board, though a tech on another board suggested it's usually the Thermistor.
  • shw104 Mar 07, 2009
    I have the same problem (i think). moisture sensor is going.... dryer works great on timed setting but when we set it to automatic.. clothes don't come out completely dry.
    Where did you find the tech manual online?  Did you resolve your issue?
    Thanks!!
  • stayvisual Mar 21, 2009
    I have a Kenmore Elite HE3 110.82822101 and I have the same problem. Dries fine on timed modes, but leaves clothes wet on automatic modes. Where did you find the tech manual? Have you solved the problem? I've heard anecdotes that the thermistor is the cause, but haven't figured out how to test it.
From the techincal document found in the dryer bottom panel
TEST #4a Dryness Level Adjust
NOTE: If the customer is complaining about the clothes being damp and the moisture sensor passes TEST #4 "Moisture Sensor Test- step 3, then the total dry time can be lengthened by changing from a "Lo" for short auto cycle to "Hi" for longer auto cycle.
1. Activate the Diagnostic Test Mode. Press the following button sequence: MORE TIME ~ LESS TIME -+ MORE TIME --+ LESS TIME - all within 5 seconds
1. In diagnostic test mode, press and hold the Auto Dry Level key for 5 seconds. The dryer will beep and the current auto cycle mode will be seen on the display. The factory default setting is "Lo".
1. To select a different auto cycle mode, press the Auto Dry Level key again. The dryer display will flash and show either "Hi" or "Lo"
1. With the display flashing the selected auto cycle mode press the Start key to save the setting and exit diagnostics (the Start key in this mode does not start a drying cycle). The result will be stored in EEPROM of the control board.
SO EASY JUST TOOK ME 3 YEARS TO FIND IT
Ross
Posted on Nov 22, 2009
Not sure if this is the solution but here is a link to a techincal document I found helpful http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%203980060.pdf. I ran Test 3a (Thermistor Test) and did receive the fault code listed. The next step is to replace and see. I also went through the listed Heater Diagnostics tests and found the process easy to follow. I am hopeful that the thermistor is the cause. Best of luck out there.
Al
Posted on Aug 23, 2009
    Problem Solver:
  • 5 Answers
This link is from the manual.
Try checking the thermal fuse or exhaust fan
Posted on Feb 28, 2009
My electric dryer takes a long time--3 hours or more to dry a load of wet towels
The heating element may have failed. Also, the vent may be clogged.
Aug 15, 2016 | Kenmore Elite HE4 Electric Dryer
I also have a Kenmore Elite Smartheat quitepak 9 HE4. It takes forever to dry in the Auto modes and it still leaves them damp. However the Manual modes dry great. I suspect the Auto modes has some kind...
if its a condenser dryer for some unknown spastic reason we have come across some where 80% of the settings didn't dry the clothes we then found out this how they were suppose to work (dont ask me why still havnt figured that i think it was something to do with ironing and not needing to use steam because they are already damp yeah i know doesnt really make a whole lotta sense to me eitha), you need to look up what cycles actually do what as i found only manual and 1 other setting actually completely dyed the clothes
Feb 09, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 does not dry the cloths all the way.
if dryer is filled with lint or vent line is blocked the clothes will not dry correctly,shop vac is great for this it sucks and blows,vac out what you can see and then blow out the lint from back and on motor,clean out the lint duct,where ever you pull out your lint filter either on top or inside dryer you have to clean out the duct.now go outside and check the flapper,if it isn't blowing open or hardly opening i use a leaf blower and take off the vent line from the back of dryer and blow it out,good luck
Nov 02, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite He3 dryer..fine on timed but leaves cloths wet auto
find the metal sensors in the drum
scratchem up with sand paper
especially if you wash rugs, sneakers , or anything with acyrlic
Oct 05, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer HE4 sounding like a boot is in it.
Check the drum rollers inside the cabinet, go to appliance guru and it will show you how to get to them.
Jan 16, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 electric dryer locked on express dry only......
Shut the breaker off for several hours. Turned it back on.
Nov 30, 2008 | Kenmore Elite HE4 Electric Dryer
Twisted sheets
dry your sheets separately.
Oct 28, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer - heat but not drying
you have thermistor failure/ located inside machine reason for premature heat
Oct 07, 2008 | Kenmore Elite HE4 Electric Dryer
HE4 Kenmore Elite Dryer error code 4e
If you have ever removed the lint filter area completely via the screws that hold the plastics in so you could clean it then remove it again and insure that you plugged in the two wires that go to the strip sensor.. (moisture sensor)
May 16, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
2,567 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
