Question about HP Officejet 5610 All-In-One InkJet Printer
HP Officejet 5610 Installation keeps stalling at Stopping Services Service Print Spooler
  • homeinaweek Mar 02, 2009
    Tried your solutin, but would not restart or stop. "Error 1053 Could not stop the service" displayed Thanks
  • 82 Answers
Goto Start >run>type services.msc there you right click on print spooler and restart it..
Posted on Feb 28, 2009
Opration could not be completed.the print spooler service is not running.
Go to start, control panel, administrative tools, services. Under services scroll down until you find Print Spooler. Under status it should say "Started". Right click on Print Spooler and select Properties. There are buttons on this page. Under Service Status if it says "stopped", click on the start button to start the service.Also, under startup type, it should say "automatic". If it does not, select automatic from the drop down box. Click on Apply and then ok.
Aug 14, 2010 | HP Officejet 5610 All-In-One InkJet...
The printer does not print and the document cannot be cancelled
In run window type services.msc and the go to print spooler option just stop and restart the service.
To clear all pending job
In run window type services.msc and the go to print spooler option just stop and restart the service. And switch off and switch on the printer.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Jul 19, 2010 | HP Officejet 5610 All-In-One InkJet...
Can't print queue
Hi there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 01, 2010 | HP Officejet 5610 All-In-One InkJet...
A print job that I want to cancel is stuck in the print queue and I can't print anything.
Hi there
Mar 30, 2010 | HP Officejet 5610 All-In-One InkJet...
Hp officejet 6500n will install and when you send a print job it shows in the que but will not print
Mar 03, 2010 | HP Officejet 6500 Wireless All-in-One...
The print spooler drive is the problem .my computer keeps asking me to run Windows Xp
log on to www.google.com and type download windows installer 4.5 and then run the downloaded application. then restart the computer and then once it restart, typr service.msc on the run command box or on the search option. then in the services menu find out the print spooler option. then select it and then click on the restart option from the top left corner.
then type cmd on the run option and then open the cmd window.
then type a command -- net stopspooler and then press enter and then type -- net stratspooler. and then try to print and use the printer.
Nov 04, 2009 | HP Officejet 5610 All-In-One InkJet...
Uncleared print job HP J5780 I'm pulling my hair out trying to print to my HPJ5780. With a failed manual duplex job, I tried to delete the print job from the queue. It came up fine as deleting - however...
Try stopping the print spooler service and canelling all the documents.
The Windows Print Spooler is a Windows XP "Service". You can start/stop it via the following steps:
  1. Click on the Start button
  2. click on Run
  3. enter "services.msc" without the quotes and press Enter
  4. Scroll down to Print Spooler
  5. Single-Click on Print Spooler
  6. The details will open in the middle of the window.
    • It probably shows Start -- if so, Start it.
    • If it shows Stop and Restart, I suggest Stop it, then Start it.
Jul 16, 2009 | HP Officejet J5780 All-In-One InkJet...
Hp OfficeJet 5610 All-In-One
Try uninstalling printer software and reinstalling it...if it not work..check whether print spooler service is on or off in services.msc..click on start ...select run...type down in the box -services.msc and check the print spooler services..
Jun 17, 2009 | HP Officejet 5610 All-In-One InkJet...
How do you put the printer online
Right click on the printer icon and then check if an option to "Use printer online is avaialble". If not, refresh print spooler service.
Unplug the USB cable of printer from the computer, turn off printer,
Click Start>Run and in the run window, enter services.msc and hit enter.
This will open the services window. In the right pane of the services window, look for Print Spooler service, right click on it and select Restart. Close the services window and then try to set the status of the printer to online (Right click on the printer icon and then check if an option to "Use printer online"), Try to print from the computer.
Feb 11, 2009 | HP Officejet 5610 All-In-One InkJet...
Installation problem
This printer is compatible with Vista. Try stopping and restarting the Spooler service. Follow the following steps to do this:
1. Click on Start, in the Search box, type services.msc
2. Click on Services.msc in the pane
3. Locate "Print Spooler" service
4. Right Click on the service and click on "Stop" if the service is started and click on "Start" if the service is stopped.
5. If the service was started, right click on it again and this time click on "Start"
If this does not solve the problem, you can visit the following link:
http://support.microsoft.com/kb/927524
The device software is also available at the following link. If nothing works, you can try downloading and installing this software.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=ro&cc=ro&lang=ro&product=3540751
Install the "Full Feature software & drivers"
Sep 29, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
98 people viewed this question
Seeker5211
Seeker5211
