Question about RCA HD52W58 52" TV
The menu keeps poping off and on
The menu keeps poping up until ipush the butten in the front of the tv like 5 times then it quits for a while
    Genius:
  • 1,030 Answers
The cuircit board that contains the front buttons is at fault. you have two options remove the front button panel and use remote only or replace this cuircit
Posted on Apr 24, 2009
Pattern locked
do a hard reset if u cant figure out the code hard reset will deleat everything on your phone push your power butten and your volume down butten at the same time wait 10 seconds let go of the volume butten but keep holding the power butten untill the little android dude appears then form there is easy ! if this does not work or if i must be mistaken just look up on google on how to hard reset !
Feb 25, 2014 | Samsung Galaxy Cell Phones
The monitor's menu keeps poping up
if you manually press the button that accesses the 'menu' at other times, does it work ? (as in maybe the menu button is stuck down ?)
Aug 28, 2012 | E-Machines eMachines Desktop PC
I have a Samsung LCD (LN-T5271F) about 2 years old and lately when I turn it on, it clicks on and off several times before it actually stays and the tv comes onI have a Samsung LCD (LN-T5271F) about 2...
Call Samung customer service, they are doing this repair for free. I had the same problem at 11 months, they replaced the power supply board under warranty. At 2 years I had the exact same problem again and this time they replaced 2 - 50 cent capacitors on the power supply board. It took the repair man less than an hour and he had the replacement capacitors on hand. The original board and the replacement board they gave me had capacitors that were faulty. Hopefully these new capacitors will last. I have to say that I was thinking (no more samsung products for me) but I got excellent customer service and they admit that they had a faulty product and they accepted responsibility.
Apr 26, 2010 | Samsung LN-T5271F 52 in. LCD Television
Black box keeps poping up in the middle of the tv
your closed captions are turned on and in the text mode. turn them off or select cc1 to view that captions
Jan 06, 2009 | Insignia IS-LCDTV32 32 in. Television
KEEPS POPING UP GUIDE PLUS MENU
try to change all the micro switch button on the pcb board
Dec 08, 2008 | RCA F25442 25" TV
CAN'T PROGRAMORIN TV TOA RCA UNIVERSAL REMOTE
u must press and hold the botton titled as code search until the red light is lit. Once you do so, you program in one of the 3-4 digit codes. I am actually dealing with the same delema. I have an Orion tv except i have no clue what the code for it is. If you could help me out with the code that would be great
Nov 09, 2008 | RCA RCU300WBL Remote Control
Tv want go on
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source)
Apr 07, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi ws-55807 tv
call a repair man not much else  you can do, try and unplug for a few min
Oct 17, 2007 | Mitsubishi WS-55807 TV
RCA HD52W58 52" TV Logo
77 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
