Red light flashing
SOURCE: 42" philips plasma
when a television turns off by itself and flashes as you say, it indicates that there is a problem inside the tv. If you keep trying to turn it on you may do more damage. It could be something as simple as a faulty fuse inside. If you have no expierience with electrics I suggest you get it checked out by a professional. I had a similar problem with another tele model and it was the fuse in the back of the tele that needed changing. I did try to this on my own but unfortunatley didn't have the right fuse so i took it to a repair shop and he done it really quickly.
SOURCE: problem with philips 42 inch plasma tv
if you go and download the new firmware it will take care of the red light problem. firm ware upgrade version 1.5.0.0
SOURCE: Philips 42" Flat Screen Plasma - blinking red light 7 times - HELP please!
I had the same issue with 2 of these sets. It ended up being 2 capacitors were bad on the power supply. They are located towards the bottom of the board, you can visually see they were buldging and leaking slightly. I replaced them with 2 I salvaged out of an old computer (of same values) and the tv works as it did before.
SOURCE: I have a Philips 50 inch plasma tv. The light is
I have Philips 50 inch plasma TV purchased almost exactly 3 years ago. Completely out of warranty. Paid 1999 bucks for it new. Now Plasma TVs similar to this are 800 bucks. I figured the cost of a repair tech coming to the house would be around 500 bucks.. so I decided I could "do no harm" and look at the power supply. Sure enough, two 3300 uF caps were swollen.. I am far from a true electrical repair person, and if it were not for the caps being swollen, would have no idea that they were bad. I am however a little bit skilled in soldering. So I ordered replacements for about 8 bucks. The caps were actually only 1.50 ea. but the min order fee and shipping brought it to about 8 bucks.. I got them from studiosoundelectronics.com . They came in today and installed them... to my astonishment, my TV works as good as it did when it was new... I must say that I am dissapointed in Philips.. and will never buy another product from them. If it is out of warranty.. they will not even talk to you.. I don't think it is too much to ask when you spend 1999 bucks on a product from them.. I expected my TV to have more than 2.999 years in life in it. Thanks a million to this site for providing soulutions for folks..
Jeff
Florence AL
SOURCE: my plasma philips tv dosent turn on and red light blinks 6 times
Power supply board have dead capacitors.U know how to solder?Replaced these capacitors that bulge up,puff up or burst open.Should get ur power back.Or replaced a whole power refurbish power supply buy it at Shopjimmy.com,Ebay.com.
