Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
Kenmore vacuum won't shut off
What is the solution? Switch was replaced but still have the same problem.
Unplug it
Posted on Feb 28, 2009
I have Kirby sentria that shuts off while using the rug attachment and won't start until I change to the hose attachment. I have had it in Kirby repair store 5 times, cord replaced. Took it back t
power switch faulty, slow speed terminal inside switch is burnt,hence
intermittent fault, hose uses second speed different lever inside switch
Oct 12, 2012 | Kirby Vacuums
Vacuum won't shut off. Switch appears good. Won't shut off with hose removed.
The "vacuum won't shut off" problem is caused by a faulty triac (electronic component) on the P.C.B. assembly. You have two choices, depending on your handiness:
  1. Easiest: Replace the PCB: P.N.=KC86WBZRZ000
  2. More difficult: Replace the triac: P.N.=BTA16-600CW (ST Microelectronics): http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00002265.pdf
The PCB costs about $25.00 from Sears, whereas the triac costs about $1.50. Sears will not sell the triac - you'll have to find an electronics parts supplier.
Feb 17, 2011 | Kenmore 25614 / 25615 Progressive Bagged...
Dyson DC07 won't shut off
It sounds like the power switch is no good.replace it.
Aug 27, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Vacuum will not shut-off
if it has a foot pedal flick it a few times and see if it goes off.if its a switch unplug the vacuum and move the switch from on to off real fast a few time.if you have any contact cleaner you can try to spray a little into the switch while unplugged and work the switch back and forth a few times .the switch might just be dirty.if you don't hear a click when you turn it ioff and on then the switch is probably bad.please leave feedback.i hope i was some help to you
Mar 30, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Vacuum will not shut off
Sounds like you have wires crossed at the switch. The 2 wires coming in go to the center posts, 2 to the power head & 2 to the main motor.
Jan 31, 2009 | Kenmore 25512/ 25513 Progressive Canister...
VACUUM WON'T SHUT OFF
Most likely the pcb in the cannister is bad, part # KC86WBZRZ000
Sep 01, 2008 | Kenmore 25812 / 25813 Progressive Bagged...
Need a model number to be sure, but alot of the Sears cannisters have a relay and it is found mounted in the motor comparment, it may be sticking in the on position.
Nov 26, 2007 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore model 116 25615506
You can sometimes find the PCB from a 3rd-party supplier. For example, this one on EBay: Mel-Co KC86WBZRZ000
Sep 24, 2006 | Kenmore 25614 / 25615 Progressive Bagged...
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
79 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
