Question about Maytag 24 in. MDB9750AW Dishwasher
Maytag diswasher won't spray water
Today I put Jet Dry in my dishwasher and after that the water didn't come in. The motor was running, the elements got hot, but no water.The diswashwer is 7 years old.
Thanks
  • 360 Answers
Water level/float switch is stuck. (dishwasher is getting a indication the unit has enough water in it to operate)...repair/replace float switch, located in front right corner under bottom rack.
clarkco
Posted on Feb 28, 2009
Dishwasher is 16 months old. Recently, it won't get tea stains from spoons or cups and there is a white film on plastics. I have run unit once with vinegar. I tried using less detergent and no change...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Sep 26, 2010 | Maytag MDBH985AWB / MDBH985AWS 24 in....
I have a Maytag dishwasher. I use Cascade and jet
Check your heating element..
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jul 15, 2010 | Maytag Dishwashers
Dishes won't dry. Is heating element the likely problem. Is it replaceable
What temp is your water? You may need to set your water heater up a notch. Try running the dishwasher on the "sani rinse" since this heats to 160 and see if they are drier. Is your heating element working? During the dry cycle with the heat dry on I would open the door and put my hand next to the element to see if it seemed hot. Maybe it isn't working. Also did you put Jet Dry in the dispenser?and also if the setting is adjustable you can dial it up a notch or two. I also like the Jet Dry Turbo. It makes my dishes dry completly, even plastics and this is on the no heat dry.
If there is no heat, then the heating element may be bad. You can get the part, and view diagram at partselect website.
May 18, 2010 | Whirlpool 24 in. DU920PW Built-In...
Dishwasher doesnt spray the dishes and it no longer drains
It sounds like your jet sprays are clogged. Try a couple of things. Lets start by cleaning the unit with beach and white vinegar. Use a cup of each with not dishes inside. Do not heat dry, ever. Next use a liquid jet cleaner. You should notice a difference doing this. Hope this helps. Let me know if I can help you with anything else.
JimmyC
Sep 30, 2009 | Kenmore 24 in. 16193 Stainless Steel...
Diswasher doesnt clean and leaves
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
May 31, 2009 | Maytag 24 in. MDB6600A Jetclean II...
Kenmore Quiet Guard 3 leaves soap film. This happened before and we realized it wasn't standing straight. Bringing back to balance seemed to fix it. Now it's happening again but doesn't appear to be a...
We have had the same problem with clear glasswear with both Kenmore and Maytag diswashers, in fact any diswasher I have used. It seems to be a problem with diswasher soaps. Either try a different soap (continue using Jet Dry), or do what I do and periodically go over your glasswear with an SOS pad.
Mar 09, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Jennair dishwasher jdb8910aww
Start by puting timer in heat dry for about 4 seconds and see if element got warm. If so check you rinse aid and make sure it is full. I like the turbo dry made by jet dry. If it is empty, this is your problem. about the smell, you would use a cleaner such as diswasher magic made by GE. If element did not get warm, put unit on heat dry and and test voltage at the element. 120 volts present replace element. if not check voltage at thermal fuse for 120 volts. If no voltage there replace timer.
Jul 26, 2008 | Jenn-Air 24 in. JDB8910 Built-in...
Maytag dishwasher DWU7560AAM
Check your water spray bars. I'll bet they are plugged with calcium or something.
Oct 13, 2007 | Maytag 24 in. MDB3700 Built-in Dishwasher
Dishwasher will turn off
Mami, first see if you can put it through a test cycle by pressing the heated dry button six times and then press start. 88 will display. This will test all the funtions of the dishwasher. Let it do it's thing for approx. 20 minutes. Wash motor should run. If it doesn't call for warranty service so you don't void it. It's possible something got messed up during installation. Catriver..post back.
Jan 04, 2007 | Maytag 24 in. MDB8751AWS Stainless Steel...
Maytag 24 in. MDB9750AW Dishwasher Logo
238 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
