Question about Kodak Cameras
Kodak Easyshare camera has lights on like it is on-but shutter is partially closed, lens is down and camera will not turn fully on or off. I may have tried to turn it on while it was lens down on the countertop. After that-all the button lights were on, but the camera will not respond in any other way.
    Genius:
  • Kodak Master
  • 1,099 Answers
Shutters on the lens won't fully open
Stuck automatic lens covers are fairly. But usually it's very easy to fix, without even opening the camera. See this link for troubleshooting steps for this problem.
Dec 14, 2012 | Kodak EasyShare C633 Digital Camera
My sons kodak easyshare cx6230 only takes black/blank images. Screen works, but all photos taken are black. Suggestions please?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 06, 2011 | Kodak EasyShare CX6230 Digital Camera
Kodak M1033 LCD black. entire images on SD black. It powers on and makes audio. Flash works as does the the green light. In other words it seems everything works except viewing, taking, and saving...
It might be easily fixed. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 12, 2011 | Kodak EasyShare M1033 Digital Camera
My Kodak EasyShare C713 suddenly takes only black pictures and shows only a black image on the LCD in live display. Playback is fine for old pictures and movies. Can I replace the picture senor element-...
It actually might just be a stuck shutter. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
Dec 19, 2010 | Kodak EasyShare C713 Digital Camera
Black screen when i turn camera on have changed the memory card, menu works and all my pictures are still there when i go to preview on old memory card, have changed the batteries also. Kodak...
Dec 19, 2010 | Kodak EasyShare C913 Digital Camera
I have a Kodak EasyShare M340 it was working fine earlier today but now when I turn it on the screen is black and when I take a picture it comes out black too, even with flash I can see the saved pics on...
Nov 20, 2010 | Kodak EASYSHARE M340 Digital Camera
My Kodak EasyShare M340 turns on, but then shuts off immediately.
omg! thank you so much Stephan you are th best i just bought the camera for Christmas. Went to the beach yesterday and it sttopped working the method with holding the lens and moving it around i saw some sand come out now it works!!!!!! :-D
Oct 07, 2009 | Kodak EASYSHARE M340 Digital Camera
Kodak Easyshare M340 is fully charged but turns off immediately
I had the same problem after a day at the beach. What I did was get a can of compressed air (from the computer section) and blow air around the lens as I repeatedly turned it on. It took about five cycles, but I eventually cleared whatever was preventing the lens from fully opening.
Good luck.
Sep 15, 2009 | Kodak EASYSHARE M340 Digital Camera
LCD screen is black-cannot take photos
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help: http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 16, 2009 | Kodak EasyShare CX7330 Digital Camera
My Kodak Easyshare LS443 is taking black pictures
Dec 15, 2008 | Kodak EasyShare LS443 Digital Camera
Cameras Logo
48 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
