Question about Acer AL1916W 19" LCD Monitor
Acer 19167W flat screen
This is a wide screen and I would like to use it as a standard screen for adjusting photos but the width is different. Is there any method of narrowing the width to standard? Thanks, Larry
    Novelist:
    Scholar:
  • 108 Answers
Depending on the application you are viewing the picture in you can shrink the application window. You could reduce the size of the viewable area but that defeats the purpose of the wide screen which is to provide a better viewing experience (to quote the marketing types). It sounds like....since the wider screen really has nothing to do with your picture size....you might want to adjust your picture size independent of screens and applications. There are a variety of free products out there that can do this...and some are really nifty...perhaps better than the software you might now be using.
Posted on Jan 24, 2008
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
Picture is too wide to fit screen can not see complete picture
hi there, i don't know your TV brand but this could be of help anyway. there is an adjustment for horizontal and vertical width. you can manually adjust the setting until it fits the picture on the screen. for standard TV it has trimmer in the CRT board. If in your case you have a soft adjustment in the remote control try to adjust it. Learn how the menu works just look for the picture adjustment.
Good luck, please rate and vote.
Mar 20, 2011 | Televison & Video
Screen horizondally pulled right side and screen rolled to left side
hi,
your monitors horizontal deflection side have some problem. you have to check the horizontal width cotrolling transistor mounded on the aluminum heatsik near the lot( line output transistor). also check the three mosfets which adjust the width for different resolutions. there are three such mosfets in the horizontal section.
fist of all replace the width controlling transistor in the heat sink. photo of mosfet and transistor is added for reference. not the exact number.
ok
Jan 27, 2011 | AcerView 99C 19" CRT Monitor
My akai tv is set on full screen
You should have a button on the remote that came with the TV labeled: format , ratio , wide , picture , somthing like that, different brands of TVs call it different things and I am not familiar with the Akai branded TVs, but when you find it just press it as many times as needed to make the picture look as you want it to.
Good luck !
Jan 10, 2010 | Televison & Video
I cant fit the whole image on the screen. The options to adjust only allow me to adjust the width...it wont let me show both the top of my windows open AND the start button.
Your resolution may be set to high on the computer. Or you have a standard screen resolution set and since the monitor is a wide screen, it is cutting it off.
Try a different resolution 1440x900 is what the va1930wm uses.
If using a laptop with a standard type screen on it, you may have to set the laptop to just light the monitor to allow this setting to take.
Since this monitor is a wide screen, it may have options in the menu to stretch or zoom on an image if the resolution is not set to a wide screen format.
Dec 03, 2009 | ViewSonic VA1930WM LCD Monitor
Picture is too wide, how can I adjust the width?
Can't you set/adjust that on menu settings? If not, and no adjustable knob inside for width adjustment. You are now dealing its adjustment with MCU, or its eeprom ic. Check its required power supply it should be within spec. Better to have an schematic if you deals within its electronics parts.
Nov 15, 2008 | Sanyo DS27910 27" TV
PS27115 27" CTC197BC Horizontal Width Adjustment
probably shorted capacitor in pin cushion. and also a diode. is it bowed?
Mar 09, 2008 | Proscan PS27115 27" TV
Screen Widens Out Constantly
you might be getting more supply from regulated power supply if you get wide pictureor width have to be adjusted by width control. but if it stretchs out & lose some of the picture on the right and left edges it might be due to horizontal output section. 1 loose contact in connector. 2 some capacitor might be defective in h/section caution please do not open the set unless you know about high voltage in tv set.
Sep 16, 2007 | Emerson EWF2703 27" TV
Acer AL1916W 19" LCD Monitor Logo
138 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
