Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Power button malfunction
Power button flashes green when pushed the first time, TV does not come on...the next time it's pushed the light illuminates then gets bright and turns off...this happens two to three times...after that cycle pushing the power button turns the TV on. This should not happen. The set is only 15 months old.
    Sergeant:
  • 319 Answers
Sounds like a faulty power supply. Consult warranty guide if its still under warranty, if not, you really need to consider calling a repair technician
Posted on Feb 28, 2009
MY Sharp LC46D62U wont turn on
Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
Jan 07, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
AKAI 32" Power Malfunction
check all 1000mf-16v & 470mf-16v in power supply. may be blow.
May 06, 2010 | Akai LCT2662 Television
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Stand by light flashes red on powering up with remote and the green light flashes approx 15 or times before the screen illuminates.
thats pretty normal, it takes a good second or two to warm up and the display to turn on(at least0, you get the green flashes as you hold for on, 1 sec is a long time at times, lol, be patient, no problem with your tv!
Apr 22, 2009 | Televison & Video
Constant blinking green power light but doesn't turn
This is from my WS65907 service manual.
4. Self Diagnostics
The “Power ON LED” provides an indication of the sets operation, and the possible cause of a malfunction.
1. Initial Control Circuitry Check
Immediately after the TV is connected to an AC power source:
• The LED flashes three times ... indicating the Microprocessor has initialized and is functioning
properly.
• If the LED does not flash ... the Microprocessor is NOT functioning.
2. Error Code Operational Check
Pressing the front panel “INPUT” and “MENU” buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: For Error Code is “24”, the LED will flash 2 times, pause, and then flash 4 times.
3. Error Codes
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
“12” ... indicates no error has occured.
“21” ... X-Ray Protect circuit.
“22” ... Short Protect circuit.
“23” ... Horizontal Deflection failure.
“24” ... Vertical Deflection failure.5. Circuit Adjustment Mode
Most of the adjustments can only be performed using the remote hand unit. Many of the adjustments must
be performed in both the NTSC and HD modes. Video/Color adjustments must be performed in the NTSC
and HD modes, and data must be preset in the 480P (DVD) and VGA modes.
Apr 08, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Green Light Flashing in Power Button
so the sound of mouse click is from the button being pushed.
is the light flashing codes at you in the form of flashing?
looks like you may have a short in the p/s.
Apr 09, 2008 | Philips 55PW9363 55" Rear Projection...
My big screen tv went off and reset it but you push the button and the power comes on and goes right back off
when we push power button the green light flashes as if thinking about turning on and nothing happens, any way to fix this?
Feb 18, 2008 | Televison & Video
Won't power, light goes green 5-10 seconds later red flashing light is basically what's its doing. at 1st i'd power down the tv for a min and then it comes back up with no red flashing going on.
keep pressing the channel up/down button and the screen will come on it may take a few minutes dont use the switch on the side of tv just use the remote buttons u could try the power button on the remote aswell
Dec 18, 2007 | Philips 42FD9954 42 in. Plasma HDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
120 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
