Question about Maytag Neptune FAV6800AW Top Load Washer
I have a maytag neptune LED TOUCHPAD I get getting the message FL. It fills with water and acts like it is going to start and then it clicks a couple of times and then the message "FL" comes up and it STOPS MODEL # is MAH5500BWW
  • 52 Answers
FL code is Failure to Lock. You have a problem with your Door Latch/Lock Assembly
Posted on Feb 28, 2009
Maytag neptune washer code FL and DO
FL means the door failed to lock
DO
means washer door is sensed as being open.
Aug 19, 2016 | Maytag Washing Machines
How do i fix my maytag neptune fl washing machine
WELL THERE ARE MANY THINGS TO CHECK? CHECK WITH A MULTI METER THE DOOR SWITCH, THE FUSE? LOCATED IN PANEL OR CABINET BODY, THE START TIMER MOTOR, SEE PICS BY THE WAY IF THERE IS NO WASH BUT U GET A SPIN CYCLE THEN CHECK THE WATER PRESSURE SWITCH.
Jun 07, 2015 | Maytag Washing Machines
I'm getting an "FL" message.
FL - Failed to Lock
Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
1.Check wire connections in harness leading from machine control board to door lock mechanism.
2.Check solenoid and door lock enable switch in door lock mechanism.
3.Replace responsible component.
You can get it at a local appliance parts dealer near you or online and to replace it you will need to open the door, remove the screws that run though the hinges into the cabinet and the ones straight across on other side, pop the top of the front panel loose and take off, remove the screw at the top of each side and raise the top panel and swap it out; check this DIAGRAM PARTS LOCATION
Hope this helps.
Aug 10, 2011 | Maytag Neptune MAH5500B Front Load Washer
Code reads FL Door will not open. Ran spin cycle on empty to get water out after well went dry.
FL code indicates that the machine failed to detect that the door was locked. Perhaps the controller became confused when the fill failed (due to well). Try unplugging the machine for 15 minutes, and then plug back in. You may get the PF (Power Fail) code, but that is normal. You should be able to start a new cycle from this code.
If the door still will not open, please post back.
Oct 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Have a maytag mah5500bww replaced door lock still do and fl code
fl is usally a water not detected problem,, check ur fill hoses for kinks make sure ur water is on,, possibly have a bad fill valve..
Feb 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
FL message
Is it leveled properly? Is the door latched all the way? Is the water turned on at the valve? Unplug the unit for a few minutes and during that time, unhook all in/out valves and make sure drain hose is in proper position and down in to the drain hole far enough. Plug unit back in and try that.
Apr 19, 2009 | Maytag Neptune MAH6500A Front Load Washer
The Timer Window shows FL and the washer stops after filling.
I unplugged the washer for 20 minutes, plugged it back in, the same FL message appeared, so I slammed the door (as a last effort to attempt to overcome the problem of door failing to close before I would decide to call a repairperson). Following the sound slamming of the door, the washer has worked just fine through the last five loads.
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune door locked
Lid lock failure Replace switch, linkage, lock solenoid or control board.
This is what you will need to check and replace
Feb 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer display showing FL
fl is a over fill. clean the pump out and the sump near the pump is in the back the dran hose goes to it
Nov 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune on/off button wont stay on
You have to investigate where the burning smell came from. Start at the timer and then check the main board. Also check the drain pump.
Oct 23, 2007 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune FAV6800AW Top Load Washer Logo
558 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
