Question about Euro-Pro Cordless Bagless Upright Sweeper - Blue/Gray
The belt broke on my my SHARK Model V15Z and Euro Pro hasn't responded to my request for a new belt w/ directions as how to effect repairs.
  • 3 more comments
  • Anonymous Mar 15, 2009
    My problem is exactly as you have listed. I have bought one of these hand sweepers and in the last 10 days and it has a broken belt on it. I've looked all over the instruction manual and there is NOTHING in that manual that indicates there is even a belt as a part to purchase, let alone how to change it. I made the call to the company and all they could do is read some manuscript to me in 20 sec as to how to disasemble the entire sweeper just to change the belt. What a rediculous design.
  • cowboydadx4 May 07, 2009
    I have the same problem. I can put a belt back in. i only need a source for the belts. where do i get the belts?
  • lulujames75 May 19, 2009
    The belts are available on http://www.sharkvac.com/home.aspx. I have the same problem....How do you change the belt???
  • Charles Jul 25, 2012
    Hi, if you call 800-798-7398 and when asked pressthe number 1 then follow thru to customer service you can place order for belts. They are $9.95 plus shipping, 5 to 7 days for delivery. You can also order hepa filter which is $18.95 plus shipping hope this helps
  • Anonymous Mar 13, 2014
    hand held
Well it's actually not so bad once you realize where they hid the screws. Gently pull outwards on either side of the housing that surrounds the brush and vacuum.There are no screws for this piece it simply snaps off and on. Once this piece is removed you'll see two phillips type screws on the side where the removable hose attaches. Remove the two screws and pull off the molded section they keep in place. The brush will now come off revealing the rotor that the belts slips over. The belt is placed over the rotor and the brush cylinder in a figure eight. Reassemble and your ready to go. Now if Shark will only help customers locate a replacement belt you may find this info useful.....
Posted on Apr 22, 2010
  • 2 more comments
  • grtmd Apr 15, 2011
    Awesome help and description, kj1209! Exactly as you describe!
    thanks!
  • samuline Aug 12, 2011
    kj1209 did a very good job of describing the way to fix the belt! I would ad that it is important to line up the ends of the rotary brush which can be difficult on the second end once you get the belt on. I suggest you put a string or wire around the rotary brush to hold onto and hold the brush in the correct position while you line up the end that will be screwed back on. Once it's all lined up-quick with the screws! then the wire pulls right out of the way.
  • P. Cather Dec 31, 2012
    Thanks Samuline. The string/wire tip was just what I needed. Also I think it's worth noting that the direction you turn the belt to make your figure 8 is important. Make sure that when you are finished the brush is turning from front to back and not vise versa. If it's wrong just turn the belt figure 8 in the opposite directions.
  • Tom Gerbeck May 12, 2013
    The belt on my Shark v15Z also broke after 5months.I called their cust serv@ 800 798 7398 and listened to all of the menu selections. I got to a real live person:a very nice lady named Joanie.They had the belts and she shipped them off to me. I received them in 4 days!
It is simply ignorant that Shark had to make its owners go through so much to replace a broken belt. To bad they don't have an access door for quick changing of the belt. I will try all of the above to get it replaced and repaired and running again. Thanks Kj1209, samuline, P. Cather, and Charles. I will let you all know how it comes out.
Posted on Mar 25, 2013
  • Phyllis Hopkins
    Phyllis Hopkins Aug 23, 2014
    Yes and owners manual is useless....No where does it say how to change the belt...Had to do this search to find out how to do.
Call 800-798-7398 and press 1, then customer service where you can order belts, 2 $9.95. you can also order hepa filter for $18.95, good luck
Posted on Jul 25, 2012
  • Ed ahearn
    Ed ahearn Oct 12, 2015
    I Looked everywhere for a belt for the shark V15Z hand vac. Very hard to find one and between the price of the belt and the cost of shipping unreal. I had a great Idea and it worked found a thick elastic band a bit smaller than the original belt and it works fine, It may not last as long as the orig. belt but very cheep to replace. If you can' find one thick enough put 2 or 3 thinner ones together. Hope this helps
OMG - I am pretty sure we broke the thing trying to get it open. It will NOT come apart!!
Posted on Apr 21, 2010
  • 1 more comment
  • Phyllis Hopkins
    I, also, am trying to get it apart to replace the belt...Got one screw out. and i might add are very flimsy screws. Other screw seem all the way loosen, but won't actually come out.
  • Phyllis Hopkins
    Have only had unit for a few months, and belt broke
  • Phyllis Hopkins
    Phyllis Hopkins Aug 25, 2014
    First answer was helpful, but located 1st screw, got off. was thinking next one was on top of unit, couldn't get screw out. So tried the screw holding wheels on...Housing came right off, now have to order belt
How to change a belt on a shark v15z vac. tks john t
John -
Your vacuum doesn't have a belt - only vacuums with rotating brushes use drive belts.
What problem are you having - why do you think you need to change the belt?
Please rate my solution if you find it helpful.
Oct 14, 2010 | Euro-Pro HEPA Shark EP035 Bagless Handheld...
I received a Euro Pro Shark steam mop but there were no instructions included. Could you tell me where I can get them either online or to request by mail.
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
ii
Aug 08, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Need new brush ( power beater bar) and belts
You're in luck! We carry both the belts, as well as the roller brush for your Shark Infinity model that you listed this repair under.
Here are links to both parts you are requesting:
Euro-Pro Shark Infinity NV30, NV31 Bagless Upright Roller Brush Assembly
Belt Set For Shark Infinity Bagless Uprights, Models NV30, NV31
After you receive the parts, here's a link to the manual that will walk you through, step by step on how to replace both items if you have any questions, or need help:
Shark Infinity Bagless Upright Owners Manual
Hopefully this was able to answer your questions. Please feel free to reply to this email or just give me a call if you have any further questions. If this helped, please be so kind and rate the repair, or leave some feedback for me.
Chris Jones
GoVacuum.com
May 22, 2010 | Euro-Pro NV31 Infinity Vacuum
I need a new roller bar or beater brush for infinity vacuum
Hi There,
Here's a link to that part on our website if you haven't found it already:
Also if you need belts for this machine, here's another link to the belts on our website:
Euro-Pro Shark Replacement Belt Set For Shark Infinity Upright Models, Part 1085F
I hope that this information helped you. If it did, please be sure to rate the repair helpful by clicking the thumbs up icon in the top right hand corner of the repair.
Thanks again,
Chris J.
GoVacuum.com
Apr 14, 2010 | Euro-Pro NV31 Infinity Vacuum
Engonmic hand grip broke off
Check the manuals link and maybe they will replace it under warranty...
heatman101
Aug 24, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Euro-pro Shark steam mop has a broken handle.
I have broken 4 shark handles, have repaired them its a pain. remove the screws on the handle end of the head pop out the broken handle part, drill a 3/16 hole into the part tap 1/4 inch threads use a countersunk head 1/4 inch bolt screw it together put epoxy on the inside to lock threads reassemble. its a pain. two small keepers lock the swivel together pry out with a screwdriver carefully dont loose them. I broke one shark handle when it was brand new. this repair works good if you like alot of fooling around
Jan 02, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Euro-Pro Cordless Bagless Upright Sweeper - Blue/Gray Logo
3,394 people viewed this question
Top Euro-Pro Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
