Question about Dryers
I have ge dryer the timer stop half of the minutes i set the time
  • Anonymous Feb 28, 2009
    keep doing the same thing
  • Janelle Tablada May 11, 2010
    Are your clothes drying?
    Genius:
  • 2,920 Answers
You need to replace the timer
Posted on Feb 28, 2009
GE Front load Gas Dryer Model GTDP490GDOWS won't turn on
Remove the timer nob see if it is cracked, replace it with another nob or use pliers to turn the timer see if that works
Aug 26, 2014 | Dryers
Ge dbxr463gd1ww stops before cycle ends
Sounds like a safety or limit switch cutting it out, if you wait 2 minutes and it restarts then repeats.
Aug 27, 2013 | GE Dryers
Should the heater come on every time the compressor stops running on a ge gss201embww???
The cycle is controlled by an electric or electronic timer: For every six to 12 hours of compressor operation it runs a defrost heater element for about 15 minutes to a half hour.
Oct 31, 2012 | GE Refrigerators
GE basic timer model 15131 manual missing
It's a little backward from what I was thinking. The "Stops" haveto be UP for the timer to be OFF. When you want the timer toturn an object ON you push the "Stops" DOWN.Thanks to geno_3245 for posting the initial information.
Sep 25, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
My dryer is not drying my clothes completely. I have to set it to time dry for at least 120 minutes to get a load of clothes to dry. I can feel that the dry is warm .I usually dry my clothes on optimum dry...
Your dryer has a double set of heating elements
1 side of the coils is probably broken and you are getting half the heat.
This is making the dryer take longer to dry them clothes.
Air restrictions in the dryer and vent can cause the heater control to shut down quickly also.
If you have a bad breaker the power will sometimes work and sometimes not.
If all of these are good you might have a problem with the timer.
Most of the GE timers have leaf switches in the that get a burr on the contacts. The come apart simple enough.
I have more HERE
Apr 01, 2011 | GE DWSR463EGWW Electric Dryer
Sensor and timed dry isn't working. Dryer runs but never stops.
if the timer dont run on the timed dry setting the timer is bad.if it works on the timed setting but not the auto setting you have a heat issue.
Mar 06, 2010 | GE Dryers
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
Top Dryers Experts
