Question about Apple iMac G5 Desktop
Grid surrounding cursor and desktop icons
Recently a black square grid started being attached to my cursor (the cursor is in the upper left corner of the grid).  Each of the icons on my desktop is also surrounded by a square or rectangular grid, with the icon visible underneath it.
  • stuartmc999 Mar 05, 2009
    Thanks for the suggestion, but it did not work.  However, the problem initially started around the time that I accidentally turned on voice-over using shortcut keys.  I saw on an Apple discussion board that many other people had something similar happen at about the same time as me http://discussions.apple.com/thread.jspa...  It appears to be related to iMac G5s with serial numbers that start with W8.  For some of the others, it turned out to be a hardware problem.  However, it seems odd that a hardware issue could explain the same thing happening to many people at the same time.  Also, I do not know if this helps, but starting in safe mode causes the icons to look normal on my computer, but the cursor still has the square grid surrounding it.
  • Anonymous Mar 19, 2009
    i have the same grid around the mouse pointer and the grid obscuring the icons on the desk top and the dash board has anyone got the answer, Apple say its a £600 repair
  • 40 Answers
You have accidentally enabled "Universal Access"
Open System Preferences from either the dock or the pull down menu under the Apple in the upper left hand corner of your screen.
In System Preferences the 4th line down should have icons for "System" one of those icons (usually the right most) will be a blue circle with a person in it. This is "Universal Access"
Open Universal access and turn voice over and zoom off.
Posted on Mar 01, 2009
  • pbeck Mar 01, 2009
  • pbeck Mar 05, 2009
    Very Interesting.
    Usually if it's a hardware issue it won't change just because you are using single user mode.
    Try booting from your original cd and run the disk repair utilities, look to see if your cursor has the problem. If it does, then it probably is hardware. If not there is some kind of damage to the OS.
    Try performing an archive and install if that is the case.
Behroozmohit@gmail.com
Do I understand correctly that you able to access your email but not your calendar? Recently Google has rolled out some changes in their UX for their gmail as well as other sites. Instead of the black menu with a list of their products (drive, calendar, maps etc) there is now a grey icon to the right hand side of the header where your name is. The icon is 9 little squares in a grid. Clicking on that icon opens a dropdown with each of those google products, including your calendar. Does this answer your question?
best of luck
-wallace
Dec 11, 2013 | Computers & Internet
White cursor in upper left corner
Remove ALL media, DVD, CD, USB, etc. Unplug, remove battery, plug in, reboot, at boot start tapping F-10 to do a System Restore, use this procedure to restore to a date before this issue: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&prodSeriesId=3832468&objectID=c01634414#A1 Post results.
Feb 02, 2013 | HP Mini 1000 Netbook
Screen appearing w/pointer and desktop icons
Are they outlined with a square or rectangular box? If so, click the Apple menu (top left of your screen), click System Preferences. Click "Accessibility". Make sure "Voiceover" is OFF.
Let us know if this helps solve your problem.
* If you find this information helpful, please rate my solutions and recommend me. Thanks! *
Apr 19, 2010 | Apple iMac G5 Desktop
I have a double picture and the red apears to be
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Dec 07, 2009 | JVC AV-56WP74 56" Rear Projection...
Grid surrounds cursor and icons
Hi Gabrielle
Go to System Preferences and select 'Universal Access'
Switch ~OFF 'Voiceover'
Oct 21, 2009 | Apple iMac G5 Desktop
Grid surrounds icons and follows cursor
Hold down "control", while at the same time, move your scroll wheel downward.
Sep 27, 2009 | Apple iMac G5 Desktop
I am no longer able to rearrange desktop icons freely
You might have Auto Arrange icons ticked.
Right click on a clear area on the desktop, select Arrange Icons By and then click Align To Grid.
May 03, 2009 | Dell Dimension 4600 PC Desktop
Toshiba 47" 1080P LCD 47HL167
Replace the convergence IC and check power resistor for leakage, if values are not exact replace them. Once the parts are in place perform the alignment.
Thank you & post back again if you need additional info.
May 07, 2008 | Toshiba REGZA 47HL167 TV
Apple iMac G5 Desktop Logo
1,350 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
