Question about Tally T6218 Matrix Printer
How do I clear a "config 1" error on my tally t6218 printer
Printer refuses to print and gives a config 1 error message.
  • 741 Answers
Click start>run>type services.msc. The services window will come up and you can right-click on the Print Spooler and then click Restart. This will clear the print queue and hopefully allow you to print. Good Luck. Let me know if you have any questions.
Posted on Feb 28, 2009
Tally t6218 prints and stops with no errors
The power supplies are known for shutting the printer down without any error if that is the symptom, replace the power supply.
TALLYGEN 084435 POWER SUPPLY ASSY T6218 Refurbished
If not let me know exactly what it is doing.
Dec 28, 2015 | Tally T6218 Matrix Printer
CONFIG 1*
If the printer is showing "CONFIG 1*" this is not an error, this message is simply advising that Menu CONFIGuration 1 is selected hence the * beside the message.
Assuming the settings in CONFIG Menu 1 are correct if you send data to the printer in the correct format it should print.
May 03, 2013 | Tally T6218 Matrix Printer
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
Tally Printer the error is some times Hammer
In the T6215 Maintenance Manual the fault message: Hammer Voltage has been replaced, in the T6218, with:
Hammer Voltage 1
There is a new fault message for the T6218. It is:
Hammer Voltage 2
Explanation: A high resistance coil fault has likely occurred in one or more of the hammer coils
Note: This fault message will have been preceded by printing slow-down attempts associated with On-The-Fly thermal monitoring of hammer bank temperature.
Corrective Action:
Check the hammer bank for defective hammer coils.
Confirm that hammer drive board is functioning properly.
Apr 05, 2010 | Tally T6218 Matrix Printer
Tally6215 "Config 1" Error
The 'Config 1" message on the T6215 is not indicating an error message, this message is simply indicating that Config 1 of the 10 configurations that you can set on the T6125 is loaded.
With the Config 1 message loaded you should still be able to print so long as the printer is ONLINE and does not have any other error lights on.
If the printer is not printing I would recommend printing a configuration page to check the printer is working OK.
To print a configuration page follow these steps;
Put the printer OFFLINE
Press the MENU BUTTON
Press the DOWN ARROW to HELP
Press ENTER
The printer should print a configuration page, if this prints correctly I would recommend checking the settings in particular the Interface and Emulation settings.
I would also recommend checking connectivity between the system and the printer to check the print jobs can get to the printer.
Also check the system to ensure the correct printer driver and printer setup is being chosen.
Mar 26, 2009 | Tally T6215 Matrix Printer
My Tally T6218 gives the following error message shuttle fault
may shuttle belt is lose or it is not in proper place. check the shuttle belt and clean the shuttel sensor , your problem will be solve.
Nov 30, 2008 | Tally T6218 Matrix Printer
Platen open error message on tally t6218 line printer
there are two reason behind the problem . 1 .the problem may come from the logic board.
2.and the platen sensor. change the platen sensor. if not solved change the board.
Sep 16, 2008 | Tally T6218 Matrix Printer
Print stops after 2 pages !
Hi my tally printer 6218 giving Ribbon motion fault, what could be done to remedy this error message ?
Jan 19, 2008 | Tally T6218 Matrix Printer
Hammer voltage 2
it prints for about two minutes then starts slowing down and then stops printing showing an error of : hammer voltage 2
Sep 05, 2007 | Tally T6218 Matrix Printer
Tally T6218 Matrix Printer Logo
176 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
