Question about Eureka Boss SuperLite Bagless Upright Vacuum, 405AVacuum
  • 328 Answers
Check two things with this model: if the top slider button has been activated it will turn the brush roll on. If not then you'll have to remove the sole plate and check the sides of the beater bar - sometimes this will get jammed and refuse to turn because clogging of dust or tangled hair/carpet thread takes up the thread wheels at the sides. Sadly this model has a permanent toothed drive belt that can't really be replaced by the owner. However check the slider control on the top of the main body / handle first before doing anything - as you know it has a two option slider - switching on without the brush roll function and switching on with the brush roll activated.
Posted on Mar 06, 2009
How can I use my upright as air compressor to inflate air mattress
It would be difficult because your upright does not have an exhaust port where you can hook up a hose. You would have to attempt to funnel the air from the exhaust filter into a hose or tube.
Mar 08, 2014 | Eureka Boss SuperLite Bagless Upright...
How to remove the eureka the boss super lite filter
Push up on the black slide button just above the dump cup and hold. With your other hand remove the dump cup. Once you have the dump cup removed, pull up on the rubber section of the filter to remove and clean the filter.
Feb 13, 2010 | Eureka Boss Superbroom Bagless VacuumStick...
My vacuum caught on fire when I tried replacing the belt and when I tried to unclog it. Is this common for other people, or am I just very lucky?
Today sadly to say it is common for most vacuums. The quality is so poor that the roller brushes don't last long and can burn up belts as fast as you can replace them. Next time you want to buy a vacuum, turn it up side down and see what the roller brush is made of. If is is steel then buy it, if it is wooden or plastic forget it.
Nov 27, 2009 | Eureka Boss SuperLite Bagless Upright...
Eureka boss power plus
I had this same problem. The brush roll wouldn't spin, smoke came out, and it smelled like burning rubber. I changed the belt thinking that would fix the problem but it didn't, so I took the belt back off and checked the motor shaft in the back and found a whole bunch of hair wrapped around the shaft. Once I cut out the hair with some scissors and replaced the belt, everything worked like normal. I hope this helps.
Sep 01, 2009 | Eureka Boss SuperLite Bagless Upright...
Roller brush will not turn on Eureka "The Boss Power Plus" 12 amp
Depending on the model there will be a couple of screws on the top plastic cover. The cover lifts off and the belt is then serviceable. On some models you will need to remove some parts on the bottom too to get the roller out.
In any case just look for screws that hold the covers on and explore a bit. You can't break anything.
Jul 30, 2009 | Eureka Boss SuperLite Bagless Upright...
Can't find manual needed to see why brushes don't turn Eureka Boss Whirlwind Lite Bagless Vacuum 450A
Hi Please visit and enter 450 into the first box on the page where you put the model number. This will gve you two options, one is for the PDF user manual, the other for parts.
Alternatively if you are trying to get into the drive belt locate four screws, two at the front and two at the back on top of the hood. Once undone, the hood should pop off easily to reveal the brush roll and drive belt. If the belt is intact check that the dust channel is completely free of blockages.
Dont forget to rate thanks!
Mar 28, 2009 | Electrolux Vacuums
Belt location
If you torn the macine over, at the bottom of the sweeper you will see the belt on on side. You have to take the bottom part apart and remove the brushes to replace the belt. I hope this helps.
Jan 21, 2009 | Eureka Whirlwind 4388 Bagless Upright...
Belt broke
The belt number is 60957, There should be some screws that you remove from the bottom and the whole bottom nozzle will come apart, then you can change the belt.
Feb 27, 2008 | Eureka Boss SuperLite Bagless Upright...
Vacuums Logo
585 people viewed this question
Top Eureka Vacuums Experts
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
