Question about Crosley CDE6000 Electric Dryer
Dryer belt replacement
Able to get belt on but when i turn the drum the spring comes undone. i have tried it turing it clockwise and counter clockwise with the same thing happening each time.
    An expert whose answer gotĀ voted for 100 times.
  • 135 Answers
Here's a URL to a website showing an exploded view of the parts in your washer, and I noticed that one of those drawings shows the proper belt path for installation: --> Hope this helps! :)
Posted on Aug 06, 2007
Change belt on washing machine
Go to and enter the model number of your machine. You will be presented with a list of common replacement parts and may be able to view a video showing the procedure.
Feb 19, 2015 | Whirlpool Washing Machines
I have a samsung dryer model DV209AEW/XAA. I "hand rolled" (dryer was off) the drum to get at a particular pair of pants from the dryer and I heard a loud bang. When I tried the dryer with...
This photo is from a Samsung DV409AEW, but I assume they are quite likely the same. I also turned the drum (clockwise, which is the wrong way) and the same thing happened. The thud in my case was the spring that holds the tension pulley arm in place falling to the bottom of the dryer. If your situation is the same, spinning the drum caused the belt to come off of the idler pulley and the tension spring fell off. It seems to happen frequently based on web searches.
Again, assuming the DV409Axx is the same, you can get at it from behind. There should be 3 screws (2 on the top and 1 on the bottom) of the plate that holds the vent pipe output assembly. That assembly can then be removed. There will be a vent pipe extension that comes out with the assembly.
Once inside, see if the spring is off, and if so re-attach it per the photo below. It is counter-intuitive that the spring pulls the arm down, rather than to the left. Hopefully this will be your issue.
Putting the pipe extension and outlet assembly back in can take a bit of fiddling... but if you lay on the floor, you can actually shine a flashlight in the crack to see what you're doing.
Hope this helps!
Nov 15, 2010 | Dryers
The roller doesn't spin, though there is heat coming out. What can be the problem
If the dryer is heating, but the drum fails to turn, this is usually caused by a broken dryer belt. To replace the belt on a Whirlpool Duet series dryer, you need to follow these steps:
1. UNPLUG the dryer before servicing. Dangerous voltage is still present inside the dryer even when it is turned off.
2. Remove the top panel of the dryer by locating and removing the screws holding the panel in place in the rear of the dryer. With the screws removed, the panel will slide back, then come off. The belt should be present tightly wrapped around the drum. If not, its likely the belt is broken and lying in the bottom of the cabinet.
3. Open the door and remove the lint screen. IMPORTANT: You will not be able to remove the air blower cover with the lint screen in place.
4. Remove the lower toe panel directly below the door. The panel comes off by locating and removing the screws under the bottom front edge. With the screws removed, the panel will drop down, then come off.
NOTE: Propping the front feet of the dryer up can provide you better access to the screws (a 2x4 works well for this).
5. Disconnect the auto dry sensor plug (usually yellow wires with a white plug to the right of the blower assembly) and any ground wires that may be connected to the front panel.
6. Remove the air blower cover by locating and removing the mounting screws.
NOTE: This is a good time to clean the blower fan housing, squirrel cage motor and dryer interior cabinet.
7. Locate the two screws that hold the operator console in place. There should be one on each side under the top panel. Remove the screws and carefully lift the panel straight up.
NOTE: You do not need to disconnect the ribbon cables. Carefully lay the console across the top of the dryer out of the way.
8. Disconnect the door switch connector plug and remove the dryer front panel by locating the four screws that hold it in place. Loosen the two screws along the bottom of the panel and leave in place. Remove the top two screws and lift up and turn the whole front panel slightly counter-clockwise to release the drum supports from the dryer drum.
NOTE: Make sure the dryer door is closed when removing the front panel to avoid damaging the door hinges.
9. Reach in behind the air blower with both hands and pull the idler pulley to the right with your right hand to release the tension and remove the dryer belt (if still attached) from the drive motor.
10. Install new belt around the dryer drum making sure the ribbed side faces towards the drum.
11. Reinstall the dryer belt by releasing the belt tension pulley again (as described in step 9), then, with your left hand loop the belt over the drive motor pulley. Release the idler pulley making sure the belt rests on the drive motor pulley. You should feel the belt tighten with tension.
NOTE: If you need further clarification on how to properly route the dryer belt you can go to and click on the "Repair Help" link at the top of the page. On the following page, locate the "Dryer Belt Diagrams" link under the Special Features section. Refer to diagram K.
12. Reinstall the front panel by turning it slightly counter-clockwise and aligning the front drum supports under the front of the drum. Once the supports are under the drum, turn the front panel clockwise and lift up, placing it on the bottom two screws. Reinstall and tighten the top two screws.
13. Reinstall the door switch connector plug and reinstall the operator console. Use caution not to put too much stress on the console ribbon cables.
14. Reinstall dryer top panel.
15. Reinstall air blower cover and reconnect the auto dry sensor and ground wire.
16. Reinstall toe panel by inserting the top portion first and pushing up. Push lower portion of the panel in place and reinstall screws.
Replacement parts (if required) can be purchased at any of the following web sites:
Prices will vary between sites so shop and compare. The drive belt part number for the model you listed this question under is 661570.
NOTE: This model dryer has a broken belt switch mounted on the belt tension puley. If the pulley loses tension form either a broken belt, or a tension pulley spring that has come loose, the dryer will stop tumbling. So, if the belt is still intact, check the tension pulley for a loose or missing tension spring. The first three web sites I listed have exploded view parts illustrations to assist you locating and properly identifying any part you may need. Refer to the "Cabinet Parts" section for an illustration of the belt and drive components. The belt is listed as item 30 and the belt switch is listed as item 5.
I know this may seem like a lot, but its actually fairly simple if you follow the steps provided. Read through everything before attempting any repairs. If you have any questions, please post back and let me know. I hope this helps you.
Jul 14, 2010 | Whirlpool GEW9250 Electric Dryer
have you try to rotate the drum when belt is attached or installed, unplug your machine and try to spin it manualy at the back opening where you can access the mechanical part
try to use the belt when turning it counter-clockwise see if it will turn the drum, if not then the fproblem is the bearing
Nov 08, 2009 | Whirlpool LGR6611L Gas Dryer
Dryer drum will not spin. motor hums when button
either the belt is broken that turns the motor or thr idler tension pulley is bad, if it were a motor problem the breaker most likely will trip
Nov 01, 2009 | Dryers
Dryer spins counter clockwise
When installing new belt the belt comes off the right side of the drum and through the idler and around the motor shaft, then up the left side
Jan 07, 2009 | Whirlpool LGV4634JQ Gas Dryer
MDE5500AYW Drum belt
I dont think you broke the belt, I think it may have just come off the belt tensioner. Take the bottom of the back panel off and I think you will see it hanging in there. Just put er back on.
Nov 01, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Fitting tumble dryer drive belt
Looking from rear of dryer,one spring on motor is for tension,therefore put belt around drum(groove to the drum surface).Then rotate the motor firmly clockwise tensioning the spring,take belt from right of drum over tension wheel then put grooves of belt on shaft of motor.Release motor to tension spring,job done !!!!!
Mar 28, 2008 | Dryers
Crosley CDE6000 Electric Dryer Logo
127 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
