Question about Toshiba Satellite A135-S2386 Notebook
My toshba satteklite is giving me the ubiquituos"disk read error occured press crtl/alt&del" no stange noises, kjust stopped working one day, these toshiba hard drives r not easy to replace any suggestions?
    Scholar:
  • 53 Answers
Well, you can use any laptop 2,5" inches hard drive with the same connector(SATA or IDE). Brand means nothing.
it just needs to meet the height(thickness) requirements to fit in the little cradle that holds the drive in place in the chassis
this number can go from 8,5 mm to 12.5mm I suggest you find one the same size of your old one for better compatibility though a smalled drive will definitely fit with no problem(but might vibrate or rattle a little bit).
the swap process is very easy and can be done by anyone with a little patience.
usually any laptop has one or more little doors secured with a screw on bottom of the chassis. locate the one that covers he hard drive and open it. the hard drive will be laying under it inside a metal cradle to secure it in place. you need to remove the screws and then slide out properly the cradle. then replace the drive and follow all the steps backwards.
I suggest you do this only if your warranty has expired or if it does not cover the hard disk drive.
Remember than faster the drive spins faster is its operation, I suggest 5400rpm though these days 7200 rpm drives got quite reliable. HDD is a cheap component for about 60-70$ you can get a 250-300 GB one...
Posted on Feb 28, 2009
    President:
  • 2,653 Answers
They're VERY easy to replace.
Looks like it's on the bottom left according to this picture.
http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/take-apart-laptop/toshiba-satellite-A135-06.jpg
Just remove the screws on the cover and then swap the hard drives.
Let me know if you need any more help.
Best of luck!
Doesnt startup,but rather displays "A disk read error occurred.Press Ctrl+Alt+Del",it does that again and again
maybe a usb device plugged? if not try in bios\boot sequence to set cdrom - hd - usbdev. then try to boot with the puppy sturdust linux cd. if it work is just the internal hd; format it and reinstall. hope it help bye
Nov 16, 2013 | Acer Aspire one D270-1375 Intel Atom N2600...
"A disk read error occurred Press Ctrl+Alt+Del to
Most likely the hard drive is failing, run diagnostics on the hard drive if you have a resource CD. Or you can download them from support.dell.com
Jul 21, 2011 | Dell Latitude C810 Notebook
Vaio computer PC wont start up get a disk read error press crtl-alt-del to restart though when i do it still does not work
you have a corrupted system, OS is not working...need to re-install OS.
if u r on WinXP then get help from my site
www.sureshayyar.110mb.com
Sep 25, 2010 | Sony VAIO PCV-J200 PC Desktop
I have a optilex 170l dell computer i replaced the hard disk and now i gives me a disk read error occured press ctrl+alt+del to restart
Press ctrl+alt+del to restart is just an instruction. Did you do it?
What happened? Was it read? Tell us more. Send your e-mail for
us to give you our feedback.
By the way, assuming that it did not work, Your hard disk must be
configured to your PC, by running a software driver for your new hard
disk. You can download it from the internet by running search " hard
disk driver". Just specify the brand.
Oct 17, 2009 | Dell Computers & Internet
My cisnet computer keep reading disk errors.i tying to install window xp. it also system window 32 problems. is a missing files. how do you fix it?
u need to format using a windows 98 sec boot disc. place the floppy in to the comp. switch on the comp. let the disc run, making sure your bios is set to boot floppy first. when disc is finished setting type fdisk then when finished delete drive by pressing 4 .add drive when finished by pressing 1 and following the insturctions. when finished press crtl+alt+del let the comp, reboot the when the disk as finished loading type format c: press yes let it run press crtl +alt+del again then take out floppy disc and put in winpx . as this sounds like you have a virus in your registery
Aug 03, 2009 | SimpleTech 320GB SimpleDrive External by...
Problem with a disk read error
There are a couple of possibilities.
1. The hard drive is defective.
2. The operating system is corrupt.
The easiest way to test this is to run the restore cd that came with the computer to reload Windows.
If you get this error while running the restore cd then you will need to get a new hard drive.
Jan 03, 2008 | Computers & Internet
Toshiba Satellite A135-S2386 Notebook Logo
135 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
