Question about GE 24" Built-In Single Gas Wall Oven
I need the squematic wiring GE 24" Built-In Gas Oven
I have GE 24" Built-In gas oven, Model JGRP17BW38B Serial D7608522R, 120VAC, 60HZ.
I need the squematic wiring so I can make the connection wire to lead terminals control. The old control was replaced by one new and the squematic cables connection control was not made. The new control is TORISAN Thermostat model RGB04XP015CN-AB and the replaced was GE WB27T10267.
I would appreciate help me.
F Fernandez
I have the same problem -- did you ever get this question answered?
Posted on Jun 14, 2010
We have a Frigidaire Wall Oven that shows Err F3 - no buttons work. Model FSC88B-4 . The Oven temperature sensor measures at 1089 Ohms. There is 5 VDC on the control board. Tried resetting by removing the...
The sensor checks good. The only thing left to check the wiring between the control and the sensor. Check this for opens and shorts. If all checks good you will need to replace the EOC electronis oven control / clock. You can get diagrams and illustrations at by entering your model #. All parts come with installation instructions.
Apr 15, 2010 | GE 24" Built-in Single Electric Wall Oven...
I bought a used 24 inch GE gas wall oven, changed it over from natural gas to lp and it will not ignite they glow red but no flame
Many times, unless you have the universal, the orficies have to be changed. From nat to LP. they do make a universal type.
Dec 15, 2009 | GE 24" Built-In Single Gas Wall Oven
Maytag gas oven has an F3 code and beeping. Model # CGR3740ADW.
Hi. This code is the result of a shorted, or open(circuit) oven temperature sensor device. You will need to Check the sensor harness and harness connection between the oven sensor and oven control. Replace the oven temperature sensor (RTD) if wiring is ok.
Dec 11, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
I do not have wiring diagram for this ERC. They had never been made available online by GE.
Here GE contact contact 1-800-626-2005.
All I can give you is the oven diagram below:
Nov 06, 2009 | GE 24" Built-In Single Gas Wall Oven
GE Gas built in oven Model JRS14 will not heat up
The bake ignitor has failed.Turn off the gas supply. Remove the racks. Then remove the bottom pan cover in the oven to access the ignitor. Place a amp meter on one wire of the ignitor.Turn the BAKE switch on. If it reads less than 3 amps,replace the ignitor.
Oct 30, 2009 | GE 24" Built-In Single Gas Wall Oven
Maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
Jun 25, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
GE Gas Built-in Oven model JGRP17B Door Replacement
pull out the bottom drawer you will find a plate on the left side pillar of the drawer opening the model # and, serial # is there this is all that is needed to order a new door glass
Apr 21, 2009 | Ovens
Temperature is wrong
Many ranges show a beginning temperature that is higher than actual temperature, then the gap closes as it heats up.
Use a accurate oven thermometer to check your temps.
If it is faulty, it will not recalibrate to offset 200 degrees. You will have to replace the ERC.
Mar 20, 2009 | GE 24" Built-In Single Gas Wall Oven
GE 24" Built-In Single Gas Wall Oven Logo
303 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
