Question about Bernina 1008
Thread wound around disc of take-up lever on bernina 1008
Thread is wound around the disc of take-up lever on bernina 1008. There is so much thread wound around a disc (I think that's what it is) on the arm of the take up lever (inside the machine) that it is preventing the take-up lever to move properly. It seems to make the take-up lever be off balance. Consequently, when I turn the flywheel, the take-up lever hits on the plastic **** (on outside of machine) therefore it will not sew. I think if I could remove the top cover I can remove the thread. I can not find any screws on the top of the machine to remove the cover. There are some plastic spots that look to be where you press in and it releases something, but when I press them, nothing happens.
My question is two-fold. First, how do I remove the top cover and second, what would cause the thread to wind around the disc on the arm of the take-up lever?
  • 202 Answers
Hi, there is no top cover on this machine. First the side cover has to come off then the back cover. Under the back cover there is a rigidity plate with many screws that has to come off and then you might be able to get at the take up lever mechanism. I'm not saying you can't do this but it might just be the time to have a tech go in and service this machine completely.
The thread must have slipped out of the end of the takeup lever and wound in the mechanism. It happens.
If you feel you want to do this yourself feel free to contact me and I can walk you through getting the covers off.
Possibly you can get a tweezers or needlenose pliers in through the front slot, grasp the thread and turn the handwheel bit by bit and see if it will unwind as you pull it out.
callnrick@yahoo.com
Posted on Feb 28, 2009
Bernina 1008 thread tension is way too tight
Remember to raise the presser foot before you begin the upper threading process. May not be the problem, but you might try changing the needle and the type of thread you are using. Good luck with getting it fixed. Going back to the service provider is probably the best bet. You already paid for the service and they didn't fix the issue. Be sure to bring them a sample of how it is (mis)sewing.
I also pull the bobbin thread to the top of the fabric and gently hold both threads behind the presser foot until the machine completes the first stitch. That helps prevent the "thread nest" that is frequently created under your fabric. This is a procedure that is taught by Bernina instructors, and it does work.
Jun 23, 2015 | Bernina 1008
Bernina 1008 thread bunching on bottom
"Nesting or Rat's Nesting" on the bottom side of Bernina sewing machines (CB hook type) is generally the result of very loose top tension. If the problem is found in newer sewing machines such as machines made after 1986 (serial numbers beginning with 26xx xxxx), may have an older Bernina bobbin case in the machine. The problem with the older bobbin cases is that the rounded projection of the latch on the left side of the casing will catch thread, preventing easy thread escapement during the take-up lever cycling resulting in loops on the bottom side and or thread breakage, etc..
Note:....Timings and modified latch geometry's were applied to later models to allow for good thread escapement. Older Bernina cases cannot be used on newer machines but newer cases can be used on all CB hook Bernina machines.
Additionally, Chinese copies of the Bernina/Cerliani OEM bobbin are rampant and can cause sewing issues. Always ask for OEM Bernina cases.
Note the following trouble shooting logic:
1. The center tension disk that is visible through the thread slot in the top cover of most machines must be positioned exactly in the middle of the top cover slot. By loosening the fixing screws on the top tension mechanism, one can adjust the disk position to center.
2. It would be a very rare situation for the top tension to change whatsoever from the (red center marking) factory setting. The most likely cause of loose top tension under the normal center mark position, would be accumulated lint, thread, or a sticky substance between the disks. This would prevent the tension compression disks from applying an even tension on the sewing yarn (thread). Often this can be blown out with compressed air when the presser foot lever is lifted in the up position. In some cases, soft drinks and other sticky or corrosive liquids can find their way between the disks. In this case, the tension assembly must be removed, disassembled, and the disks cleaned and polished.
3. Check the facial surfaces of the bobbin case for corrosion, and sticky substances that prevents the thread from easily sliding over the bobbin case.
4. Check that the spindle of the hook body is not bent or warped, causing the bobbin case to wobble, thus creating an intermittent pressure on the hook race cover at the moment that the thread is trying to escape over the bobbin case finger. (Replace the hook body)
5. Inspect the undercut on the hook body spindle for thread wrappings and knots. This condition can cause the bobbin case to press hard against the hook race cover, hence hindered thread escapement .
6. Exceedingly tight bottom tension can cause some problems as well. ( If you don't know how to adjust Bernina bobbin cases to factory settings, please ask).
7. Hook timing, (loop lift) can be out enough to affect thread escapement. This is typical of newer machines made after 1986 since Bernina no longer made fixed timed machines like the earlier Swiss made models. The later made models have timing components that can slip under stressed machine mechanics.
SewTechnical Home ">
Feb 13, 2014 | Bernina 1008
I have threaded up my machine and have started to sew. The thread on the back of the fabric keeps catching and bunches up. What's going wrong?
try a new needle
keep a check on the thread take up lever that the thread doesn't come off of it
rethread the machine to make sure that the thread isn't catching on anything
clean under the needle plate for loose thread or lint & in the bobbin area also
make sure the bobbin is inserted correctly
Aug 04, 2011 | Bernina 1008
My thread keeps breaking on my Bernina 800dl serger
Is the thread aerial raised up ensuring a good thread flow?
Which thread is breaking, needle or looper? If you can establish which thread is breaking, then check that tension dial, turn it to zero and clean between the tension discs by sawing a selvage edge of cotton fabric offcut between the two discs to remove any fibres, dirt or debris.
Now turn all dials to zero, unthread the needles, and pull on each thread, feeling if there is any resistance. If there is, check back through the thread path and find where the thread is catching.
Serger threads flow very fast and the thread path can't be compromised or the thread snagged.
Check the thread path from the cone to the sewing foot, and ensure that the thread is not catching on something, or getting caught around the cone, cone holder or aerial somewhere in the path. Look at the thread cone, has the thread feeding off got looped around itself somewhere? Open up front of the serger and look at the thread going through the loopers, is something misthreaded here, sometimes there is a part that slides on a looper to make threading easier, just check it is all threaded up correctly. There should be a threading diagram inside the serger cover usually showing the paths.
Rethread the needle(s) and pull all the threads under the pressure foot, lower the foot, turn tensions back to 5, then chain off and test sew.
If no joy after trying all this, I'd take it for a ride in the car to the shop.
Apr 14, 2011 | Bernina 1008
I have a Bernina 1008 and I love it, but every time I try to sew with it lately, the bottom thread wads up and makes a terrible mess. It will sew OK for a little bit and then the bobbin thread sort of...
Hi, I'm guessing you have the bobbin in the bobbincase upside down and its turning the wrong way. Or the machine is not thread correctly. Possibly there is junk in between the tension discs at the top that the thread goes between. Just some thoughts.
Rick
Sep 30, 2009 | Bernina 1008
I have a Bernina 800 Serger and I am trying to thread it.
You might take a look on ebay item 150416413591
Sep 07, 2009 | Bernina 1008
Bernina 1008 sewing machine making huge clumps of loops on underside of fabric. have tried moving screw on bobbin in two opposite directions without a sign of improvement.
Hi: You have threaded the machine incorrectly. Rethread the machine with the presser foot up to the needle, pull the thread (loose) and drop the presser foot while pulling thread, thread should get tighter, then thread needle and machine will work fine. Make sure the top tension is set at where you normally have it, probably about #4 or #5
Jan 08, 2009 | Bernina 1008
Bernina 1008 - tension problems
Make sure the presser foot bar is UP before you thread the machine, otherwise the thread doesn't connect propertly with the tension discs. Top thread should reel-off in clockwise direction.
Jan 02, 2009 | Bernina 1008
Threading a Bernina 900
Place the thread spool on one of the two thread guides. Bring the thread across to the notch on top of the machine guide it to the left and down the front of the machine. Directly under that threader close to the needle wrap it down under and go back to the top right to left then go to the top lever in the up position use your wheel to the right , wrap from right to left going down and threading. Wrapping just means placing around. Now for the bobbin. take casing out wit bobbin thread counter clockwise place in casing and release handle of casing put in machine making sue it is locked in. THen go fishing.
Sep 22, 2008 | Bernina 1008
Sewing Machines Logo
408 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
