Question about Texas Instruments TI-15TK Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
You can use the calculator with it on the screen; the indicator simply tells you that it's in a fixed-decimal setting. To remove the fixed-decimal setting, press FIX . (decimal point).
Posted on Sep 29, 2010
I down loaded the update 2.1 for my Ti Nspire and applied it to the calculator and now my calculator won't load past the operating systems screen and I can't connect it to my laptop. Please help.
what you need to do is delete the current OS and load the 1.7 v
if you canot connect the clac to the laptop it needs and hardware reset this can be done only by technician.
if you want to fix the calc let me know
Mar 02, 2011 | Texas Instruments TI-Nspire Graphic...
My ti-89 screen is frozen and wont accept input
Remove the batteries and wait a minute or two. Put them back in and turn the calc back on and it should function normally. Check for stuck buttons as well, as sometimes they will cause the calc to appear "frozen".
Sep 30, 2010 | Texas Instruments TI-89 Calculator
Half my TI-89 calculator screen is blank. Do you know if you can buy a replacement LCD?
You can contact or by email to inquire about where you can buy a screen.
Hope it helps.
Oct 24, 2009 | Texas Instruments TI-89 Calculator
Ti-83 plus silver edition. calc won't turn on.
Well, if screen shows the RAM CLEARED message, that means your calculator is working. Just press the [CLEAR] key, message will be erased and you are ready to crunch numbers.
Hope it helps.
Oct 09, 2009 | Texas Instruments TI-83 Plus Silver...
Ti 84 not working
Since it gets tossed around a lot, it is possible though improbable that the batteries lose contacts with the electrical terminals.
You may try to darken the screen a bit.
1. Press [2nd] key and release it
2. Press [UpArrow] and release it.
3. Repeat steps 1 and 2 in sequence until contrast is satisfactory.
If that does not fix the problem, use a calc-to-calc cable and try sending something to it from a working calculator.
You can also download the TIConnect software from and install it on your computer. Then connect the calculator to the computer by means of a USB cable, a TISilverCable, or a TI Graphlink (Black cable). Turn the calculator ON, run TIConnect, connect calc-to-computer and Click TIDEVICEINFO in TIconnect main window.
If it tells you NOT FOUND, on any of the ports, click the communication settings: Set the device type to you calculator model. Set the cable type. Set the port (COM x) or USB1
If calculator is not detected through any of the available ports (COM ports, or USB), then it would suggest that calculator is in need of repairs.
Hope it helps.
Sep 26, 2009 | Texas Instruments TI-84 Plus Calculator
TI 83 Plus won't turn on after battery change
I was having the same problem...I found the info below on another blog and it helped me fix my calculator problem. Take out all the batteries, hold the DEL button and put the batteries back in (keep holding the DEL button until all batteries are put back in). This will restart the calculator and restore it to its default settings...but it makes it work again!
"Reflashing the OS is probably the thing to do now. I think there's some trick that throws the calc into OS receiving mode. Hold down DEL while putting the batteries in? I don't remember if that's it. Go to 1-800-TI-CARES/ if you need specifics on getting the calc to take an OS upload given the state it's in."
Feb 24, 2009 | Texas Instruments TI-83 Plus Calculator
Darken screen!!!
reset your calc, press 2nd left right on simultaneously. it should work.
Apr 25, 2008 | Texas Instruments TI-89 Calculator
Cannot get the "fix" to go off.
How do I clear off fix (rounding) mode on the TI-10 and TI-15?
In order to clear Fix off the calculator just press the following keys
- First press the [Fix] key
- Next press the [.] decimal key
Oct 01, 2007 | Texas Instruments TI-15 Explorer...
Texas Instruments TI-15TK Calculator Logo
168 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
