Question about Metra Ford/Chry/Jeep 1974 99
Rough idel I have a 99 with a 4.0 that has a rough idel and the service engine light is on it smooths out just off idel and runs fine at higher rpms and under a load.
  • 57 Answers
If your check engine light is on, you can have the OBDII code read at most local autoparts stores. If you have a flashing check engine light, don't continue to drive as you will damage your catalytic converter. The auto parts store can tell you what the P-code is and what the possible parts replacement solution would be. Call ahead to make sure they offer this as a free service. If it is at idle, my hunch is you need to clean your throttle plate and throttle bores. You didn't say what kind of car or engine (Just 99 4.0L). So that's as specific as I can be.
Posted on Feb 28, 2009
Which way do I shift my 3L Toyota hiace fuel pump for a smoothe idle it starts fine but idels rough and moves off weak ?
Best to have codes read if the engine light is on. start up and rough idle are different. Rough idle can be different things. When is the last time you had a tune up?
Jan 02, 2017 | Toyota Cars & Trucks
7.5 l engine. Starts well but idles a bit roughly. Check engine light illuminates intermittently but does not stay lit constantly. Thanks!
If you have a check engine light the best thing is to read the codes and find out what the problem is. Many shops like Aamco read codes free.
Feb 14, 2015 | Cars & Trucks
Engine codes p2299
Without knowing the vehicle, I'd say you have a problem with your fuel injection. I had a 1990 Cadillac Deville with a rough idle, and smooth operation at higher RPMs, and replacing all of the fuel injectors was my solution.
Nov 04, 2013 | Vehicle Parts & Accessories
When ideling the rpms pulse slightly what is the
Plugged air filter - replace.
Dirty throttle body and idle/air control motor - Can of Carb. cleaner sprayed into throttle body and idle/air hole while engine is running.
If engine is also running rough check:
-Spark Plugs.
-Compression for bad valve.
Jun 25, 2010 | 1999 Oldsmobile Alero
Missing
Sounds like a load miss. Chk plug wires for deterioration and or cross firing. Wires should not cross over each other. Worn plugs load wires causing increase spark out put increasing cross firing potential
Apr 30, 2009 | 1986 Ford F 250
Engine runs rough after about ten minutes /idles really low
Just trowing some suggestions out there, but, I would check the idle air control valve (solenoid) or the throttle position sensor. If they check out then my last guess would be the map sensor or the vaccuum to the map sensor. Hope I was able to help. Best wishes.
Jan 16, 2009 | 1991 Plymouth Laser
"99 cherokee classic: sputtering when cold
I had the same problem with my 99 Cherokee. I was told to replace the blower motor for the carburetor, works great and gas mileage improved.
Jul 16, 2008 | 1999 Jeep Cherokee
Metra Ford/Chry/Jeep 1974 99 Logo
134 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
