Question about Philips 60PW9363 60" Rear Projection Television
I have a philips rear projection 60 inch model60pw936317f its got kind of a 3 d blue line on all the words
  • Philips Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
77ea520.jpgi have a philips rear projection 60 inch - f0900cb.jpgmi
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips arei have a philips rear projection 60 inch - 2c07611.pngould be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on May 07, 2009
The colors look very weak. The green is weaker than the blue. Red seems ok. I have a philips 60 inch rear projection. It almost looks like a haze. The colors are not crisp. .
The TV has coolant in the CRTs that after years of use get cloudy. you will need to have a shop replace the coolant in all three, it is pretty involved so its best to have a trained tech. do it.
Oct 30, 2010 | Philips 60PP9202 60" Rear Projection...
I have a 60 inch Philips tv and the picture is kind of blury and a little red. What is tha caused from?
THREE possible reasons for this:
I will list each and describe for you:
1.) If redish picture go to a black and white channel; is the screen somewhat red or black and White? This is adjustable from inside the set.
2.) If colors are skewed or look like they have a red outline it may be a convergence problem. See attached photo.
3.) Some of these sets develop a problem with the coolant which is used to keep the face of each of the three tubes cool; it is called Glycol. You would have to remove back cover and with set on look into each of the three lens (red,green,blue) to see if you have a clear red, green and blue picture.
Which best describes your problem?
Aug 10, 2010 | Philips 60PP9352 60" Rear Projection...
BLue will not allign
This is probably a failure in the convergace board
This should be looked at by a competant service engineer due to the high voltage in this circuit
Jun 28, 2010 | Philips 60PP9352 60" Rear Projection...
What kind of lamps ???
You have 3 tubes red-green-blue.
Encompass Parts might have some in stock 1-800-638-3328
Mar 23, 2010 | Philips Magnavox 9P6034C 60" Rear...
Pictures not lined up and angled
Sounds like your convergence is just out. First make sure the mirror in back is pulled out completely (if you have that model). Otherwise, there is a convergence feature on the menu that should fix it all.
Jan 03, 2009 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60 in. Help
You will need a service call by a qualified technician....
Red & green = yellow, therefore the blue CRT has a problem..T.
Feb 12, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 60 inch rear projection t.v. model number 60PP9363H/17
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 26, 2007 | Philips 60PP9352 60" Rear Projection...
Mitsubishi 6071 April 1994 NEED HELP!!!
these sets have bad connections in the picture yokes take the spekerr grill off and front cover move the wires around and see if the pic comes back be careful ok
Oct 03, 2007 | Mitsubishi VS-60719 60" Rear Projection...
Open Questions:
Philips 60PW9363 60" Rear Projection Television Logo
282 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
