Question about JVC AV-32230 32" TV
RED BLINKING TIMER TV WONT TURN ON
KEY20 MY JVC MODEL AV-36D502 STARTED BLINKING RED TIMER AND WOULD NOT COME ON,I TRIED TO UNPLUG THE POWER BUT COULD NOT SOLVE THE TIMER ISSUE HELP
  • 57 Answers
Page 40 on the PDF link below may help - Ask me if you need further assistance.
Thanks
Len
http://resources.jvc.com/Resources/00/00/99/51798Cien.pdf
Posted on Feb 28, 2009
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
JVC Model AV-36D502 Blinking power light on start-up
you probably have some sort of overheating or short on the internal board - is it still on warranty? if so they will fix at no charge - if not, a local repair shop should be able to correct the problem but it may cost as much as $150
Jan 26, 2008 | JVC AV-36D502 36" TV
Jvc model av32s33 wont turn on and has a blinking red light
check for a shorted regulator in the power supply section and bad horizontal output transistor.
Oct 02, 2012 | JVC AV-32S33 32" TV
Want to connect my JVC AV-36D502 to my lap top computer
hi hmwpeg
• you may need a PC to TV Converter
like one of these:
http://sewelldirect.com/pc-to-tv.asp
instruction is on the web page.
• to enable on your laptop, set your JVC TV as secondary monitor.
• use the Catalyst control panel.
hope these helps
thanks for choosing Fixya for assistance
Sep 05, 2012 | JVC AV-36D502 36" TV
JVC AV-36D502 36
Check and replace the chroma IC.
Aug 13, 2012 | JVC AV-36D502 36" TV
Hi there TV is a JVC AV-36F713. Turned TV on a few days ago and nothing. Red flashing light on bottom of TV. Looked it up and manual said needs repair etc. Any ideas? Thanks Tim Also...
Hello Jim O'Connell,
Welcome and thank you for using FixYa!
To answer your question: I would suggest having a television repair professional pull out the power supply board.
They will need to remove the board and check it for bad (cold) soldier joints, bad capacitors, and lastly, to use an Osilliscope to test the +5v and -5V transistors on the board. If they can't diagnose the board, they can use the part number to order and install a replacement for you. That should fix your issue.
Have a great day!
Oct 15, 2011 | JVC AV-36D502 36" TV
I was watching tv and it just shut off now the power light is blinking red and a clicking noise is coming from the tv. It wont stop unless I unplug it
i chaged some flyback on that model. you can unsolder b+ of fbt and replace with a 75 watt bulb to see if power supply or fbt.
Apr 22, 2010 | JVC AV-36D303 36" TV
JVC AV-36D502: Input #3 doesn't work
Good day sir, its a different issue, about the capacitor, for as long as your replacement part is correct, it will work, now, there are several things you should check, the I/O device that controls the inputs of the TV, usually an IC, check your schematic diagram to trace the fault. check also the line from the input 3 to the controller IC on your diagram. Measure the voltage across the IC Vcc to ground if the IC is getting the right power, Low voltage can be cause by faulty capacitors, on the power supply line, or the IC itself is faulty, Circuit analysis and voltage measurements are needed to trace the faulty part. hope this helps thanks.
Oct 23, 2009 | JVC AV-36D502 36" TV
Tv shutting off timer light blinking
The problem you describe is not really related to a timer function being set. The unit is in shutdown and the light is blinkng to let you know there is a problem.
There are several possible causes. the most common is a failure in the vertical deflection circuit due to a bad vertical IC and possibly a capacitor, zener diode and resistor.
Feb 19, 2009 | JVC AV-27530 27" TV
JVC AV-32230 32" TV Logo
548 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
