Question about MSI Wind U100-030US Laptop
Msi keyboard locked
I have an msi wind netbook, the keyboard won't work ... the touchpad does though ... any ideas?
  • ekberk Feb 28, 2009
    oh, i tried to restore system to an early date - it didn't work ...
4 Suggested Answers
  • 136 Answers
SOURCE: touchpad tapping for MSI Wind U100 laptop
Usually this on/off feature comes with the manufacturer drivers. If (I'm assuming you are using windows) the OS was re-installed, it just uses a generic driver which does not include advanced options. And MSI seem to not provide this driver (I've searched). Maybe there is an option for it on their System Control Manager. You can download it here:
http://global.msi.com.tw/index.php?func=downloaddetail&type=utility&maincat_no=135&prod_no=1474
In LINUX, it is a bit more complex, because it is not easy to get a specific driver for the touchpads .
Posted on Nov 02, 2008
freedhast
  • 3 Answers
SOURCE: built in webcam not working MSI wind notebook u100 series
please chek ur webcam status..that on or off. if off press fn + f6.
Posted on Aug 25, 2009
DwyerMN
  • 62 Answers
SOURCE: how do u turn off the bluetooth on the msi wind
Press【Fn 】+ 【F11】for Bluetooth \ WLan functions
I believe that the number of times you press the FN+F11 button, these would be the results. I hope this helps you.
1. Both Bluetooth, Wireless LAN Off
2. Bluetooth Off, Wireless LAN On
3. Bluetooth On, Wireless LAN Off
4. Both Bluetooth, Wireless LAN On
Posted on Oct 26, 2009
SOURCE: u100 msi wind netbook, webcam problems
i have same problem pls sant driver u100 webcam artit146@gmail.com
Posted on Jun 12, 2010
Msi netbook
Try downloading ALL the drivers from msi. Windows drivers don't always work properly as they are generic.
May 23, 2014 | MSI Computers & Internet
Msi wind broken dc power connector port
1) http://www.bit-tech.net/hardware/laptops/2008/07/05/breaking-wind/1
2) http://www.radioshack.com/product/index.jsp?productId=2103245
3) http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
[You don't need a Soldering Station though. Use a 25 Watt soldering iron, or so. Rosin core solder, Rosin flux paste, etc ]
4) http://laptopjacks.com/product/MSI-Laptop-DC-Power-Jacks.html
So, who is going to do the job?
Post back in a Comment.
Regards,
joecoolvette
Mar 14, 2013 | MSI Wind U100 Netbook
Battery falls out
Try to get something to hold it like duck taping the locking tabs over the battery
May 08, 2012 | MSI Wind U120-020US Netbook
How do i activate the wireless connection on my daughter msi u100 435uk netbook as it won,t come on after ste used a pay as you go dongle when staying with friends who had no internet
go intocontrol paneland select add/remove programs or programs and features and find the payg dongle software and uninstall it then restart the netbook that should remove the dialup connection and allow you to connect back to your wireless.
If you need any more help leave a message
Mar 04, 2011 | MSI Wind U100 Netbook
I just bought a MSI Wind U100-649ca Netbook Computer on ebay and the only problem is that the touchpad is worn out. I also have an Acer Aspire 5570Z and the touchpad works perfectly. The thing is I want to...
You can't exchange touchpads, The reason for this is the ZIF line usually has a different pinout. How ever you can fix the touch pad by cleaning the contact where it slides into the motherboard and you should be good to go. You should find all the connections right under the keyboard and they should be easy to open and clean out, make sure you re-seat them completely and if that does not work make sure you have the latest drivers for your system and the touchpad installed. If non of those help you can easily find a replacement touchpad unit off ebay as well for your MSI laptop.
Apr 09, 2010 | Acer Computers & Internet
MSI U100 :S
I believe holding down the Fn button (on the bottom left of the keyboard) and F6 turns the webcam off and on. If it is off, it won't be seen by windows at all. Just hit Fn and F6 at the same time and you should be all set. The F6 key even has a small picture of what should be a webcam.
EJ
Jan 26, 2010 | MSI Wind U100 Netbook
My touchpad on my msi win notebook is not responding...how can I fix it
Try this:
On the bottom left of your keyboard there is an "Fn" button. Press Fn + F3. Then try and see if the touchpad works now.
Oct 27, 2009 | MSI Wind U100-030US Laptop
MSI Wind U100-030US Laptop Logo
529 people viewed this question
Top MSI Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
