Ink question How do I tell how much ink I have left in my printer? I have a F2110 Deskjet.
  • 145 Answers
If you do not have indicator .you should look at print quality.if light you should change it.and you should read the ink cart-info should indicate the yield..
Posted on Feb 28, 2009
Ink light is on. which cartridge needs to be replaced
The printer's indicator lights tell you when to obtain a replacement ink cartridge by flashing when ink is low, and when to replace an empty ink cartridge by remaining on when ink is depleted. The LCD panel also displays INK LOW or INK OUT.
Even if only one ink cartridge is empty, the printer cannot continue to print.
Nov 24, 2014 | HP DeskJet 960c InkJet Printer
DeskJet 940c InkJet Printer: I have an hp deskjet 940c printer. The orange lig...
the moving ink frame is probably pointing to a symbol such as replace color ink( three dots on ink cartridge picture). Replace color ink. You are probably printing your black and white documents with colored ink--always select black or greyscale.
May 17, 2010 | HP DeskJet 940c InkJet Printer
The red light on left is blinking. What does that indicate? I have a deskjet 904C. There are three light The left one is blinking, the middle is okay and the right is the green one, that shows me the...
Hi:
If you open the door on the top of the printer, while it is powered on, the ink cartridges will move to a spot that shows you the status of your ink.. There are little cartoon pictures of the cartridges with smiles or frowns to tell you if you have an empty color or black cartridge.
Nov 04, 2009 | HP DeskJet 940c InkJet Printer
Where can I download the deskjet 932c toolbox?
try downloading complete driver and software from HP.
You can open the door and the ink will go to the smily face or the frown telling you ink is low or good.
Sep 03, 2009 | HP DeskJet 932c InkJet Printer
How do i check the ink level on my hp deskjet f21000 all in one series i have a advent 5431es laptop many thanks
Most reliable way, is to take out your cartridges and give them a shake. this does two things
1. Tells you how much is left
2 Mixes ink once again as they do separate.
Jul 16, 2009 | HP Ruggedized DC Car Adapter for HP...
I used to refill the ink cartridge of HP Deskjet D1460 by injecting ink. The problem is the level of ink is not resetted to full level, its still very low level. However, the printer prints normally
Close the top left pin at head contactor (1 pin only), with tape. Plug it in head carriage. Unplug it. Close to top rigtht with tape too. Plug the head. Unplug head. Remove all the tape cleanly. Plug again. See ink monitor.
May 28, 2009 | HP DeskJet D1460 InkJet Printer
The ink light blinks all the time since I replaced the color
The ink light flashes when the top cover is open...check the switch that tells the printer when the cover is closed.
Feb 23, 2009 | HP DeskJet 842c InkJet Printer
HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
Can't find ink levels on my printer
I just had this same problem on my Deskjet 5550 printer. The orange light (ink indicator) was staying on. I found out that all you need to do is just open the front cover to the printer. If your printer is running out of ink, the print cradle will move to either the far left or far right side. If it moves to the far left side, the BLACK cartridge is low or empty and should be replaced. If the print cradle stays on the far right side, the COLOR cartridge should be replaced. Normally, when you open the front cover, the print cradle should move to the center. Hope this helps!
Aug 11, 2008 | HP DeskJet 5550 InkJet Printer
Ink level problem
are you refilling your cartridges? if so, there are two contacts on the print head that connect to the printer program that estimate ink usage and what's left. go to a site that deals with hp printers and they'll explain to you on how to reset your software for ink usage.
Nov 04, 2007 | Heating & Cooling
jasbo
jasbo
